Will not play AVI AC3 files
Files were done on a Mac but I am running PC.
Can play sample files but not the larger Movie.
Any ideas?
rohan cannon wrote:Can play sample files but not the larger Movie.
Complete name : C:\Downloads\TV\House Of Lies\House.of.Lies.S01E05.HDTV.XviD-LOL.avi
Format : AVI
File size : 233 MiB
Duration : 28mn 43s
Overall bit rate : 1 135 Kbps
Writing application : transcode-1.0.6
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 28mn 43s
Bit rate : 993 Kbps
Width : 624 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.189
Stream size : 204 MiB (88%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 28mn 43s
Bit rate mode : Variable
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 26.5 MiB (11%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Writing library : LAME3.99r
Encoding settings : -m j -V 4 -q 3 -lowpass 17 --abr 128
C:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\Downloads\TV\House Of Lies\House.
of.Lies.S01E05.HDTV.XviD-LOL.avi"
g-config
[mpeg4 @ 003FC6C0] Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'C:\Downloads\TV\House Of Lies\House.of.Lies.S01E05.HDTV.Xvi
D-LOL.avi':
encoder : transcode-1.0.6
Duration: 00:28:43.80, start: 0.000000, bitrate: 1134 kb/s
Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv
420p, 624x352 [SAR 1:1 DAR 39:22], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, s16, 128 kb
/s
At least one output file must be specifiedGeneral
Unique ID : 192242003024002267836173469792539169464 (0x90A076886EA731CD939CEEAD08FED2B8)
Complete name : C:\Downloads\Music\Dr. Dre - I Need A Doctor (Feat. Eminem & Skylar Grey).mkv
Format : Matroska
Format version : Version 2
File size : 121 MiB
Duration : 7mn 36s
Overall bit rate : 2 216 Kbps
Encoded date : UTC 2011-02-25 01:48:49
Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') built on Oct 31 2010 21:52:48
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : V_MPEG4/ISO/AVC
Duration : 7mn 36s
Width : 1 280 pixels
Height : 720 pixels
Frame rate mode : Constant
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 7mn 36s
Sampling rate : 44.1 KHz
Default : Yes
Forced : No
C:\Program Files\Serviio\lib>ffmpeg.exe -i "C:\Downloads\Music\Dr. Dre - I Need
A Doctor (Feat. Eminem & Skylar Grey).mkv"
g-config
Input #0, matroska,webm, from 'C:\Downloads\Music\Dr. Dre - I Need A Doctor (Fea
t. Eminem & Skylar Grey).mkv':
creation_time : 2011-02-25 01:48:49
Duration: 00:07:36.41, start: 0.000000, bitrate: 2215 kb/s
Stream #0:0: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 23.98
fps, 23.98 tbr, 1k tbn, 48 tbc (default)
Stream #0:1: Audio: aac, 44100 Hz, stereo, s16 (default)
