Serviio stops playing after 30-45 minutes
mastoul
Post Fri Jan 04, 2013 10:53 am
After version 0.6 all 1.x versions just stop playing in the middle of the movie and goes to next file. My renderer is C series 8000 samsung and i had never had issues on 0.6 version
Post Fri Jan 04, 2013 11:13 am
Re: Serviio stops playing after 30-45 minutes
Can you post detailed log of playing the same file on these two versions?
mastoul
Post Fri Jan 04, 2013 1:14 pm
Well i have to uninstall reinstall the versions of serviio but i'll give it a try
BoostSamurai
Post Sat Jan 05, 2013 2:26 am
I initially had this problem with 1.0.1 under Windows 7, then I fixed it somehow.
I upgraded to Windows 8 and installed Serviio 1.1 and the problem came back.
I remembered though, when installing another DLNA server that it asks to disable the 'Windows Media Player Network Sharing Service' because it can cause problems during playback. So I disabled the service manually and tried Serviio 1.1 again, and now, I can play videos all day long on my Samsung without Serviio dropping out even once.
HTH
mastoul
Post Wed Jan 09, 2013 10:20 am
Thanks for the advice i will try it and post the results
mastoul
Post Fri Jan 11, 2013 8:06 am
I confirm that disabling the windows media player network share service makes serviio works just fine!!! Thanks a lot for the help
BoostSamurai
Post Sat Jan 12, 2013 9:00 am
I'm glad it worked for you, now go forth and spread the word! :D
