TC-P55ST30 aspect ratio issue
Vader76
Post Sat Dec 15, 2012 5:25 am
I have a few MKV files that are being stretched vertically. I can't seem to figure out how to have them not stretch during transcoding. I tried adding the DAR="16:9" to the profile but that didn't do anything.
With the same files, Mezzmo was able to display them properly with out the vertical stretch.
Is there anything else I can try?
Thanks...
Post Sat Dec 15, 2012 2:01 pm
Re: TC-P55ST30 aspect ratio issue
Try disabling transcoding in the console and play the mkv then.
Vader76
Post Sat Dec 15, 2012 9:03 pm
The tv says it can't read the file with transcoding turned off.
Post Sun Dec 16, 2012 8:54 am
Probably because the source is a not supported h264 resolution, and with serviio, h264 video will be remuxed in the same resolution. with mezzmo, video is probably transcode to mpeg2video with a good resolution.
When you add the DAR option, do you also force h264 video to be transcoded to mpeg2video ?
Could you provide information about this file ?
Vader76
Post Mon Dec 17, 2012 12:34 am
C:\Program Files\Serviio\lib>ffmpeg -i c:\videos\te2.mkv
g-config
Input #0, matroska,webm, from 'c:\videos\te2.mkv':
    creation_time   : 2012-12-03 02:16:22
  Duration: 01:42:42.00, start: 0.000000, bitrate: 4884 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x528 [SAR 1:1 DAR 80:33],
 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), s16, 768 kb/s (defa
ult)
This is what I did in the Panasonic profile
         <!-- Transcode h264 videos with profile level > 4.1 to mpegts with ac3 audio -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" forceInheritance="true" DAR="16:9">
Post Mon Dec 17, 2012 8:07 am
What is the h264 profile level of your c:\videos\te2.mkv' file? check with MediaInfo tool...
Vader76
Post Tue Dec 18, 2012 2:37 am
This is the profile level:
Format profile : High@L4.1
Format settings, ReFrames                : 8 frames
Muxing mode                              : Header stripping
Duration                                 : 1h 42mn
Bit rate                                 : 4 132 Kbps
Height                                   : 528 pixels
Display aspect ratio                     : 2.40:1
Bits/(Pixel*Frame)                       : 0.255
Stream size                              : 2.89 GiB (83%)
Writing library                          : x264 core 120
Encoding settings                        : cabac=1 / ref=8 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=2pass / mbtree=1 / bitrate=4132 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Post Tue Dec 18, 2012 6:52 am
With your file, this previous modification will have no impact, this is for level>4.1 file. yours = 4.1
Add this at the begening of your profile:
Vader76
Post Wed Dec 19, 2012 5:16 am
Thanks Illico! That did the trick.. I kept thinking that it meant >=4.1 :? :)
Dagg21
Post Mon Apr 29, 2013 12:08 pm
Can someone explain where exactly to add this entry in my profiles.xml. Does it replace whats there or maybe paste in a working file with this setting.
I tried a few file edits and serviio would not start so I had to back them out.
Thanks!
dangles
Post Mon Jul 08, 2013 3:16 am
That solved it for me...
I also have this issue with some .avi files (xvid i believe)... how could that additional line be modified to do the same for those?
thanks
Return to Panasonic
