Hulu (US only)
jjslegacy
Post Mon Oct 08, 2012 7:45 pm
Re: Hulu (US only)
Anybody else having trouble with the hulu plug-in all the sudden? I have the new one and it worked last week but now none of my hulu feeds have any shows.
Any ideas?
Post Tue Oct 09, 2012 12:37 pm
Re: Hulu (US only)
did you try the latest plugin?
jjslegacy
Post Tue Oct 09, 2012 2:26 pm
Re: Hulu (US only)
my bad I grabbed the full pack and it seems it hasn't been updated to have the latest hulu plug-in. Grabbed the 10/6 one and all is well again.
Thanks!
WildRushSykes
Post Tue Oct 09, 2012 2:37 pm
Re: Hulu (US only)
Whoops my bad JJS :cry: havent been on that much of late but i must admit that the Hulu plugin is the only one that was out of date and is now fixed in the latest update :)
Honestly sometimes i think i need a good smack round the head sometimes because either im blind or dumb or a bit of both hopefully it might fix me :lol:
jjslegacy
Post Tue Oct 09, 2012 2:53 pm
Re: Hulu (US only)
WildRushSykes wrote:Whoops my bad JJS :cry: havent been on that much of late but i must admit that the Hulu plugin is the only one that was out of date and is now fixed in the latest update :)
ha no worries my bad for not checking better.
supekrups20056
Post Mon Oct 22, 2012 2:59 pm
Re: Hulu (US only)
I am thinking about purchasing Serviio just because I love this plugin so much! However, I have a few questions...
1) I've tested this on Windows and this Hulu plugin works perfectly! Will it work just as well for Mac?
2) Currently on Hulu, you have to to be logged in and provide your DISH subscriber information in order to play videos from Fox. However, there is no logging in with this plugin...Can this plugin push Fox TV shows to my DLNA capable BluRay player if I am logged in with my default browser?
3) Off topic but this is my first post and my username has a typo in it. It's supposed to be 'superkrups20056'. Is there a way to change this? Thank you.
Post Mon Oct 22, 2012 9:23 pm
Re: Hulu (US only)
It'll work on Mac. Currently there is no support for logged in users in this plugin.
colt42
Post Tue Oct 30, 2012 9:02 pm
Re: Hulu (US only)
Plugin works perefct except for a small but hugely annoying issue-
Hulu's shows RSS has a LIMIT to the amount of episodes it indexes... This actually causes some shows to not supply any working streams via this plugin, because the latest episodes might be Hulu Plus only while the earlier ones are free and the latest ones clog up the RSS until it reaches its indexing limit.
Example: Arrested Development - http://www.hulu.com/feed/show/51/episodes.
Season 2 and 3 are Hulu Plus only, while season 1 which is free Hulu isn't indexed because seasons 2 and 3 max out the amount of episodes indexed in the RSS. Plus, I think we should be able to see all available episodes without having to endure limits.
Any solutions for this problem?
I don't mean to criticize, but Serviio is such a well written program for streaming even with the most problematic devices, but the user-interface limitations and having to rely on the suppliers RSS files make this programs brilliant streaming capabilities to be completely overlooked and undermined.
DrCee
Post Tue Nov 06, 2012 12:13 am
Re: Hulu (US only)
You can get serviio to filter by series if you add this to the string in the console e.g. arrested+development+s1. :D
This will start your list of streams from the beginning of series 1. I haven't tried but i'm guessing hulu+ episodes might not work
sleepykid
Post Wed Nov 07, 2012 8:19 pm
Re: Hulu (US only)
Anybody else having problems running this? running 1.01 on a mac, watching through vlc
arsaboo
Post Thu Nov 08, 2012 11:38 pm
Re: Hulu (US only)
Is there any way to add a particular movie or episode (e.g. http://www.hulu.com/watch/361989) to Serviio. Better still, can I add the entire movie genre in Serviio (e.g., http://www.hulu.com/movies/genres/international/british)? Kindly advice.
sleepykid
Post Fri Nov 09, 2012 2:53 am
Re: Hulu (US only)
Never mind, seems to work after a reboot
miksa
Post Thu Nov 15, 2012 8:23 pm
Re: Hulu (US only)
arsaboo wrote:Is there any way to add a particular movie or episode (e.g. http://www.hulu.com/watch/361989) to Serviio. Better still, can I add the entire movie genre in Serviio (e.g., http://www.hulu.com/movies/genres/international/british)? Kindly advice.
