Re: Serviio server on WD My Book Live
rajeshagarwal wrote:i can see Serviio on renderers but only the parent folder, no content or sub folders.
usually empty video folder means that video file type is not recognized by the client.
tozevv wrote:After several attempts I was able to make serviio run with MyBook Live:
5. Install ibm java - it's a 1.6 version. Grab the 32bit IBM POWER Install anywere J2SE version from http://www.ibm.com/developerworks/java/jdk/linux/download.html
So far looks great. The box is fast enough to run it smoothly with subtitles, skip/ff and resume - all tested and working fine.
Keep up the good work with serviio
maxblue wrote:If you are encountering this error message
dpkg: warning: files list file for package `ramlog' missing, assuming package has no files currently installed.
dpkg: warning: files list file for package `libparted0' missing, assuming package has no files currently installed.
(Reading database ... 22677 files and directories currently installed.)
Preparing to replace libc-bin 2.11.2-2 (using .../libc-bin_2.11.3-2_powerpc.deb) ...
Unpacking replacement libc-bin ...
dpkg: error processing /var/cache/apt/archives/libc-bin_2.11.3-2_powerpc.deb (--unpack):
trying to overwrite '/etc/ld.so.conf.d/libc.conf', which is also in package wd-lib 01.03.02-67335
Processing triggers for man-db ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Just run dpkg -i --force-all /var/cache/apt/archives/libc-bin_2.11.3-2_powerpc.deb
Then run apt-get -f install again
Keep on doing the above. Just replace the filename that is causing error. Until you are able to install ffmpeg.
beasteh wrote:maxblue wrote:If you are encountering this error message
Hi maxblue, I have tried the above steps but instead I had to run:
dpkg -i --force-all /var/cache/apt/archives/libc-bin_2.11.3-4_powerpc.deb
Preparing to replace libc-bin 2.11.3-4 (using .../libc-bin_2.11.3-4_powerpc.deb) ...
Setting up libc-bin (2.11.3-4) ...
I then ran:
apt-get -f install
The following extra packages will be installed:
libc6
Suggested packages:
glibc-doc
The following packages will be upgraded:
libc6
1 upgraded, 0 newly installed, 0 to remove and 241 not upgraded.
1 not fully installed or removed.
Need to get 0B/4461kB of archives.
After this operation, 12.3kB of additional disk space will be used.
Do you want to continue [Y/n]? Y
Preconfiguring packages ...
(Reading database ... 22839 files and directories currently installed.)
Preparing to replace libc6 2.11.2-2 (using .../libc6_2.11.3-4_powerpc.deb) ...
Unpacking replacement libc6 ...
dpkg: error processing /var/cache/apt/archives/libc6_2.11.3-4_powerpc.deb (--unpack):
trying to overwrite '/etc/ld.so.conf.d/powerpc-linux-gnu.conf', which is also in package wd-lib 01.04.01-81092
Please could anyone assist further? I am a little unsure as to why this is happening.
My /etc/apt/sources.list:
deb http://ftp.us.debian.org/debian/ squeeze main
#deb http://ftp.us.debian.org/debian/ sid main
#deb http://ftp.us.debian.org/debian/ experimental main
deb http://deb-multimedia.org stable main
Thanks very much & Happy Christmas!
Reading package lists... Error!
E: Unable to write mmap - msync (28 No space left on device)
E: The package lists or status file could not be parsed or opened.
WD:~# ln -sf /opt/bin/coreutils-dirname /usr/bin/dirname
WD:~# apt-get update
Get:1 http://ftp.us.debian.org squeeze Release.gpg [1672B]
Hit http://ftp.us.debian.org squeeze Release
Ign http://ftp.us.debian.org squeeze/main Packages/DiffIndex
Hit http://ftp.us.debian.org squeeze/main Packages
Fetched 1672B in 0s (2051B/s)
WD:~#
MyBookLive:/usr/local/serviio/serviio-0.6.2/bin# apt-get install ffmpeg
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
ffmpeg: Depends: libavcodec52 (>= 5:0.7.13) but 4:0.5.1-3 is to be installed
Depends: libavdevice52 (>= 5:0.7.13) but 4:0.5.1-3 is to be installed
Depends: libavfilter1 (>= 5:0.7.13) but it is not going to be installed
Depends: libavformat52 (>= 5:0.7.13) but 4:0.5.1-3 is to be installed
Depends: libavutil50 (>= 5:0.7.13) but it is not going to be installed
Depends: libpostproc51 (>= 5:0.7.13) but 4:0.5.1-3 is to be installed
Depends: libswscale0 (>= 5:0.7.13) but 4:0.5.1-3 is to be installed
libc6-ppc64: Depends: libc6 (= 2.11.3-4) but 2.11.2-2 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
MyBookLive:~# chown serviio -R /usr/local/serviio
MyBookLive:~# chmod 755 /etc/init.d/serviio
MyBookLive:~# update-rc.d serviio defaults
update-rc.d: warning: /etc/init.d/serviio missing LSB information
update-rc.d: see <http://wiki.debian.org/LSBInitScripts>
System startup links for /etc/init.d/serviio already exist.
MyBookLive:~# /etc/init.d/serviio status
/etc/default/serviiod: line 7: Update: command not found
MyBookLive:~# nano /etc/default/serviiod
MyBookLive:~# nano /etc/apt/sources.list
MyBookLive:~# apt-get update
Hit http://www.deb-multimedia.org stable Release.gpg
Hit http://www.deb-multimedia.org stable/main Packages/DiffIndex
MyBookLive:~# apt-get install --allow-unauthenticated debian-multimedia-keyring
E: Couldn't find package debian-multimedia-keyring
MyBookLive:~# Couldn't find package debian-multimedia-keyring
a_abhijit wrote:Firstly a Big Hello from a newbie![]()
My WD MyBookLive (2TB) firmware verson is MyBookLive 02.32.06-006 : Core F/W
Has anyone successsfully tried installing serviio on this version ??
~Abhi
/etc/apt$ apt-get install openjdk-6-jdk
Building dependency tree...
aptitude-common: Breaks: aptitude (< 0.6.8-1) but 0.4.11.11-1~lenny1 is to be installed
openjdk-6-jdk: Depends: openjdk-6-jre (= 6b27-1.12.4-1) but it is not going to be installed
Recommends: libxt-dev but it is not going to be installed
