Library not Refreshing
Looked at other refresh posts for an answer but not luck.
Used Serviio 1.1 for a while and had better results with mkv/m2ts transcoding on the sony 2010 profile for both my tv's. Poor results on the 2011/12 profile with most formats - I don't see the sense in sending files native to a sony tv that causes too many problems.
My main issue with v1.1 was regular "temporarily cannot access the server" messages.
Went back to v0.6.2 which has been working fine and updating (as it always did) without error, but now since today my library will not refresh/update - ran through all the usual possible causes to this problem but no luck, my network is fine and serviio still streams to the tv's without error.
Can't understand what is causing the library not to update?
Any help appreciated. Can post log if it would help.
