trouble streaming (.ts file) to vizio tv
linen
Post Mon Jan 07, 2013 8:18 pm
Hello, I am new to serviio, but really like what I have seen so far! Thanks for the great work! Since I am so new to this, I am still learning the interface and how the system works...so please let me know what you might need if it is missing.
I have been experimenting with serviio (on a vista 32bit machine) and a dlna capable Vizio "smart" tv (Model#E320i) as a client. The serviio shows up as a server in the media app on the TV. I have been able to play some files on the TV, but not others. I am trying the "DirecTV HD-DVR" renderer profile per this thread: http://forum.serviio.org/viewtopic.php?f=7&t=8325. I have transcoding enabled.
I am not at home so I do not have the Device spy output yet for the TV, but can get that tonight if it would be useful.
I can also post logs if that is needed.
Here is the ffmpeg output and MediaInfo output of an example of something that does not play (and after it I have also included the same for something that does play):
C:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\Temp\Masterpiece Classic\Masterpi
ece Classic_20130106_20002200.ts "
g-config
[mpeg2video @ 0037CB00] mpeg_decode_postinit() failure
    Last message repeated 25 times
[mpegts @ 0037BDC0] PES packet size mismatch
    Last message repeated 1 times
Input #0, mpegts, from 'C:\Temp\Masterpiece Classic\Masterpiece Classic_20130106
_20002200.ts ':
  Duration: 02:02:49.71, start: 26073.735911, bitrate: 12622 kb/s
  Program 3
    Stream #0:0[0x31]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p
, 1920x1080 [SAR 1:1 DAR 16:9], 65000 kb/s, 38.24 fps, 29.97 tbr, 90k tbn, 59.94
 tbc
    Stream #0:1[0x34]: Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, 5.1(side)
, s16, 384 kb/s
    Stream #0:2[0x35]: Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo, s
16, 192 kb/s
Complete name                            : C:\Temp\Masterpiece Classic\Masterpiece Classic_20130106_20002200.ts
Format                                   : MPEG-TS
File size                                : 10.8 GiB
Duration                                 : 2h 2mn
Overall bit rate                         : 12.6 Mbps
Menu ID                                  : 3 (0x3)
Format                                   : MPEG Video
Format profile                           : Main@High
Format settings, BVOP                    : Yes
Format settings, Matrix                  : Custom
Format settings, GOP                     : Variable
Codec ID                                 : 2
Duration                                 : 2h 2mn
Bit rate                                 : 11.4 Mbps
Maximum bit rate                         : 65.0 Mbps
Height                                   : 1 080 pixels
Active Format Description                : Full frame 16:9 image
Frame rate                               : 29.970 fps
Scan type                                : Interlaced
Scan order                               : Top Field First
Bits/(Pixel*Frame)                       : 0.184
Stream size                              : 9.79 GiB (90%)
Audio #1
Menu ID                                  : 3 (0x3)
Codec ID                                 : 129
Duration                                 : 2h 2mn
Bit rate                                 : 384 Kbps
Delay relative to video                  : -492ms
Stream size                              : 337 MiB (3%)
Audio #2
Menu ID                                  : 3 (0x3)
Codec ID                                 : 129
Duration                                 : 2h 2mn
Bit rate                                 : 192 Kbps
Delay relative to video                  : -460ms
Stream size                              : 169 MiB (2%)
Text #1
ID                                       : 49 (0x31)-CC1
Menu ID                                  : 3 (0x3)
Format                                   : EIA-608
Muxing mode                              : A/53 / DTVCC Transport
Muxing mode, more info                   : Muxed in Video #1
Duration                                 : 2h 2mn
Stream size                              : 0.00 Byte (0%)
Text #2
Menu ID                                  : 3 (0x3)
Format                                   : EIA-708
Duration                                 : 2h 2mn
The one below does seem to play (although I am still not sure how "good" it plays):
C:\Program Files\Serviio\lib>ffmpeg.exe -i "E:\TVfiles\Worse Than War\Worse Than
 War_20100415_02000400.dvr-ms "
g-config
[mpeg2video @ 02946020] mpeg_decode_postinit() failure
    Last message repeated 13 times
Input #0, asf, from 'E:\TVfiles\Worse Than War\Worse Than War_20100415_02000400.