@arsaboo - i have found Hulu RSS plug-in to be very useful and flexible. It can be used to play a particular movie via feed search and channel via feed path, for example
Hero - http://www.hulu.com/feed/search?query=Hero+1983
International Movies - http://www.hulu.com/feed/channel/International?type=movies
- Mike
darkcloud784
Post Thu Jan 10, 2013 6:04 am
Re: Hulu (US only)
I have yet to get a plugin to work. I get the link to the RSS feed, set it as an RSS/Atom in the library and click add. I move the groovy file to the plugins folder inside the root of serviio. This is the only error I get after restarting the server:
2013-01-09 23:55:34,820 WARN  [LibraryAdditionsCheckerThread] An error occured while scanning for item to be added, will continue
org.serviio.db.dao.PersistenceException: Cannot mark Repository with id 1 as scanned
   at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:173)
   at org.serviio.library.local.service.RepositoryService.markRepositoryAsScanned(RepositoryService.java:112)
   at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:84)
Caused by: java.sql.SQLNonTransientConnectionException: Connection closed by unknown interrupt.
   at org.apache.derby.impl.jdbc.EmbedStatement.executeStatement(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeStatement(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedPreparedStatement.executeUpdate(Unknown Source)
   at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:171)
   ... 2 more
Caused by: java.sql.SQLException: Connection closed by unknown interrupt.
   ... 12 more
Caused by: ERROR 08000: Connection closed by unknown interrupt.
   at org.apache.derby.iapi.util.InterruptStatus.setInterrupted(Unknown Source)
   at org.apache.derby.iapi.util.InterruptStatus.throwIf(Unknown Source)
   at org.apache.derby.impl.sql.execute.BasicNoPutResultSetImpl.checkCancellationFlag(Unknown Source)
   at org.apache.derby.impl.sql.execute.TableScanResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.IndexRowToBaseRowResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.ProjectRestrictResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.NormalizeResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.DMLWriteResultSet.getNextRowCore(Unknown Source)
   at org.apache.derby.impl.sql.execute.UpdateResultSet.collectAffectedRows(Unknown Source)
   at org.apache.derby.impl.sql.execute.UpdateResultSet.open(Unknown Source)
   at org.apache.derby.impl.sql.GenericPreparedStatement.executeStmt(Unknown Source)
   at org.apache.derby.impl.sql.GenericPreparedStatement.execute(Unknown Source)
   ... 6 more
I have posted on 3 different plugin topics and have yet to get any support on these types of issues from the authors. I am on a windows 7 PC, streaming to a Samsung TV. Full Detailed log below:
2013-01-09 23:26:27,929 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-09 23:26:27,944 INFO  [MediaServer] Serviio DLNA media streaming server v 1.1 (rev. 6ba0dd933a8e+)
2013-01-09 23:26:27,944 INFO  [MediaServer] Petr Nejedly 2009-2012
2013-01-09 23:26:27,944 INFO  [MediaServer] http://www.serviio.org
2013-01-09 23:26:27,944 INFO  [MediaServer] Java 1.7.0_09-Oracle Corporation
2013-01-09 23:26:27,944 INFO  [MediaServer] OS Windows 7 amd64 6.1
2013-01-09 23:26:27,944 INFO  [MediaServer] File encoding: windows-1252
2013-01-09 23:26:27,944 INFO  [MediaServer] Headless mode enabled: true
2013-01-09 23:26:27,944 INFO  [MediaServer] User: SHARK$
2013-01-09 23:26:27,944 INFO  [MediaServer] User home dir: C:\
2013-01-09 23:26:27,944 INFO  [MediaServer] Temp dir: C:\Windows\TEMP\
2013-01-09 23:26:27,944 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-09 23:26:29,738 INFO  [WebServer] Socket buffer set to 65535 bytes
2013-01-09 23:26:29,754 INFO  [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-01-09 23:26:29,941 INFO  [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-01-09 23:26:29,941 INFO  [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-01-09 23:26:30,003 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-01-09 23:26:33,576 INFO  [MediaServer] ------------------------------------------------------------------------
2013-01-09 23:26:33,576 INFO  [MediaServer] License: PRO (NORMAL, id: 461eb4f9-e405-40eb-85d1-dbc328cefe6b)
2013-01-09 23:26:33,763 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-01-09 23:26:35,214 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-01-09 23:26:35,744 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-01-09 23:26:36,087 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-01-09 23:26:36,353 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-01-09 23:26:36,524 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-01-09 23:26:36,649 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-01-09 23:26:37,070 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-01-09 23:26:37,086 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-01-09 23:26:37,772 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-01-09 23:26:38,365 INFO  [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2013-01-09 23:26:38,599 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-01-09 23:26:38,817 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-01-09 23:26:38,864 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-01-09 23:26:38,973 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-01-09 23:26:39,020 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-01-09 23:26:39,207 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-01-09 23:26:39,301 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-01-09 23:26:39,504 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-01-09 23:26:39,738 INFO  [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2013-01-09 23:26:39,863 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-01-09 23:26:39,909 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-01-09 23:26:40,315 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-01-09 23:26:40,393 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-01-09 23:26:40,455 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-01-09 23:26:40,533 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-01-09 23:26:40,627 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-01-09 23:26:40,767 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-01-09 23:26:40,830 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-01-09 23:26:40,955 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2013-01-09 23:26:41,235 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-01-09 23:26:41,438 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-01-09 23:26:41,547 INFO  [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-01-09 23:26:42,437 INFO  [Device] Created UPnP Device with UUID: dee3f94e-28dc-363d-ab06-b84cb061d425, bound address: 192.168.1.136
