Library not Refreshing
vinyldj
Post Sun Feb 03, 2013 2:02 pm
Looked at other refresh posts for an answer but not luck.
Used Serviio 1.1 for a while and had better results with mkv/m2ts transcoding on the sony 2010 profile for both my tv's. Poor results on the 2011/12 profile with most formats - I don't see the sense in sending files native to a sony tv that causes too many problems.
My main issue with v1.1 was regular "temporarily cannot access the server" messages.
Went back to v0.6.2 which has been working fine and updating (as it always did) without error, but now since today my library will not refresh/update - ran through all the usual possible causes to this problem but no luck, my network is fine and serviio still streams to the tv's without error.
Can't understand what is causing the library not to update?
Any help appreciated. Can post log if it would help.
vinyldj
Post Fri Feb 08, 2013 9:15 am
Re: Library not Refreshing
Never mind just uninstalled app and removed serviio startup items from registry. Re-installed v0.6.2 after library set up all works fine again.
Would probably prefer to go to v1.1 pro so would like an explanation as to why v1.1 repeatedly gives a "temporarily cannot access server" message.
jagadish
Post Tue Feb 19, 2013 7:39 pm
I also tried to install pro 1.1 and it worked fine for few weeks, after that i am unable to see the server connected in my TV, even though the server is running in my laptop. Mine is Sony Bravia TV 2012 model, KDL46HX75G.
Please guide me how can i make this possible. Even if you want me to install the old version of serviio, its fine for me....
