Can't get Serviio to work on Sony KDL-26ex550
vvp12
Post Wed Jan 16, 2013 1:30 pm
Hi all, i am new bee. i am trying to set up serviio on my sony bravia kdl-26ex550(2012 model), on my laptop the serviio consolle shows that i am connected but on tv its not appearing! can somone here help me out in this getting correct? i can stream media files through windows media player its working properly! also i am doing this through sonys wifi dongle so pls help me....
prioryjim
Post Wed Jan 16, 2013 1:39 pm
Re: Can't get Serviio to work on Sony KDL-26ex550
What's not showing on your Sony TV
Is it
1) - No Serviio icon appears ?
2) - Videos don't play ?
My Sony Bravia has a menu setting it's called "Server Diagnostics" as I remember.
This checks out the network for servers and test their capabilities.
It also shows you what, if anything, it thought was wrong. ( Options button ).
Perhaps your Sony is similar.
Jim
vvp12
Post Wed Jan 16, 2013 2:00 pm
i am not able to access serviio on my tv ! i also did server dignostic it shows that no servers found & tells me to check firewall on my pc! so i disabled it and again checked gives same message that no servers found! so pls help..
Post Thu Jan 17, 2013 10:32 am
On Sony menu, do you try to clear all server list and try to refresh ?
prioryjim
Post Thu Jan 17, 2013 12:26 pm
Also can you ping you TV from your laptop ?
vvp12
Post Fri Jan 18, 2013 7:20 am
@illico, i tried server refresh option also tried to update server list but no work! serviio still not showing up! the other merdia servers like twonky media are working properly! does serviio works only through router? as i i am using wifi dongle for this? i am really got stuck at this to get it work! :cry: need solution badly! :?
vvp12
Post Fri Jan 18, 2013 7:25 am
@ prioryjim i tried pinging my tvs ip address which is 192.168.246.102 showing results as follows
C:\Users\Vishal>ping -a 192.168.246.102
Pinging 192.168.246.102 with 32 bytes of data:
Reply from 192.168.246.102: bytes=32 time=4ms TTL=64
Reply from 192.168.246.102: bytes=32 time=2ms TTL=64
Reply from 192.168.246.102: bytes=32 time=5ms TTL=64
Reply from 192.168.246.102: bytes=32 time=6ms TTL=64
Ping statistics for 192.168.246.102:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 2ms, Maximum = 6ms, Average = 4ms
dont know whats going wrong? :roll:
prioryjim
Post Fri Jan 18, 2013 7:59 am
You could try switching windows firewall off for a test.
You do it in control panel.
Once off then try you TV again.
Don't forget to switch firewall back on again.
Jim
Post Fri Jan 18, 2013 8:35 am
Or a conflict with twonky media server...