2013-01-09 23:26:43,357 INFO  [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-01-09 23:26:43,357 INFO  [UpdateChecker] Checking if a new version is available
2013-01-09 23:26:43,373 INFO  [PluginCompilerThread] Started looking for plugins
2013-01-09 23:26:46,929 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-01-09 23:26:47,101 INFO  [WebServer] WebServer starting on port 8895
2013-01-09 23:26:47,132 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-01-09 23:26:47,132 INFO  [EventDispatcher] Starting EventDispatcher
2013-01-09 23:26:47,132 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-01-09 23:26:47,132 INFO  [RendererExpirationChecker] Starting RendererExpirationChecker
2013-01-09 23:26:47,201 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller) and address 192.168.1.136, timeout = 0
2013-01-09 23:26:47,295 INFO  [PluginCompilerThread] Added Feed plugin Hulu (US only) (Hulu.groovy), version: 1
2013-01-09 23:26:47,482 INFO  [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
2013-01-09 23:27:13,528 INFO  [FeedUpdaterThread] Started looking for information about online resources
2013-01-09 23:27:13,531 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-01-09 23:27:13,590 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-01-09 23:27:13,591 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2013-01-09 23:28:21,496 INFO  [ServiioConsole] Starting Serviio Console
2013-01-09 23:28:22,939 INFO  [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-01-09 23:28:33,633 INFO  [Messages] Loaded console message bundle for locale: en
2013-01-09 23:29:11,390 INFO  [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-01-09 23:29:12,472 INFO  [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2013-01-09 23:53:48,151 INFO  [WebServer] WebServer shutting down
2013-01-09 23:53:48,151 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-01-09 23:53:48,151 INFO  [EventDispatcher] Leaving EventDispatcher
2013-01-09 23:53:48,151 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-01-09 23:53:48,151 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-01-09 23:53:52,247 INFO  [RendererExpirationChecker] Leaving RendererExpirationChecker
2013-01-09 23:53:52,527 WARN  [ServiioStatusService] ValidationException occured. Returning error code 400 to the REST layer. Message: null
2013-01-09 23:53:59,424 INFO  [WebServer] WebServer starting on port 8895
2013-01-09 23:53:59,425 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-01-09 23:53:59,425 INFO  [EventDispatcher] Starting EventDispatcher
2013-01-09 23:53:59,425 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-01-09 23:53:59,445 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller) and address 192.168.1.136, timeout = 0
2013-01-09 23:53:59,780 INFO  [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
2013-01-09 23:54:14,029 WARN  [ServiioStatusService] ValidationException occured. Returning error code 400 to the REST layer. Message: null
2013-01-09 23:54:29,932 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-01-09 23:54:30,032 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-01-09 23:54:30,132 INFO  [PlaylistMaintainerThread] Finished looking for playlist changes
2013-01-09 23:54:30,302 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-01-09 23:54:30,302 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-01-09 23:54:30,387 INFO  [PlaylistMaintainerThread] Started looking playlist changes
2013-01-09 23:54:34,493 INFO  [WebServer] WebServer shutting down
2013-01-09 23:54:34,493 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-01-09 23:54:34,493 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-01-09 23:54:34,493 INFO  [EventDispatcher] Leaving EventDispatcher
2013-01-09 23:54:34,493 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-01-09 23:54:37,997 INFO  [WebServer] WebServer starting on port 8895
2013-01-09 23:54:37,997 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-01-09 23:54:37,997 INFO  [EventDispatcher] Starting EventDispatcher
2013-01-09 23:54:37,997 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-01-09 23:54:38,017 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller) and address 192.168.1.136, timeout = 0
2013-01-09 23:54:38,348 INFO  [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
2013-01-09 23:55:32,496 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-01-09 23:55:32,596 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-01-09 23:55:32,696 INFO  [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-01-09 23:55:32,696 INFO  [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-01-09 23:55:33,063 WARN  [LibraryAdditionsCheckerThread] An error occured while scanning for item to be added, will continue
org.serviio.db.dao.PersistenceException: Cannot mark Repository with id 3 as scanned
   ... 2 more
   ... 12 more
   ... 6 more
2013-01-09 23:55:33,064 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-01-09 23:55:33,120 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
slyguy42o
Post Tue Jan 15, 2013 4:34 pm
Re: Hulu (US only)
darkcloud784 wrote:I have yet to get a plugin to work. I get the link to the RSS feed, set it as an RSS/Atom in the library and click add. I move the groovy file to the plugins folder inside the root of serviio. This is the only error I get after restarting the server:
   ... 2 more
   ... 12 more
   ... 6 more
   ... 2 more
   ... 12 more
   ... 6 more
not seeing anything useful in your logs.
