Serviio server on WD My Book Live
miksa
Post Fri Nov 30, 2012 3:46 pm
Re: Serviio server on WD My Book Live
rajeshagarwal wrote:i can see Serviio on renderers but only the parent folder, no content or sub folders.
usually empty video folder means that video file type is not recognized by the client.
- Mike
rajeshagarwal
Post Fri Nov 30, 2012 4:03 pm
Miksa,
thx but these files are all working when I use Serviio from my mac. The library is not loading here.
rajeshagarwal
Post Fri Nov 30, 2012 4:38 pm
I sorted that out by using webUI. Things are finally working. However, I have a new problem. The subtitles aren't showing up. They do show when I run through a mac, but not when I run Serviio direct from my book.
Any help/advice will be greatly appreciated.
rajeshagarwal
Post Fri Nov 30, 2012 4:49 pm
tozevv wrote:After several attempts I was able to make serviio run with MyBook Live:
5. Install ibm java - it's a 1.6 version. Grab the 32bit IBM POWER Install anywere J2SE version from http://www.ibm.com/developerworks/java/jdk/linux/download.html
So far looks great. The box is fast enough to run it smoothly with subtitles, skip/ff and resume - all tested and working fine.
Keep up the good work with serviio :)
How does one grab the JAVA version? I am a newbie to ssh and don't know how to. I am using openjdk and am unable to get subtitles going. I don't know if it is the java or any other reason for this.
maxblue
Post Mon Dec 17, 2012 2:32 pm
If you are encountering this error message
dpkg: warning: files list file for package `ramlog' missing, assuming package has no files currently installed.
dpkg: warning: files list file for package `libparted0' missing, assuming package has no files currently installed.
(Reading database ... 22677 files and directories currently installed.)
Preparing to replace libc-bin 2.11.2-2 (using .../libc-bin_2.11.3-2_powerpc.deb) ...
Unpacking replacement libc-bin ...
dpkg: error processing /var/cache/apt/archives/libc-bin_2.11.3-2_powerpc.deb (--unpack):
trying to overwrite '/etc/ld.so.conf.d/libc.conf', which is also in package wd-lib 01.03.02-67335
Processing triggers for man-db ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Just run dpkg -i --force-all /var/cache/apt/archives/libc-bin_2.11.3-2_powerpc.deb
Then run apt-get -f install again
Keep on doing the above. Just replace the filename that is causing error. Until you are able to install ffmpeg.
beasteh
Post Sun Dec 23, 2012 2:12 pm
maxblue wrote:If you are encountering this error message
Hi maxblue, I have tried the above steps but instead I had to run:
dpkg -i --force-all /var/cache/apt/archives/libc-bin_2.11.3-4_powerpc.deb
Preparing to replace libc-bin 2.11.3-4 (using .../libc-bin_2.11.3-4_powerpc.deb) ...
Setting up libc-bin (2.11.3-4) ...
I then ran:
apt-get -f install
The following extra packages will be installed:
libc6
Suggested packages:
glibc-doc
The following packages will be upgraded:
libc6
1 upgraded, 0 newly installed, 0 to remove and 241 not upgraded.
1 not fully installed or removed.
Need to get 0B/4461kB of archives.
After this operation, 12.3kB of additional disk space will be used.
Do you want to continue [Y/n]? Y
Preconfiguring packages ...
(Reading database ... 22839 files and directories currently installed.)
Preparing to replace libc6 2.11.2-2 (using .../libc6_2.11.3-4_powerpc.deb) ...
Unpacking replacement libc6 ...
dpkg: error processing /var/cache/apt/archives/libc6_2.11.3-4_powerpc.deb (--unpack):
trying to overwrite '/etc/ld.so.conf.d/powerpc-linux-gnu.conf', which is also in package wd-lib 01.04.01-81092
Please could anyone assist further? I am a little unsure as to why this is happening.
My /etc/apt/sources.list:
deb http://ftp.us.debian.org/debian/ squeeze main
#deb http://ftp.us.debian.org/debian/ sid main
#deb http://ftp.us.debian.org/debian/ experimental main
deb http://deb-multimedia.org stable main
Thanks very much & Happy Christmas!
Leveltrauma
Post Sun Dec 23, 2012 11:33 pm
Hi there!
I want to say thanks for the great "WDTVLive" Guide - after 2 Days I get it running on "My Book World Edition 2"
I use debian-squeeze on it and for the Web Console I use "WebUI v1.3beta"
Actually I added the folders to scan - it is really slow ( maybe because of the Thumbnail creation I dunno )
I hope when the scan is finished I can use it like a charm
Leveltrauma
Post Mon Dec 24, 2012 8:35 am
Again Hello!
I checked the log files and get this warning, I think Serviio can't save the database or preferences.
