Samsung PS51E550 - selected file not currently supported
sionghua
Post Tue Nov 13, 2012 8:54 pm
Just got the above TV, which profile should I use? currently I am using samsung c/d/e series.
I can browse videos served up by serviio no problem. However when I try to play any file is says "The selected file is not currently supported". Just upgraded to latest Samsung firmware.
Regards.
Post Thu Nov 15, 2012 2:25 pm
Re: Samsung PS51E550 - selected file not currently supported
can you post detailed log? and ffmpeg -i of the file.
sionghua
Post Sat Nov 17, 2012 1:00 pm
zip wrote:can you post detailed log? and ffmpeg -i of the file.
Debug log and ffmpeg result attached. Thanks.
FYI I am also running Allshare and Plex server on the same computer at the same time.
ffmpeg.txt
ffmpeg result
(3.65 KiB) Downloaded 647 times
serviio.zip
Debug log
(63.87 KiB) Downloaded 497 times
Post Thu Nov 22, 2012 5:18 pm
there is nothing in the log suggesting the TV even attempted to play the file. Does it work via AllShare?
sionghua
Post Fri Nov 23, 2012 9:31 am
Yes it works in Allshare, but I prefer Serviio mainly for the steaming of internet content.
sionghua
Post Tue Nov 27, 2012 6:32 am
Hi, I am returning my Samsung PS51E550 which did not work with Serviio (returned due to other issues). I am looking at buying a Panasonic TH-P50UT50A. Has anyone tested it with Serviio?
kevinm2k
Post Wed Nov 28, 2012 4:49 pm
Im having this exact same issue - the channel works great on pc, but streaming to my Samsung has this error - mine is a 6 series
Model Number: UE37ES6300
I have chosen the Samsung C/D/E Profile under renderer profile and have enabled transcoding.
The channel I am trying to play is a futubox channel.
EDIT: This has been resolved - i'm not exactly sure how but I noticed a red circle next to the found device, so I decided to delete it and try again, again it came up red I went away for a bit and came back and I noticed it was now green... it then worked! :)