What URL are you trying to use?
Also can you enable detailed logging and post another set after trying with this enabled?
darkcloud784
Post Thu Jan 17, 2013 5:45 am
Re: Hulu (US only)
Here's the only thing from the hulu applet:
2013-01-16 23:41:27,305 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 12)
2013-01-16 23:41:27,305 DEBUG [OnlineLibraryManager] Resource http://www.hulu.com/feed/show/12138/episodes not in cache yet, loading it
2013-01-16 23:41:27,305 DEBUG [FeedParser] Parsing feed 'http://www.hulu.com/feed/show/12138/episodes'
2013-01-16 23:41:27,905 DEBUG [AbstractCDSLibraryIndexingListener] Library updated, notifying CDS
2013-01-16 23:41:28,114 DEBUG [FeedParser] Found matching url extractor (Hulu (US only)) for resource http://www.hulu.com/feed/show/12138/episodes
2013-01-16 23:41:28,114 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Teenage Mutant Ninja Turtles - s1 | e12 - It Came from the Depths
2013-01-16 23:41:30,179 DEBUG [FeedParser] Unexpected error during url extractor plugin invocation (Hulu (US only)) for item Teenage Mutant Ninja Turtles - s1 | e12 - It Came from the Depths: Invalid SMIL XML, content probably expired. Expression: (matcher.count == 1)
2013-01-16 23:41:30,180 DEBUG [FeedItemUrlExtractor] Hulu (US only): Starting extraction of url for item: Teenage Mutant Ninja Turtles - s1 | e11 - Mousers Attack!
Here's the URL:
Here's where I'm getting it from:
http://www.paulscomputerservice.com/dow ... -feeds.txt
Post Thu Jan 17, 2013 10:24 pm
Re: Hulu (US only)
This means the video is not available, either it already expired, or like in this case, is a HuluPlus content, which is not supported by this plugin.
Spaceboy64
Post Mon Jan 28, 2013 6:02 am
Re: Hulu (US only)
I finally had success with one of the URLS for Hulu
http://www.hulu.com/feed/search?fs=0&qu ... pe=episode
That one works great! Could you explain how to compose a URL like the one above but for a different show? I tried substituting the show name for Lost+in+Space, but that didn't work.
MikK
Post Wed Jan 30, 2013 6:10 pm
Re: Hulu (US only)
Out of interest, and to satisfy my curiosity, is there a reason why the plugin has to use the RSS feed rather than scraping the 'All episodes' page for a show? Would be great for it to become a web resource and get all the episodes, rather than last 20 dictated by the RSS feed from Hulu.
MikK
Post Thu Jan 31, 2013 8:57 am
Re: Hulu (US only)
@Spaceboy64
The url style I've been using is not like yours where you are using a search to gain access to an RSS feed.. What you need to do is use the shows id number.
Example for Lost in Space ::
http://www.hulu.com/feed/show/26/episodes
To get the 'show_id' just browse hulu for the show and go to its Episodes page ::
http://www.hulu.com/grid/lost-in-space? ... pe=episode
Now view the pages source in your browser and search for show_id":
This will give you the number... Just replace the number in the example above with the show you wish to stream.
I'm sure this has been explained in a previous post on this thread.. but doesn't harm to repeat from time to time.
Return to Available plugins
Users browsing this forum: Google [Bot] and 8 guests
