Cannot find cover
rostaniani
Post Sat Feb 09, 2013 3:35 pm
Cannot find cover
Hi
I have Serviio 1.1 on Win8 PC
everything is so good but most cover arts are not set !
The file names are not the same as the movie title and there is some more characters on file names such as "720p" ! but Plex Media Server handles them so good.
Should I change the cover art source website ?
Thanks a lot :)
slyguy42o
Post Sat Feb 09, 2013 10:54 pm
Re: Cannot find cover
what option are you currently using under the metadata tab of your console?
rostaniani
Post Sun Feb 10, 2013 6:20 am
slyguy42o wrote:what option are you currently using under the metadata tab of your console?
The screenshot is attached
Servei Metadata options
serviio metadata.PNG (31.26 KiB) Viewed 12958 times
Post Sun Feb 10, 2013 12:28 pm
If you're talking about local poster, naming has to follow these rules (at the bottom): http://www.serviio.org/index.php?option ... icle&id=12
rostaniani
Post Sun Feb 10, 2013 6:13 pm
zip wrote:If you're talking about local poster, naming has to follow these rules (at the bottom): http://www.serviio.org/index.php?option ... icle&id=12
No , There is no local posters ... but no posters is found online too :)
Post Mon Feb 11, 2013 7:15 pm
Does your renderer support thumbnails for videos?
rostaniani
Post Tue Feb 12, 2013 7:20 am
zip wrote:Does your renderer support thumbnails for videos?
The thumbnails are created . But I need Cover Arts !
Just one of movies has cover that is local!
Post Sun Feb 17, 2013 3:48 pm
do the files actually get the metadata from the online DB? If you click on on of the videos in MediaBrowser, does it show Genre, Summary, etc?
rostaniani
Post Mon Feb 18, 2013 1:52 am
zip wrote:do the files actually get the metadata from the online DB? If you click on on of the videos in MediaBrowser, does it show Genre, Summary, etc?
Yes, The genre, ... are correct ! but images are not :(
Can I use another cover art server ? It seems that this server does not work for me!
Post Mon Feb 18, 2013 12:23 pm
try to remove one of the files, Force refresh, then add it again
and enable detailed logging before you do this, then zip the log up and post here
Users browsing this forum: Baidu [Spider], Google [Bot] and 14 guests
