Remux DTS
Encrypted
Post Mon Feb 11, 2013 2:20 am
Remux DTS
Hello, I am wondering if you can setup the stream to not transcode DTS to AC3. It seems to want to always transcode DTS to AC3 even though all of my equipment support DTS. I prefer to leave things in their native format if possible. Not only does this tax my media servers CPU for no reason, it degrades quality and often has sync issues.
Post Mon Feb 11, 2013 8:36 am
Re: Remux DTS
What is our device renderer?
What is the profile used on serviio console ?
What is your OS and ffmpeg version?
Post Mon Feb 11, 2013 1:12 pm
Re: Remux DTS
AFAIK FFmpeg has problems with muxing DTS in mpegts. That's some time ago, so it might be fixed in a recent FFmpeg version.
patters
Post Mon Feb 18, 2013 11:50 pm
Re: Remux DTS
This is a long standing unfixed issue with FFmpeg. I finally sat down nine whole months ago and carefully created some example samples and opened a ticket but no one has worked on it so far unfortunately:
https://ffmpeg.org/trac/ffmpeg/ticket/1398
Xmantium
Post Tue Feb 19, 2013 7:14 pm
Re: Remux DTS
With the new January, 7, 2013, FFmpeg v1.1
Its does say "DTS-HD demuxer"
Post Wed Feb 20, 2013 3:31 pm
Re: Remux DTS
@patters, could you double check if it's still a problem with the latest FFmpeg? I commented on the issue on FFmpeg tracker and they need confirmation.
patters
Post Wed Feb 20, 2013 9:04 pm
Re: Remux DTS
Checked just now. It's still an issue even with FFmpeg 1.1.1 - the audio is just silent when played back on Sony hardware.
Encrypted
Post Wed Feb 20, 2013 11:42 pm
Re: Remux DTS
okay. Too bad. Thanks for looking into this for me. Hopefully they fix it soon.
