Playlist
andihawes
Post Thu Dec 06, 2012 8:18 am
Playlist
Hi Forum,
how do i create a playlist to appear in the playlist folder on Serviio which my Samsung TV then sees?
Elgazore
Post Fri Dec 07, 2012 1:40 pm
Re: Playlist
Similar problem here.
Created an m3u playlist an added it to a folder. Folder is named "playlist" an i selcted it in serviio.
On my samsung TV it appears in the folder list but its empty.
How do i make my m3u playlist appear on my TV?
Elgazore
Post Sat Dec 08, 2012 1:45 pm
Re: Playlist
You can create a playlist using winamp or windows media player for example. Both types of lists are supported.
andihawes
Post Mon Dec 10, 2012 9:50 pm
Re: Playlist
how about playlists on a mac?
Post Wed Dec 12, 2012 12:35 pm
Re: Playlist
Looks like you can save playlists as m3u in VLC
phn2
Post Tue Dec 25, 2012 2:10 pm
Re: Playlist
Same here. Made playlist in Banshee (linux mint mediaplayer), since it can make list sorted by year. Not showing up in serviio? I've put i in my usual music folder, does it have to go in a separate playlist folder and get updated via console?
Post Tue Dec 25, 2012 10:59 pm
Re: Playlist
No, just store it in a shared audio folder. Check the log if there are any errors.
andrewmonk
Post Sat Dec 29, 2012 7:21 pm
Re: Playlist
Firstly thanks for a great product, very simple, lightweight and robust.
Like others on this thread I cannot see my playlists. They are saved as M3U files under \My Playlists in a folder monitored by serviio.
I run WinAmp on Windows XP connected over HomePlug to my Yamaha RX-V473 AV Amp. The Yamaha detects the server and can select by album/artist/genre etc, and plays tracks nicely, but when I select playlists on the device it searches and returns 'no content'.
I can see the playlists on the Yamaha using windows media server, but this has several drawbacks over Serviio, so any help on getting Serviio to pick up the playlists would be welcome.
Post Mon Dec 31, 2012 2:08 pm
Re: Playlist
enable detailed log, add a new playlist and then post the log here
andrewmonk
Post Wed Jan 02, 2013 5:18 pm
Re: Playlist
Thanks. Log file is 27MB, too big to post!
Post Wed Jan 02, 2013 10:04 pm
Re: Playlist
delete the log, restart your PC .. it should start from the beginning
japeski
Post Sat Aug 17, 2013 12:15 pm
Re: Playlist
I am having the same problem with winamp m3U files not showing up as playlists in serviio. I am running windows 7.
Any suggestions?
Post Sat Aug 17, 2013 7:26 pm
Re: Playlist
check the log to see if the playlist has been added / found
japeski
Post Sun Aug 18, 2013 11:06 am
Re: Playlist
I have checked the log file and it makes no mention of the playlist folder or the m3u files in it?
Post Sun Aug 18, 2013 11:41 am
Re: Playlist
is your playlist in one of your shared audio folders?
japeski
Post Sun Aug 18, 2013 9:26 pm
Re: Playlist
yes, I have tried it in both the main folder and playlists sub folder.
