ffmpeg and map_channel
TKoos
Post Tue Feb 05, 2013 11:59 am
I've some old files from a video camera that I would like to rearrange the sound from.
Some files are mono with all sound from left speaker and some are in stereo. I would like to map all channels to the center instead, ie all sound should come in mono from the center. Is that possible?
I've lurked around some and found the -map_channel switch for ffmpeg, but I don't quite get how it's supposed to work.
Serviio 1.1 on Debian Wheezy
I'm glad for all help I can get. ;)
Post Thu Feb 07, 2013 10:55 pm
Re: ffmpeg and map_channel
You can't do that with Serviio. You should be able to do it offline with FFmpeg, but I'd ask at their mailing list / IRC.
