Serviio stops playing after 30-45 minutes
• Page 1 of 1
After version 0.6 all 1.x versions just stop playing in the middle of the movie and goes to next file. My renderer is C series 8000 samsung and i had never had issues on 0.6 version
Re: Serviio stops playing after 30-45 minutes
Can you post detailed log of playing the same file on these two versions?
Petr
Help translate Serviio
Well i have to uninstall reinstall the versions of serviio but i'll give it a try
I initially had this problem with 1.0.1 under Windows 7, then I fixed it somehow.
I upgraded to Windows 8 and installed Serviio 1.1 and the problem came back.
I remembered though, when installing another DLNA server that it asks to disable the 'Windows Media Player Network Sharing Service' because it can cause problems during playback. So I disabled the service manually and tried Serviio 1.1 again, and now, I can play videos all day long on my Samsung without Serviio dropping out even once.
HTH
HTH
Thanks for the advice i will try it and post the results
I confirm that disabling the windows media player network share service makes serviio works just fine!!! Thanks a lot for the help
I'm glad it worked for you, now go forth and spread the word!
• Page 1 of 1
Users browsing this forum: Google [Bot] and 8 guests
