Not sure where to start
nubbie
Post Sun Jan 06, 2013 7:24 am
I have been using the Serviio program for a few weeks without issue, was watching a movie tonight and suddenly had disconnects happening. Thought it was the wireless router so went to check on the desktop.
Currently I cannot login into the media browser as it states the password is incorrect and to try again. When I open the console the whole remote section is greyed out and I cannot make any changes. I did attempt to search this site for the answer but did not come up with anything.
Currently out of idea's other than un-installing this software as I can't access anything. Please provide any assistance you can.
Cheers
Nubbie.
nubbie
Post Sun Jan 06, 2013 7:33 am
Re: Not sure where to start
Just checking the log and came across this
2013-01-06 00:26:38,015 WARN [ServiioStatusService] AuthenticationException occured. Returning error code 401 to the REST layer. Message: null
Post Sun Jan 06, 2013 8:30 am
Are you using any third party consoles e.g. Web UI (PHP or AJAX), or apps e.g. ServiiDroid, or are you using the official console? Are you on Windows, Mac OSX or Linux?
Post Sun Jan 06, 2013 12:52 pm
Your evaluation Pro license probably expired. Check the license type in the About tab of your console.
rexton2006
Post Sat Dec 13, 2014 11:24 am
I have the same issue from windows 8.1 pro the remote tab the options are greyed out. I have a full pro licence registered
fachex
Post Wed Dec 24, 2014 3:01 pm
Did anybody solve this problem? I am having the same problem. I have a pro license. Windows 7 64bit and Serviio 1.4.1.2 and the Remote tab is grayed out..
Post Sun Dec 28, 2014 6:50 pm
Can you post your log file of the server startup? It should say what license you have.
Users browsing this forum: No registered users and 54 guests
