[SOLVED] sony bdp-495 no work avi
kilimnik
Post Sat Jan 05, 2013 7:44 pm
hello
I have a player sony bdp495
Avi files are not working ((
Profile enabled device
how to fix this problem?
sorry for my english
best regards
Post Sun Jan 06, 2013 3:03 pm
Re: sony bdp-495 no work avi
What is your region (US, CA, EU, etc) ?
Do you try to change profile on serviio console, for example "Sony Bravia 2012 US" or " Sony Bravia 2010" ?
kilimnik
Post Sun Jan 06, 2013 11:09 pm
Illico wrote:What is your region (US, CA, EU, etc) ?
region eu bdp495
tv 40nx720 -2011yer
profile is set correctly
TV works without problems
problem playing on a player bdp495 no work avi
Post Mon Jan 07, 2013 12:10 pm
I don't have a newest Son BDP device, so its difficult to me to help you on this, but according to patters its seems that newer ones will play Xvid but not DivX.
viewtopic.php?f=11&t=8612&p=60060#p60060
Could you provide information about your avi file (see my signature link) ?
If you force select "Sony Bravia 2012 US" profile for your BDP device on serviio console, avi will be transcoded, could you try this for a workarround ?
kilimnik
Post Mon Jan 07, 2013 1:31 pm
Format : AVI
File size : 1.37 GiB
Duration : 1h 35mn
Overall bit rate : 2 042 Kbps
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 35mn
Bit rate : 1 840 Kbps
Width : 720 pixels
Height : 400 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.267
Stream size : 1.23 GiB (90%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
http://www.sony.co.uk/product/blu-ray-d ... ations#tab
http://www.sony.ua/product/blu-ray-disc ... ystyky#tab
Post Mon Jan 07, 2013 2:09 pm
And what about the audio track ?
If you read the Readme topic:
- Owners of 2011 series players have reported issues with DivX/Xvid, so it's possible they have similar restrictions to 2011 Bravias in that regard. However, there were reports of the cause being a particular encoding setting in the MP3 audio stream (non-zero wBitsPerSample):
viewtopic.php?f=11&t=3399&p=22551&hilit=great#p22546
http://www.sony-europe.com/discussions/message/691986 (explains how to fix affected files)
The audio track could be the reason...
kilimnik
Post Mon Jan 07, 2013 10:20 pm
Illico wrote:And what about the audio track ?
Codec ID : XVID
Duration : 1h 35mn
Width : 720 pixels
Height : 400 pixels
Color space : YUV
Bit depth : 8 bits
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 1h 35mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 131 MiB (9%)
Alignment : Split accross interleaves
Interleave, duration : 42 ms (1.00 video frame)
Interleave, preload duration : 500 ms
sorry
kilimnik
Post Wed Jan 09, 2013 8:06 pm
I put the profile, as you advised
and a miracle happened)))
it worked
player bdp 495 works with a profile bravia 2011 us
big tnx
best regards
Post Thu Jan 10, 2013 8:40 am
kilimnik wrote:player bdp 495 works with a profile bravia 2011 us
You can select Sony Bravia 2011 US profile for avi file that does not work.
Its a workaround, we don't know why this file is not supported by the Sony device.
Enjoy it.
