media files not in series, movies, etc.
malcm
Post Tue Oct 16, 2012 6:44 pm
Hey guys,
I update from serviio 0.6.2 to 1.0.1. Now I have a problem. All files scanned successfully. But they are only accessible by mediabrowser and Samsung TV (D-series) over "Folders"-folder. In "series" or "movies" no movie is available. And forcing a rescan ends very fast (~10s). Did anybody have a clue? I think this error is very wired.
Otherwise I have to downgrade and use my backup of version 0.6.2
Thanks for your time!
malcm
Spadge
Post Wed Oct 17, 2012 12:57 pm
Re: media files not in series, movies, etc.
go to thetvdb.com and rename one of the files to match the exact name given there without spaces, rescan, see if that causes the ep to show up in 'series'
eg: Chuck.s01e01.avi or Dead.Like.Me.s01e01.mkv
make sure there are no illegal characters in the file/folder path name
malcm
Post Wed Oct 17, 2012 3:29 pm
That should not be the problem . I use the same folder as shared folder like in version 0.6.2. There all works fine. But in version 1.0.1 it only shows the files "Folders"-folder
Spadge
Post Wed Oct 17, 2012 5:52 pm
Maybe that should not be the problem, but I'm using v1.01 without the same problems so it was just something to try by way of starting the troubleshooting process.
malcm
Post Wed Oct 17, 2012 8:56 pm
OK! I renamed it this way but the problem persist ...
Spadge
Post Wed Oct 17, 2012 9:38 pm
Could you turn on detailed logging, restart Serviio, connect with your TV and post the logs here please?
Post Thu Oct 18, 2012 3:54 pm
malcm wrote:That should not be the problem . I use the same folder as shared folder like in version 0.6.2. There all works fine. But in version 1.0.1 it only shows the files "Folders"-folder
Do you have the other categories enabled in the Presentation tab?
malcm
Post Thu Oct 18, 2012 10:07 pm
@zip all categories are enabled and visibility is "Display category". The folder series or movies is visible but weirdly empty ...
@spadge I attached the log. First I start serviio open the series folder and shutdown the server again.
(76.96 KiB) Downloaded 652 times
Post Thu Oct 18, 2012 11:31 pm
we will need you to add some more episodes/movies or remove and add some of the current ones again. then post the log.
malcm
Post Wed Oct 24, 2012 4:45 pm
Hey I add some Schloss EInstein series around "Folge 600" (Season 13)
1. I start the server.
2. Force a refresh.
3. After finishing starting TV and go to folder series. (is still empty)
4. Switch off TV
5. Stop serviio
The logs are attached.
Sorry for the delay!
logs.zip
(125.61 KiB) Downloaded 558 times
Post Thu Oct 25, 2012 11:56 am
I doesn't go to the online DBs for metadata. Do you have that enabled on the Metadata tab? Also make sure the M icon (descriptive metadata, http://wiki.serviio.org/doku.php?id=ser ... _explained) is checked for the shared folders.
malcm
Post Sat Oct 27, 2012 10:30 pm
Hey!
Yes it works bad mistake by me.
But now adding new files did not work. Here is the coresponding output of the log.
2012-10-27 21:09:28,681 DEBUG [LibraryAdditionsCheckerThread] Found file 'Pastewka_12.10.26_23-00_sat1_30_TVOON_DE.mpg.avi', checking if it's already in the Library
2012-10-27 21:09:28,682 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item Pastewka_12.10.26_23-00_sat1_30_TVOON_DE.mpg.avi
2012-10-27 21:09:28,682 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /home/martin/Videos/OTR/Pastewka_12.10.26_23-00_sat1_30_TVOON_DE.mpg.avi, ignore case: false
2012-10-27 21:09:28,683 DEBUG [MediaItemDAOImpl] Media item Pastewka_12.10.26_23-00_sat1_30_TVOON_DE.mpg.avi doesn't exist in DB yet
2012-10-27 21:09:28,683 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2012-10-27 21:09:28,684 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: /home/martin/Videos/OTR/Pastewka_12.10.26_23-00_sat1_30_TVOON_DE.mpg.avi
2012-10-27 21:09:28,684 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: /home/martin/Videos/OTR/Pastewka_12.10.26_23-00_sat1_30_TVOON_DE.mpg.avi
2012-10-27 21:09:28,685 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 252) and extractor EMBEDDED
2012-10-27 21:09:28,686 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 252) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 21:09:28,688 DEBUG [MediaItemDAOImpl] Getting file of media item 253
2012-10-27 21:09:28,689 DEBUG [ProcessExecutor] Starting ffmpeg -i /home/martin/Videos/OTR/Pastewka_12.10.26_23-00_sat1_30_TVOON_DE.mpg.avi
2012-10-27 21:09:28,691 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 253) and extractor EMBEDDED
2012-10-27 21:09:28,692 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 253) and extractor COVER_IMAGE_IN_FOLDER
2012-10-27 21:09:28,695 DEBUG [MediaItemDAOImpl] Getting file of media item 254
2012-10-27 21:09:28,696 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 254) and extractor EMBEDDED
2012-10-27 21:09:28,700 ERROR [ProcessExecutor] Fatal error in process starting: Cannot run program "ffmpeg": java.io.IOException: error=2, No such file or directory
2012-10-27 21:09:28,701 WARN  [ProcessExecutor] Cannot retrieve results, stderrReader is null
2012-10-27 21:09:28,701 DEBUG [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video file type.
