[SOLVED] Greek Subtitles Sony Bravia Serviio 1.2
andreasvenios
Post Sat Mar 02, 2013 8:06 pm
Hi to all,
I have just downloaded the new serviio version 1.2. I can now see subtitles on my Sony Bravia but there must be a problem with Greek language. I cannot read anything. The characters are unreadable. Can you please look into it and advise?
Thanks,
Andreas.
Post Sun Mar 03, 2013 8:29 am
Re: Greek Subtitles Sony Bravia Serviio 1.2
What is the subtitle format, srt;ass files or embedded one ?
Does the subtitle is encoded in UTF-8 (see with notepad++ for example) ?
andreasvenios
Post Mon Mar 04, 2013 11:43 am
Dear Illico,
the file is an srt file and it is encoded in Ansi (I opened it in Notepad++). I changed the encoding in UTF-8 and now its working.
Thanks,
Andreas.
R3dBull
Post Sat Aug 03, 2013 11:31 pm
Re: [SOLVED] Greek Subtitles Sony Bravia Serviio 1.2
Hello noob here :-) I can see the subs but cant read them as the above user said. I my face an encoded problem but the point is I dont know how to change that, how to use UTF-8 to make them readable. I would greatly appreciate if you can help me.
Thank you in advance
Post Sun Aug 04, 2013 8:45 am
Open your srt subtitle file with advanced text editor like Notepad++, change the encoding to UTF-8, then save the file.
R3dBull
Post Sun Aug 04, 2013 10:20 am
hello, it still doesnt work on me.
lets take them from the beginning. I download a movie with its separate greek srt file from internet. In order to check subs, I play the movie with vlc player where I drop the srt file to check sync. I tested my last movie that it was playing fine with vlc with greek subs. After that, I run notepad++. From inprogram I pressed open and I choose the srt file I want to change encode. I went to toolbar to "encoding" and the bullet was in "Encode in ANSI". I then choose the below line says "encode in UTF-8". There is another option says "encode in UTF-8 without BOM". After choosing the encode I press save icon on notepad++ and I exit the program. I then add selected folder with movie and new encoding srt to Serviio console (Library->shared folders) and ticked the "share video file" and the "Retrieve descriptive metadata" boxes. I went to my tv (sony kdl55hx920) and I tried to play the movie but the subs were still in mess!. I opened the new srt file with notepad++ and I saw that the subs were unreadable also.
Don't know what to do next...
thank you
Post Sun Aug 04, 2013 11:52 am
R3dBull wrote:Don't know what to do next...
Don't know too...could you post your srt file here ?
R3dBull
Post Sun Aug 04, 2013 12:15 pm
Just uploaded the srt file. Just delete .doc from the file name I cant uploada file ending with.srt
Thank you.
One.Day.2011.BRRip.XviD.AC3-ZmN.srt.doc
srt file
(108.31 KiB) Downloaded 678 times
Post Thu Aug 08, 2013 11:52 am
I don't know how Greek subtitles should be displayed, but do you try with NotePad++ to change the character encoding to cp1253 (Windows 1253).
Then on serviio console subtitle tab set the character encoding shield with the same cp1253 value.
00:01:09,000 --> 00:01:18,000
<i><b>*Απόδοση διαλόγων G. V*</b></i>
2
00:01:19,851 --> 00:01:22,800
15 Ιουλίου 2006
3
00:01:30,083 --> 00:01:31,960
15  Ιουλίου 1988
4
00:01:44,000 --> 00:01:49,963
<b>ΜΙΑ ΗΜΕΡΑ</b>
5
00:03:05,120 --> 00:03:06,314
<i>Γεια σας, παιδιά.</i>
