Sony BDP S570
• Page 1 of 1
My blue ray player lost the media server. It was working fine but then just stopped. I think it has something to do with the bound ip. Initially it was set at 192.168.1.9. This ip disappeared. I am not sure how to bind it to an ip. Also, the console detects my Mac as a dlna renderer 192.168.1.2. I can make a static ip but I need the Mac address to do this. I am running serviio pro with mountain lion. Please help
Re: Sony BDP S570
bdid you try not to bind to any IP? It might work it out by itself.
If it doesn't work, static IP is alway a good idea. Mac address should be printed when you type
in your terminal
in your terminal
Petr
Help translate Serviio
Re: Sony BDP S570
Thanks for the reply Not binding doesn't work. How do I determine what ip to use? Or can I just pick one and assign? When I use the ifcongig. Is that the Mac address for the machine? Or does the media server generate its own?
Re: Sony BDP S570
post output of ifconfig
Petr
Re: Sony BDP S570
Below is the ifconfig data
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
options=3<RXCSUM,TXCSUM>
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
inet 127.0.0.1 netmask 0xff000000
inet6 ::1 prefixlen 128
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=27<RXCSUM,TXCSUM,VLAN_MTU,TSO4>
ether 60:fb:42:f2:4c:08
inet6 fe80::62fb:42ff:fef2:4c08%en0 prefixlen 64 scopeid 0x4
inet 192.168.1.2 netmask 0xffffff00 broadcast 192.168.1.255
media: autoselect (1000baseT <full-duplex,flow-control>)
status: active
en1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether d4:9a:20:58:5e:d2
inet6 fe80::d69a:20ff:fe58:5ed2%en1 prefixlen 64 scopeid 0x5
inet 169.254.110.108 netmask 0xffff0000 broadcast 169.254.255.255
media: autoselect
status: active
fw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 4078
lladdr 60:fb:42:ff:fe:f2:4c:08
media: autoselect <full-duplex>
status: inactive
p2p0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 2304
ether 06:9a:20:58:5e:d2
media: autoselect
status: active
utun0: flags=80d1<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1399
inet 129.49.183.109 --> 129.49.183.109 netmask 0xffffff80
inet6 fe80::62fb:42ff:fef2:4c08%utun0 prefixlen 64 scopeid 0x8
inet6 fe80::9a1e:be87:54c2:b15d%utun0 prefixlen 128 scopeid 0x8
status: active
media: autoselect
status: active
status: inactive
media: autoselect
status: active
Re: Sony BDP S570
This is what gets logged:
2012-12-15 16:09:53,023 ERROR [DiscoverySSDPMessageListener] Cannot open multicast socket,will try again
java.net.BindException: Address already in use
at java.net.PlainDatagramSocketImpl.bind0(Native Method)
at java.net.PlainDatagramSocketImpl.bind(PlainDatagramSocketImpl.java:91)
at java.net.DatagramSocket.bind(DatagramSocket.java:372)
at java.net.MulticastSocket.bind(MulticastSocket.java:162)
at java.net.MulticastSocket.<init>(MulticastSocket.java:147)
at java.net.MulticastSocket.<init>(MulticastSocket.java:112)
at org.serviio.util.MultiCastUtils.startMultiCastSocketForListening(MultiCastUtils.java:44)
at org.serviio.upnp.discovery.DiscoverySSDPMessageListener.run(DiscoverySSDPMessageListener.java:82)
at java.lang.Thread.run(Thread.java:680)
Re: Sony BDP S570
Got it to work again. Don't ask me how. It is now on a static ip. Hopefully when the leases expires it will still work. Anyone know how to prevent the expiration?
Re: Sony BDP S570
Bkube wrote:Anyone know how to prevent the expiration?
In DHCP server ... in router I mean.
Re: Sony BDP S570
Which setting in router. I set the ip to static, but I believe eventually it will expire.
Re: Sony BDP S570
Bkube wrote:Which setting in router. I set the ip to static, but I believe eventually it will expire.
Router dependant.
On my router, IP are fixed according to the MAC device address... so never change.
Re: Sony BDP S570
Well, it happened again. Server lost. The player is detected on the the console but no luck on the tv. I have a fixed ip that is entered into the server settings. I really don't get how it can be fine for days and then just crap out. Very frustrating. Any help would be appreciated. Thanks in advance
• Page 1 of 1
Users browsing this forum: Google [Bot] and 3 guests