I use ffmpeg from your website and compiled it on my own. I tried to run "ffmpeg -i /home/martin/Videos/OTR/Pastewka_12.10.26_23-00_sat1_30_TVOON_DE.mpg.avi" and get this output
  built on Oct 16 2012 00:20:52 with gcc 4.6.3
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid
Input #0, avi, from '/home/martin/Videos/OTR/Pastewka_12.10.26_23-00_sat1_30_TVOON_DE.mpg.avi':
    encoder         : Lavf52.31.0
  Duration: 00:22:53.24, start: 0.000000, bitrate: 813 kb/s
    Stream #0:0: Video: mpeg4 (Simple Profile) (DX50 / 0x30355844), yuv420p, 640x360 [SAR 1:1 DAR 16:9], 25 tbr, 25 tbn, 25 tbc
    Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, stereo, s16, 128 kb/s
Any ideas?
Post Sat Oct 27, 2012 10:53 pm
is ffmpeg on the path for the Serviio user? If not, use ffmpeg.location system property in serviio.sh script.
malcm
Post Mon Oct 29, 2012 9:03 pm
you are great. It seems to work right now.
Just one other problem. It is not that important but it would be nice if it works. I also use some times the online repositories (youtube). But for a while (also in the old version) it doesn't work. The files are displayed correctly, but if I start playing a file it writes unknown file format. I try to start the ffmpeg command serviio wrote in the log-file.
/usr/local/bin/ffmpeg -rtsp_transport +tcp+udp -i rtsp://v3.cache3.c.youtube.com/CigLENy73wIaHwkIERP2Xu5BBRMYDSANFEgGUgx1c2VyX3VwbG9hZHMM/0/0/0/video.3gp -y -threads 1 -copyts -c:v mpeg2video -sameq -r 30000/1001 -g 15 -c:a ac3 -b:a 384k -ar 48000 -ac 1 -map 0:0 -map 0:1 -sn -f vob /home/martin/tmp/Serviio/transcoding-temp-1000000000010005-1-ORIGINAL.stf
The problem accured I do not really understand:
AMR fmtp attribute octet-align had nonstandard empty value
Guessed Channel Layout for  Input Stream #0.1 : mono
Input #0, rtsp, from 'rtsp://v3.cache3.c.youtube.com/CigLENy73wIaHwkIERP2Xu5BBRMYDSANFEgGUgx1c2VyX3VwbG9hZHMM/0/0/0/video.3gp':
    title           : Video
  Duration: 00:03:57.73, start: 0.032633, bitrate: N/A
    Stream #0:0: Video: h263, yuv420p, 176x144 [SAR 12:11 DAR 4:3], 29.97 tbr, 90k tbn, 29.97 tbc
    Stream #0:1: Audio: amr_nb, 8000 Hz, mono, flt
[graph 0 input from stream 0:0 @ 0xa524c40] w:176 h:144 pixfmt:yuv420p tb:1/90000 fr:30000/1001 sar:12/11 sws_param:flags=2
[output stream 0:0 @ 0xa524b80] No opaque field provided
[graph 1 input from stream 0:1 @ 0xa524d00] tb:1/8000 samplefmt:flt samplerate:8000 chlayout:0x4
[auto-inserted resampler 0 @ 0xa5332c0] chl:mono fmt:flt r:8000Hz -> chl:mono fmt:flt r:48000Hz
[vob @ 0xa5791c0] VBV buffer size not set, muxing may fail
Output #0, vob, to '/home/martin/tmp/Serviio/transcoding-temp-1000000000010005-1-ORIGINAL.stf':
    title           : Video
    encoder         : Lavf54.15.102
    Stream #0:0: Video: mpeg2video, yuv420p, 176x144 [SAR 12:11 DAR 4:3], q=2-31, 200 kb/s, 90k tbn, 29.97 tbc
    Stream #0:1: Audio: ac3, 48000 Hz, mono, flt, 384 kb/s
Stream mapping:
  Stream #0:0 -> #0:0 (h263 -> mpeg2video)
  Stream #0:1 -> #0:1 (amrnb -> ac3)
Multiple frames in a packet from stream 1
Ungültiger Maschinenbefehl (Speicherabzug geschrieben)
poorly the error message is in german. But maybe you know what it means.
Thanks a lot for your great work and support :)
Post Mon Oct 29, 2012 9:37 pm
do you have enough space in /home/martin/tmp/Serviio and also write access?
malcm
Post Mon Oct 29, 2012 10:07 pm
there is enough space and write access.
the file will be created but have a size of 0 byte
I also try to copy with cp a 250mb file in the folder without problems ...
Users browsing this forum: Baidu [Spider], Google [Bot] and 60 guests
