[SOLVED] sony bdp-495 no work avi
I have a player sony bdp495
Avi files are not working ((
Profile enabled device
how to fix this problem?
sorry for my english
best regards
Illico wrote:What is your region (US, CA, EU, etc) ?
Do you try to change profile on serviio console, for example "Sony Bravia 2012 US" or " Sony Bravia 2010" ?
Format : AVI
File size : 1.37 GiB
Duration : 1h 35mn
Overall bit rate : 2 042 Kbps
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 35mn
Bit rate : 1 840 Kbps
Width : 720 pixels
Height : 400 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.267
Stream size : 1.23 GiB (90%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
- Owners of 2011 series players have reported issues with DivX/Xvid, so it's possible they have similar restrictions to 2011 Bravias in that regard. However, there were reports of the cause being a particular encoding setting in the MP3 audio stream (non-zero wBitsPerSample):
viewtopic.php?f=11&t=3399&p=22551&hilit=great#p22546
http://www.sony-europe.com/discussions/message/691986 (explains how to fix affected files)
Illico wrote:And what about the audio track ?
If you read the Readme topic:- Owners of 2011 series players have reported issues with DivX/Xvid, so it's possible they have similar restrictions to 2011 Bravias in that regard. However, there were reports of the cause being a particular encoding setting in the MP3 audio stream (non-zero wBitsPerSample):
The audio track could be the reason...
kilimnik wrote:player bdp 495 works with a profile bravia 2011 us