2012-12-24 09:30:51,670 WARN [prefs] Could not lock User prefs. Unix error code 2.
2012-12-24 09:30:51,673 WARN [prefs] Couldn't flush user prefs: java.util.prefs.BackingStoreException: Couldn't get file lock.
Does anybody know how to fix this? I seached the web and only find that the user has no home dir or that java tried to write to a non writable folder
Thanks in advance!
maxblue
Post Tue Dec 25, 2012 12:49 pm
I then ran:
apt-get -f install
libc6
Suggested packages:
glibc-doc
libc6
Try running dpkg -i --force-all /var/cache/apt/archives/libc6_2.11.3-4_powerpc.deb
Then apt-get -f install again
busterdan
Post Fri Dec 28, 2012 10:25 am
Hi all.... I am a bit of a noob, so apologies in advance if I ask especially noobish questions....
Firstly thanks to Jazzman, Cerberus etc... I have been using the Wiki guide supplemented by the PDF that Double T put together.
I've got as far as the Java installation (Section 5)....
Having been asked..... twice "DO you want to continue" I selected "Y" but the log I have appears quite different to the log in Double T's PDF. I've noticed that two files failed...
/var/cache/apt/archives/openjdk-6-jdk_6b18-1.8.13-0+squeeze2_powerpc.deb
/var/cache/apt/archives/ttf-dejavu-extra_2.31-1_all.deb
Apparently because there is not enough space on the device?
I've since tried a few more commands to start again, but again no space....
Reading package lists... Error!
E: Unable to write mmap - msync (28 No space left on device)
E: The package lists or status file could not be parsed or opened.
WD:~# ln -sf /opt/bin/coreutils-dirname /usr/bin/dirname
WD:~# apt-get update
Get:1 http://ftp.us.debian.org squeeze Release.gpg [1672B]
Hit http://ftp.us.debian.org squeeze Release
Ign http://ftp.us.debian.org squeeze/main Packages/DiffIndex
Hit http://ftp.us.debian.org squeeze/main Packages
Fetched 1672B in 0s (2051B/s)
WD:~#
Any idea's please?.... are their any folders/logs that I perhaps need to purge? Reading through it appears I need to create a /tmp directory but I'm not sure how to do this or how it would affect the subsequent commands (naming and referencing) that I have to use?
Edit... A bit of a concern now is that since following the steps (upto the point of the Java install) that my MBL will now longer accept my password to access the web interface. :o
I've now managed to reset the password... using this thread (thought I would add the link in case anyone else has a similar issue) http://community.wdc.com/t5/My-Book-Liv ... 967/page/4
busterdan
Post Fri Dec 28, 2012 1:03 pm
Looks like I've bricke my MBL.... the factory reset that I mentioned above did work..... to an extent...
But it errored whenever I tried to set the password. Having closed my browser I was then unable to access the dashboard again and having not already re-enabled SSH I'm stuck! :cry:
Edit..... managed to debrick my MBL using this excellent guide... http://community.wdc.com/t5/My-Book-Liv ... lse#M12669
So will try again.... I am using an older firmware 02.11.09-053 (May 2012) now though...... fingers crossed. ;)
busterdan
Post Fri Dec 28, 2012 5:16 pm
I've now managed to get as far as the FFMPEG installation....
Basically this failed, I was mainly using Double T's instructions but have since started using JazzMan's guide...
I've updated the sources file with the entries from Double T's post viewtopic.php?p=53013#p53013 and then followed his instructions again, but all I get now are these lib errors.
MyBookLive:/usr/local/serviio/serviio-0.6.2/bin# apt-get install ffmpeg
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
ffmpeg: Depends: libavcodec52 (>= 5:0.7.13) but 4:0.5.1-3 is to be installed
Depends: libavdevice52 (>= 5:0.7.13) but 4:0.5.1-3 is to be installed
Depends: libavfilter1 (>= 5:0.7.13) but it is not going to be installed
Depends: libavformat52 (>= 5:0.7.13) but 4:0.5.1-3 is to be installed
Depends: libavutil50 (>= 5:0.7.13) but it is not going to be installed
Depends: libpostproc51 (>= 5:0.7.13) but 4:0.5.1-3 is to be installed
Depends: libswscale0 (>= 5:0.7.13) but 4:0.5.1-3 is to be installed
libc6-ppc64: Depends: libc6 (= 2.11.3-4) but 2.11.2-2 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Another attempt.... I'm well and truly stuck now....
MyBookLive:~# chown serviio -R /usr/local/serviio
MyBookLive:~# chmod 755 /etc/init.d/serviio
MyBookLive:~# update-rc.d serviio defaults
update-rc.d: warning: /etc/init.d/serviio missing LSB information
update-rc.d: see <http://wiki.debian.org/LSBInitScripts>
System startup links for /etc/init.d/serviio already exist.