dvr-ms ':
    DVR Index Granularity: 500
    WMFSDKVersion   : 11.0.6001.7006
    WMFSDKNeeded    : 0.0.0.0000
    VBR Peak        : 15940.0000
    IsVBR           : 1
  Duration: 02:02:58.55, start: 1.063000, bitrate: 12155 kb/s
    Stream #0:0(eng): Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
    Stream #0:1(eng): Video: mpeg2video (Main) (DVR  / 0x20525644), yuv420p, 192
0x1080 [SAR 1:1 DAR 16:9], 65000 kb/s, 43.77 fps, 29.97 tbr, 1k tbn, 59.94 tbc
Complete name                            : E:\TVfiles\Worse Than War\Worse Than War_20100415_02000400.dvr-ms
Format                                   : Windows Media
File size                                : 10.4 GiB
Duration                                 : 2h 2mn
Overall bit rate                         : 12.2 Mbps
Maximum Overall bit rate                 : 160 Mbps
Encoded date                             : UTC 2010-04-15 06:59:00.335
Format                                   : MPEG Video
Format settings, GOP                     : M=3, N=30
Codec ID                                 : DVR
Codec ID/Hint                            : ASF
Duration                                 : 2h 2mn
Bit rate                                 : 11.9 Mbps
Frame rate mode                          : Variable
Nominal frame rate                       : 59.940 fps
Bits/(Pixel*Frame)                       : 0.191
Stream size                              : 10.2 GiB (98%)
Language                                 : English (US)
Thanks for the help!
Post Tue Jan 08, 2013 1:58 pm
Re: trouble streaming (.ts file) to vizio tv
try something like this:
 <Profile id="viziotv" name="Vizio TV" extendsProfileId="1">
            <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="mp2" maxVBitrate="8192" forceStereo="true" DAR="16:9">
                <Matches container="mp4" />
                <Matches container="asf" />
                <Matches container="avi" />
                <Matches container="ogg" />
                <Matches container="flv" />
                <Matches container="3gp" />
                <Matches container="rm" />
                <Matches container="mpegts" />
        <OnlineTranscoding>
            <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="mp2" maxVBitrate="8192" forceStereo="true">
                <Matches container="*" />
        </OnlineTranscoding>
linen
Post Tue Jan 08, 2013 2:31 pm
Thanks for the code zip! I will try it tonight.
I did try devicespy last night and the TV did not show up on the list. I also could not find it on dlna.org search, in fact there are no vizio devices listed there. I have found very little information anywhere (including directly on vizio's site) on what format and bitrates this TV can support...frustrating :?
linen
Post Wed Jan 09, 2013 4:47 am
Well the good news is the the file listed above that did not play, started playing with the above addition to the profile.xml. The not so good news is that after a few seconds it then stated stuttering, then froze. I looked at the server cpu usage and it was approaching/sometimes at 100 % with ffmpeg process using most of the resource. I am assuming the transcoding is bringing it to it's knees? The file I included above that did play previously, still plays but even then cpu usage hovers around 80%. My server is a core2 dual 1.86 Ghz. Is this a case of asking too much of my computer to handle the on the fly transcoding required to handle these high bitrate files?
Post Wed Jan 09, 2013 5:13 pm
try this:
            <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" DAR="16:9">
        <OnlineTranscoding>
and post detailed log of playing the file
linen
Post Wed Jan 09, 2013 7:06 pm
Thanks for the reply zip! I was wondering about ac3, verses the mp2 in the previous code. I will give that a try tonight and post my results and the log.
By the way, I have already enabled the DEBUG log option, and it is getting pretty big. Is it best to just zip it and attach to the post?
Post Thu Jan 10, 2013 12:11 am
yes
linen
Post Thu Jan 10, 2013 1:12 am
Nice job zip...that did it :D
ffmpeg ran around 20% and no stuttering on tv.
In case you are still interested I can add the logs, though my first try to attach the zip fill said it was too big (1.4 meg). Let me know.
Thanks again!
Post Thu Jan 10, 2013 5:21 pm
Is the TV supposed to play H264? Eg. can you play an MKV file with the Bravia 2012 profile?
linen
Post Fri Jan 11, 2013 2:52 am
I grabbed a mkv h264 and i played using the "Vizio TV" profile. I assume this means it actually worked on my TV with the "generic" profile?
I also tried the Bravia 2012 and Bravia 2012 (US) profiles and neither could play the mkv (or the ts) file.
Users browsing this forum: No registered users and 65 guests
