LG BP620 won't connect
This started under 1.1. I upgraded to the new release (it came out the day after the problem started) and it still didn't work. I did a clean reinstall with everything set to factory settings, and nothing. The BR player can connect to XBMC fine (just tried it, it brings up the file tree virtually instantly).
I scanned through the debug log, and the only error is unrelated (the initial connection after the PC is turned on - it tries again and succeeds).
.148 is the computer running serviio
.138 is the BP620
This is where serviio found the device:
2013-03-03 18:41:05,213 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2013-03-03 18:41:05,218 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.148:62049s
2013-03-03 18:41:05,219 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.148:62049s
2013-03-03 18:41:05,223 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.138:2870/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-03-03 18:41:05,223 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 140479c0-58f3-1cef-84bf-944444859f28 from address /192.168.1.138:2870
2013-03-03 18:41:05,237 DEBUG [RendererManager] Adding renderer Renderer [uuid=140479c0-58f3-1cef-84bf-944444859f28, ipAddress=192.168.1.138, name=LG PLAYER, profileId=8, manuallyAdded=false, forcedProfile=true, enabled=true, accessGroupId=1] to list of active renderers
2013-03-03 18:41:05,269 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.138:2870/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-03-03 18:41:05,269 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 140479c0-58f3-1cef-84bf-944444859f28 from address /192.168.1.138:2870
2013-03-03 18:41:05,304 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net3 (D-Link DWA-125 Wireless N 150 USB Adapter(rev.A2)) and address 192.168.1.148, timeout = 0
2013-03-03 18:41:05,305 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device d080b72f-ce73-36ff-bb4d-5a3811b70c0a
2013-03-03 18:41:05,320 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.138:2870/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-03-03 18:41:05,320 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 140479c0-58f3-1cef-84bf-944444859f28 from address /192.168.1.138:2870
2013-03-03 18:41:05,924 DEBUG [WebServer] Incoming connection from /192.168.1.138:41498
2013-03-03 18:41:05,925 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.138
2013-03-03 18:41:05,931 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device d080b72f-ce73-36ff-bb4d-5a3811b70c0a from 192.168.1.138 (headers = [HOST: 192.168.1.148:8895,DATE: Sun, 03 Mar 2013 23:41:20 GMT,CONNECTION: Keep-Alive,USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50])
2013-03-03 18:41:05,931 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.138
2013-03-03 18:41:05,931 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.148:8895,DATE: Sun, 03 Mar 2013 23:41:20 GMT,CONNECTION: Keep-Alive,USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50]
2013-03-03 18:41:05,932 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.138
2013-03-03 18:41:06,047 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'LG TV / player'
2013-03-03 18:41:06,060 DEBUG [WebServer] Incoming connection from /192.168.1.138:41499
2013-03-03 18:41:06,063 DEBUG [WebServer] Incoming connection from /192.168.1.138:41500
2013-03-03 18:41:06,068 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.138
2013-03-03 18:41:06,069 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ConnectionManager
2013-03-03 18:41:06,069 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=3cd7396b-cf95-48b4-b67a-8df1c3bb535b) for service urn:upnp-org:serviceId:ConnectionManager reporting to http://192.168.1.138:13000/
2013-03-03 18:41:06,075 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.138
2013-03-03 18:41:06,075 DEBUG [WebServer] Incoming connection from /192.168.1.138:41501
2013-03-03 18:41:06,075 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2013-03-03 18:41:06,075 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=d6d2ad5d-4c7b-44f1-9451-8fe2b87b4a3e) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://192.168.1.138:13000/
2013-03-03 18:41:06,077 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.138
2013-03-03 18:41:06,077 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service X_MS_MediaReceiverRegistrar
2013-03-03 18:41:06,077 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=3f325a29-e776-4055-a7dc-200ebbc69f41) for service urn:microsoft.com:serviceId:X_MS_MediaReceiverRegistrar reporting to http://192.168.1.138:13000/
2013-03-03 18:41:06,186 DEBUG [EventDispatcher] Sending event notification #0 for subscription d6d2ad5d-4c7b-44f1-9451-8fe2b87b4a3e to endpoint http://192.168.1.138:13000/
2013-03-03 18:41:06,193 DEBUG [RequestExecutor] Sending HTTP request to 192.168.1.138:13000
2013-03-03 18:41:06,200 DEBUG [EventDispatcher] Event notification sent and received successfully
2013-03-03 18:41:06,200 DEBUG [EventDispatcher] Sending event notification #0 for subscription 3cd7396b-cf95-48b4-b67a-8df1c3bb535b to endpoint http://192.168.1.138:13000/
2013-03-03 18:41:06,200 DEBUG [RequestExecutor] Sending HTTP request to 192.168.1.138:13000
2013-03-03 18:41:06,213 DEBUG [EventDispatcher] Event notification sent and received successfully
2013-03-03 18:41:06,396 DEBUG [WebServer] Incoming connection from /192.168.1.138:41502
2013-03-03 18:41:06,396 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.138
2013-03-03 18:41:06,397 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2013-03-03 18:41:07,105 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2013-03-03 18:41:10,186 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 18:41:10,187 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 18:41:10,188 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 18:41:10,188 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 18:41:10,193 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 18:41:10,194 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 18:41:11,214 DEBUG [RendererSearchSender] Finished searching for Renderer devices
When trying to connect, the log loops the following:
2013-03-03 19:04:40,261 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 19:04:40,261 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 19:04:40,263 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 19:04:40,263 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 19:04:40,265 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 19:04:40,265 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 19:05:10,262 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 19:05:10,263 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 19:05:10,264 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 19:05:10,265 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 19:05:10,267 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 19:05:10,267 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 19:05:26,516 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
Any ideas? I'd be happy to post the entire log if you like. I switched from xbmc to serviio two months ago - I'd hate to have to switch back.
