Online Content "There Are No Titles"
• Page 2 of 2 • 1, 2
Thanks for the input. I had built my machine using Ubuntu JeOS and I gave up and did a reinstall using the full distribution. It works now!
Re: Online Content "There Are No Titles"
It seems I was premature. While some of the files that previously did not show in my old installation now work, there are still files with the same error.
Ottomatic, how do I check if Flash is installed in a machine with no gui? Or alternatively, how do I install Flash?
hbradlow, see this link:
https://help.ubuntu.com/community/Restr ... mats/Flash
I have no idea if there is any problem installing on a headless box, or how to test it.
... and obviously if your machine is without gui, you may not be able to run the Ubuntu Software Center.
Instead, you enable restricted packages and then do:
$ sudo apt-get install flashplugin-installer
Ok, now I am getting desperate. I do have flash installed and ITV Player works. However for BBC iPlayer files, I get the same error message. The serviio log entry is below. I would really appreciate some help.
2012-11-22 18:49:04,964 WARN [FeedUpdaterThread] Failed to retrieve online item information for rtmp://bbcmedia.fcod.llnwd.net:1935/ app=a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01p0cpj_1353327394.mp4,iplayerstream/secure_auth/400kbps/b01p0cpj_1353327385.mp4,iplayerstream/secure_auth/1500kbps/MP/b01p0cpj_1353327065.mp4,iplayerstream/secure_auth/480kbps/MP/b01p0cpj_1353327393.mp4&et=1353577458&fmta-token=b1f3e25546386aae3eaab34b496af84d48319f6005072e167538277b8f4226ee tcUrl=rtmp://bbcmedia.fcod.llnwd.net:1935/a1414/e3?as=adobe-hmac-sha256&av=1&te=connect&mp=iplayerstream/secure_auth/800kbps/MP/b01p0cpj_1353327394.mp4,iplayerstream/secure_auth/400kbps/b01p0cpj_1353327385.mp4,iplayerstream/secure_auth/1500kbps/MP/b01p0cpj_1353327065.mp4,iplayerstream/secure_auth/480kbps/MP/b01p0cpj_1353327393.mp4&et=1353577458&fmta-token=b1f3e25546386aae3eaab34b496af84d48319f6005072e167538277b8f4226ee playpath=mp4:iplayerstream/secure_auth/1500kbps/MP/b01p0cpj_1353327065.mp4 swfUrl=http://www.bbc.co.uk/emp/10player.swf swfVfy=1. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:291)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:382)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:86)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:124)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:268)
... 2 more
... 2 more
That url doesn't work for me either.
Either the BBC plugin has a bug, or the content has geographic restrictions. Are you in the uk? Does other BBC material work?
And what iPlayer feed URL are you using?
Petr
Help translate Serviio
I don't think it is a region coding issue, because I can get ITV player to work.
I have tried a couple of BBC RSS feeds, neither of which work. Here are the URL's:
http://feeds.bbc.co.uk/iplayer/highlights/tv
http://feeds.bbc.co.uk/iplayer/categories/drama/tv/list
hbradlow wrote:I don't think it is a region coding issue, because I can get ITV player to work.
But are you in UK? iPlayer definitely works only in UK.
Petr
Won't it work over a VPN?
It should AFAIK. But obviously FFmpeg can't get the file info, so not sure what the problem is.
Petr
Users browsing this forum: Google [Bot] and 46 guests
