Playlist
• Page 1 of 1
Re: Playlist
Similar problem here.
Created an m3u playlist an added it to a folder. Folder is named "playlist" an i selcted it in serviio.
On my samsung TV it appears in the folder list but its empty.
How do i make my m3u playlist appear on my TV?
Re: Playlist
You can create a playlist using winamp or windows media player for example. Both types of lists are supported.
Re: Playlist
how about playlists on a mac?
Re: Playlist
Looks like you can save playlists as m3u in VLC
Petr
Help translate Serviio
Re: Playlist
Same here. Made playlist in Banshee (linux mint mediaplayer), since it can make list sorted by year. Not showing up in serviio? I've put i in my usual music folder, does it have to go in a separate playlist folder and get updated via console?
Re: Playlist
No, just store it in a shared audio folder. Check the log if there are any errors.
Petr
Re: Playlist
Firstly thanks for a great product, very simple, lightweight and robust.
Like others on this thread I cannot see my playlists. They are saved as M3U files under \My Playlists in a folder monitored by serviio.
I run WinAmp on Windows XP connected over HomePlug to my Yamaha RX-V473 AV Amp. The Yamaha detects the server and can select by album/artist/genre etc, and plays tracks nicely, but when I select playlists on the device it searches and returns 'no content'.
I can see the playlists on the Yamaha using windows media server, but this has several drawbacks over Serviio, so any help on getting Serviio to pick up the playlists would be welcome.
Re: Playlist
enable detailed log, add a new playlist and then post the log here
Petr
Re: Playlist
Thanks. Log file is 27MB, too big to post!
Re: Playlist
delete the log, restart your PC .. it should start from the beginning
Petr
Re: Playlist
I am having the same problem with winamp m3U files not showing up as playlists in serviio. I am running windows 7.
Any suggestions?
Any suggestions?
Re: Playlist
check the log to see if the playlist has been added / found
Petr
Re: Playlist
I have checked the log file and it makes no mention of the playlist folder or the m3u files in it?
Re: Playlist
is your playlist in one of your shared audio folders?
Petr
Re: Playlist
yes, I have tried it in both the main folder and playlists sub folder.
• Page 1 of 1
