Subtitles not show on my new Panasonic TV TX-L32X50M
gczobel
Post Sat Dec 15, 2012 9:05 am
I bought a Panasonic TX-L32X50M and I have no luck trying to display subtitles on it.
These are the things that I know:
1. The TV can display mkv files without problem, and I can use external subtitles if I copied the two files (mkv, srt) on an usb stick.
2. Device Spy don't detect the TV. I tried to add manually the TV IP and I receive an error indicating that cannot connect.
3. I tried the 3 Panasonic profiles and the result its the same. Video is ok, but no subtitles.
4. One of my video mkv video files has soft subtitles merged on it. This file work ok and I can switch the subtitles on/off.
This is the info about the mkv file:
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame
 --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --ta
rget-os=mingw32 --cross-prefix=i686-w64-mingw32- --pkg-config=pkg-config
Input #0, matroska,webm, from 'M:\Downloads\Videos\Series\Arrow\Season 1\Arrow.S01E01.720p.HDTV.X264-DIMENSION [PublicHD]\Arrow.
S01E01.720p.HDTV.X264-DIMENSION.mkv':
    creation_time   : 2012-10-10 18:55:36
  Duration: 00:42:04.77, start: 0.000000, bitrate: 4908 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
    Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), s16, 384 kb/s (default)
Unique ID                                : 228519963209487536420738414459366074257 (0xABEB58109DBB3F9D9603B28E0996E791)
Complete name                            : M:\Downloads\Videos\Series\Arrow\Season 1\Arrow.S01E01.720p.HDTV.X264-DIMENSION [PublicHD]\Arrow.S01E01.720p.HDTV.X264-DIMENSION.mkv
File size                                : 1.44 GiB
Duration                                 : 42mn 4s
Overall bit rate                         : 4 909 Kbps
Encoded date                             : UTC 2012-10-10 18:55:36
Writing application                      : mkvmerge v3.1.0 ('Happy up here') built on Jan 19 2010 12:09:24
Writing library                          : libebml v0.7.9 + libmatroska v0.8.1
Format settings, ReFrames                : 8 frames
Duration                                 : 42mn 4s
Bit rate                                 : 4 427 Kbps
Bits/(Pixel*Frame)                       : 0.200
Stream size                              : 1.30 GiB (90%)
Writing library                          : x264 core 128 r2216 198a7ea
Encoding settings                        : cabac=1 / ref=8 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Duration                                 : 42mn 4s
Bit rate                                 : 384 Kbps
Stream size                              : 116 MiB (8%)
The serviio log and the srt file can be found here:
https://www.dropbox.com/sh/eeofrxh5l6twzf8/B3Cup-eM5H
I tried a lot of things... but it's always the same. The subtitles option on the TV don't show any subtitle.
Thanks in advance!
gczobel
Post Mon Dec 17, 2012 8:25 am
Re: Subtitles not show on my new Panasonic TV
Some updates...
1. The TV is connected using Homeplug (not wifi)
2. I checked the srt files and are ANSI files, and the names match ok.
3. Using Intel "AV Media Controller" I see the subtitle resource.
I understand from another threads that the TV need to open a new connection to ask for the srt file. That is correct? I don't see this request on the log.
4. From another threads I understand that the subtitle file will be the resource #2. In my case is the #3. This is a problem?
This are the AV Media controller screen for the file:
resource1
resource2
resource3
Post Tue Dec 18, 2012 9:23 pm
Looks ok to me. If the incoming requests use a Viera profile and don't ask for the srt resource, not much we can do. Maybe it doesn't srt for MKV files? Did you try it with an avi file?
gczobel
Post Fri Dec 21, 2012 11:58 am
I tried now. Subtitles are ok for avi files.
There's nothing to do for mkv files, right? (without reencoding the file, of course)
Post Tue Dec 25, 2012 10:58 am
Re: Subtitles not show on my new Panasonic TV TX-L32X50M
According to this post, they should. viewtopic.php?f=13&t=5119&start=70#p58211
But he might have a different model.
Return to Panasonic