MyBookLive:~# /etc/init.d/serviio status
/etc/default/serviiod: line 7: Update: command not found
MyBookLive:~# nano /etc/default/serviiod
MyBookLive:~# nano /etc/apt/sources.list
MyBookLive:~# apt-get update
Hit http://www.deb-multimedia.org stable Release.gpg
Hit http://www.deb-multimedia.org stable/main Packages/DiffIndex
MyBookLive:~# apt-get install --allow-unauthenticated debian-multimedia-keyring
E: Couldn't find package debian-multimedia-keyring
MyBookLive:~# Couldn't find package debian-multimedia-keyring
busterdan
Post Fri Dec 28, 2012 9:51 pm
Well I have spent just about all day on this now :/
After the problems with the bricked drive and initial install I decide to upgrage the MBL to the latest firmware.... that went fine...
I then followed DoubleT's install guide and everything went fine until the FFMPEG install.... what seems to be a common problem... and I can't get around it...
I carried on regardless.... the server is running and I can connect to it using the Serviio v - WebUI v 1.0 console... however an error message on the page states "WARNING: There is a version mismatch between Serviio and Web UI. There may be a loss of functionality." and if I try to make any changes or save the settings I get a Parse error....
Also...
ARGH!!!!! I must be so near and yet I am so far....
a_abhijit
Post Wed Jan 16, 2013 9:56 am
Firstly a Big Hello from a newbie :)
My WD MyBookLive (2TB) firmware verson is MyBookLive 02.32.06-006 : Core F/W
Has anyone successsfully tried installing serviio on this version ??
~Abhi
a_abhijit
Post Fri Jan 18, 2013 6:45 am
a_abhijit wrote:Firstly a Big Hello from a newbie :)
~Abhi
^^ Bump...any attempt?? any oberservation??
thor
Post Fri Feb 01, 2013 10:38 am
HI
Hope you can help as I am at wits end. I have tried using the forum plus other web resources for weeks to solve but am ready to admit defeat. If I can't get assistance then I am going to be forced to run serviio off my desktop, which I do not want to do.
I have a mybook live 2tb and have installed Serviio but it does not work.
Issues are as follows
1. serviio will not restart on it's own after a reboot.
2. Serviio manually started ./serviio.sh & command. Stops on it's own after an hour or so.
3. Serviio server is started from serviioweb not when serviio service is started.
4. Serviio cannot be seen from any of my devices and yet their ip addresses are picked up by serviio and one is actually registered as green on the device dashboard.
Here is my Java version
java version "1.6.0_18"
OpenJDK Runtime Environment (IcedTea6 1.8.13) (6b18-1.8.13-0+squeeze2)
OpenJDK Zero VM (build 14.0-b16, interpreted mode)
I have also uploaded serviio.log to help.
I look forward to hearing from you guys.
Thank you.
(39.45 KiB) Downloaded 948 times
busterdan
Post Fri Feb 01, 2013 10:45 am
Yeah I had to give up to....
Instead I just paid for Twonky..... and upgraded MBL 3TB running two Twonky instances on it.... It does the job but I do think Serviio is the better media server. Really wish someone much smarter than me would get it working.
busterdan
Post Tue Mar 19, 2013 10:49 pm
Hi again, I've been using the latest version of Twonky since my last message above.... it works but I don't like it.... I just want Serviio.
Having just upgraded my MBL to the latest firmware I though I'd try again... I can't even get Java installed this time...
/etc/apt$ apt-get install openjdk-6-jdk
Building dependency tree...
aptitude-common: Breaks: aptitude (< 0.6.8-1) but 0.4.11.11-1~lenny1 is to be installed
openjdk-6-jdk: Depends: openjdk-6-jre (= 6b27-1.12.4-1) but it is not going to be installed
Recommends: libxt-dev but it is not going to be installed
ARGH! so frustrating! :(
mpetcu
Post Mon Apr 08, 2013 12:57 pm
Hi guys !
After two days of searching and reading all posts on the WEB from every forum out there I got nowhere so I decided to think the problem for myself.
I figure out how to install serviio on WD My Book Live, I wanted to share the experience with everybody.
You can find all info here: WD My Book Live with Serviio
I'm a noob in Linux and I think everybody can follow the tutorial
I wanted to use the latest version of Serviio (1.2.1) but is not transcoding for some reason. If you don't want transcoding you can install the new version in the same way.
stooovie
Post Sat Apr 27, 2013 10:17 pm
Sorry, that doesn't work for me. Even with the correct firmware, I'm getting all sorts of errors:
-GPG errors (The following signatures couldn't be verified because the public key is not available)
-apt-get install --allow-unauthenticated debian-multimedia-keyring results in "not found"
-"Invalid record in the preferences file, no Package header"
and others...
