Temp folder
Wingsgb
Post Fri Jan 11, 2013 2:42 pm
Temp folder
Hi all,
I have just been doing some general maintenance on my server cleaning up files that never completed ect. I have noticed in the serviio temp folder there are 8files with a total size of nearly 16gb. To be honest the size isn't an issue, I am just wondering what these temp files are and if they should auto clear. I assume its for the transcoding.
Also I havnt been on the site in awhile, what with all the spam posts. Do you need help clearing them up.
khurram23
Post Fri Jan 11, 2013 3:49 pm
Re: Temp folder
Those temp files are created when a video is transcoded for a device that doesn't natively play it. There is no harm in deleting those files. They should automatically get removed when a request for new transcode comes in from same device or if you restart your serviio instance.
If you need space, shutdown serviio and re-start it. That should clear out those files. If that doesn't happen, shutdown serviio, remove the files manually, restart serviio.
Dropbox - Get 500MB bonus space.
My pre-compiled FFMPEG, X264 packages for Linux/Ubuntu - Dropbox
TKoos
Post Tue Feb 05, 2013 10:08 pm
Re: Temp folder
Where is this temp folder located? Might be a good thing to check it up once in a while.
khurram23
Post Tue Feb 05, 2013 10:15 pm
Re: Temp folder
Open up console and look under transcoding (i think) tab.
TKoos
Post Wed Feb 06, 2013 5:13 am
Re: Temp folder
Thanks, I will look there.
