Online Content "There Are No Titles"
hbradlow
Post Sun Nov 18, 2012 3:20 am
Re: Online Content "There Are No Titles"
Thanks for the input. I had built my machine using Ubuntu JeOS and I gave up and did a reinstall using the full distribution. It works now!
hbradlow
Post Mon Nov 19, 2012 6:08 pm
It seems I was premature. While some of the files that previously did not show in my old installation now work, there are still files with the same error.
Ottomatic, how do I check if Flash is installed in a machine with no gui? Or alternatively, how do I install Flash?
ottomatic
Post Tue Nov 20, 2012 9:06 am
hbradlow, see this link:
https://help.ubuntu.com/community/Restr ... mats/Flash
I have no idea if there is any problem installing on a headless box, or how to test it.
ottomatic
Post Tue Nov 20, 2012 9:14 am
... and obviously if your machine is without gui, you may not be able to run the Ubuntu Software Center.
Instead, you enable restricted packages and then do:
$ sudo apt-get install flashplugin-installer
hbradlow
Post Thu Nov 22, 2012 7:54 am
Ok, now I am getting desperate. I do have flash installed and ITV Player works. However for BBC iPlayer files, I get the same error message. The serviio log entry is below. I would really appreciate some help.
2012-11-22 18:49:04,964 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01p0cpj_1353327394.mp4,iplayerstream/secure_auth/400kbps/b01p0cpj_1353327385.mp4,iplayerstream/secure_auth/1500kbps/MP/b01p0cpj_1353327065.mp4,iplayerstream/secure_auth/480kbps/MP/b01p0cpj_1353327393.mp4&et=1353577458&fmta-token=b1f3e25546386aae3eaab34b496af84d48319f6005072e167538277b8f4226ee tcUrl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01p0cpj_1353327394.mp4,iplayerstream/secure_auth/400kbps/b01p0cpj_1353327385.mp4,iplayerstream/secure_auth/1500kbps/MP/b01p0cpj_1353327065.mp4,iplayerstream/secure_auth/480kbps/MP/b01p0cpj_1353327393.mp4&et=1353577458&fmta-token=b1f3e25546386aae3eaab34b496af84d48319f6005072e167538277b8f4226ee playpath=mp4:iplayerstream/secure_auth/1500kbps/MP/b01p0cpj_1353327065.mp4 swfUrl=http://www.bbc.co.uk/emp/10player.swf swfVfy=1. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:291)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:382)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:86)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:124)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:268)
... 2 more
ottomatic
Post Thu Nov 22, 2012 3:09 pm
That url doesn't work for me either.
Either the BBC plugin has a bug, or the content has geographic restrictions. Are you in the uk? Does other BBC material work?
Post Thu Nov 22, 2012 5:09 pm
And what iPlayer feed URL are you using?
hbradlow
Post Fri Nov 23, 2012 2:41 am
I don't think it is a region coding issue, because I can get ITV player to work.
I have tried a couple of BBC RSS feeds, neither of which work. Here are the URL's:
http://feeds.bbc.co.uk/iplayer/highlights/tv
http://feeds.bbc.co.uk/iplayer/categories/drama/tv/list
Post Fri Nov 23, 2012 10:49 am
hbradlow wrote:I don't think it is a region coding issue, because I can get ITV player to work.
But are you in UK? iPlayer definitely works only in UK.
hbradlow
Post Tue Nov 27, 2012 1:49 am
Won't it work over a VPN?
Post Wed Nov 28, 2012 12:32 pm
It should AFAIK. But obviously FFmpeg can't get the file info, so not sure what the problem is.
Previous
Users browsing this forum: Google [Bot] and 27 guests
