How to Stream Your Windows PC Desktop
suldi15
Post Mon Feb 11, 2013 5:03 pm
i did not understand on how to do this and most of the time i add a live stream i can not view it on my tv. the link to on How to Stream Your Windows PC Desktop is http://wiki.serviio.org/doku.php?id=stream_pc so someone pls help me pls
Post Mon Feb 11, 2013 6:21 pm
Re: How to Stream Your Windows PC Desktop
Just follow the instructions in the wiki.
suldi15
Post Tue Feb 12, 2013 2:27 pm
i did not understand the part about .bat and the part how to add it on serviio
suldi15
Post Tue Feb 12, 2013 2:57 pm
it some one could clearly explain on how to make the bat file it will be helpful
Post Tue Feb 12, 2013 4:02 pm
This is very basic to using windows. If you search for "bat" you will find articles like:
http://www.ehow.com/how_2277553_write-b ... source=ask
The wiki has the text you need.
jimwoodward
Post Mon Sep 29, 2014 3:05 pm
jhb50 wrote:Just follow the instructions in the wiki.
where are the instructions?
where is (and what is): the wiki ?
i have the latest versions of serviio pro and also vlc installed
i would like step by step instructions on how to stream pc desktop to dlna tv
i can already play movies from pc on tv via serviio
thanks
