LG BP620 won't connect
kai
Post Mon Mar 04, 2013 12:37 am
A couple days ago, my LG BR player stopped being able to connect to Serviio: everybody sees everyone alright, and nothing has changed. The BR player's profile was set to "LG TV / player", but I tested generic too. Previously it worked fine under both. The green light is lit up. When I choose Serviio from the device list I get a never ending spinning wheel.
This started under 1.1. I upgraded to the new release (it came out the day after the problem started) and it still didn't work. I did a clean reinstall with everything set to factory settings, and nothing. The BR player can connect to XBMC fine (just tried it, it brings up the file tree virtually instantly).
I scanned through the debug log, and the only error is unrelated (the initial connection after the PC is turned on - it tries again and succeeds).
.148 is the computer running serviio
.138 is the BP620
This is where serviio found the device:
2013-03-03 18:41:05,213 DEBUG [RendererSearchSender] Sending 1 'm-search' messages
2013-03-03 18:41:05,218 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.148:62049s
2013-03-03 18:41:05,219 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.148:62049s
2013-03-03 18:41:05,223 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.138:2870/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-03-03 18:41:05,223 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 140479c0-58f3-1cef-84bf-944444859f28 from address /192.168.1.138:2870
2013-03-03 18:41:05,237 DEBUG [RendererManager] Adding renderer Renderer [uuid=140479c0-58f3-1cef-84bf-944444859f28, ipAddress=192.168.1.138, name=LG PLAYER, profileId=8, manuallyAdded=false, forcedProfile=true, enabled=true, accessGroupId=1] to list of active renderers
2013-03-03 18:41:05,269 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.138:2870/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-03-03 18:41:05,269 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 140479c0-58f3-1cef-84bf-944444859f28 from address /192.168.1.138:2870
2013-03-03 18:41:05,304 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface net3 (D-Link DWA-125 Wireless N 150 USB Adapter(rev.A2)) and address 192.168.1.148, timeout = 0
2013-03-03 18:41:05,305 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device d080b72f-ce73-36ff-bb4d-5a3811b70c0a
2013-03-03 18:41:05,320 DEBUG [RendererSearchSender] Received search response: location: http://192.168.1.138:2870/dmr.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2013-03-03 18:41:05,320 DEBUG [RendererSearchSender] Received a valid M-SEARCH response from Renderer 140479c0-58f3-1cef-84bf-944444859f28 from address /192.168.1.138:2870
2013-03-03 18:41:05,924 DEBUG [WebServer] Incoming connection from /192.168.1.138:41498
2013-03-03 18:41:05,925 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.138
2013-03-03 18:41:05,931 DEBUG [DeviceDescriptionRequestHandler] DeviceDescription request received for device d080b72f-ce73-36ff-bb4d-5a3811b70c0a from 192.168.1.138 (headers = [HOST: 192.168.1.148:8895,DATE: Sun, 03 Mar 2013 23:41:20 GMT,CONNECTION: Keep-Alive,USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50])
2013-03-03 18:41:05,931 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.138
2013-03-03 18:41:05,931 DEBUG [RendererManager] Looking for a renderer profile for Http headers: [HOST: 192.168.1.148:8895,DATE: Sun, 03 Mar 2013 23:41:20 GMT,CONNECTION: Keep-Alive,USER-AGENT: IPI/1.0 UPnP/1.0 DLNADOC/1.50]
2013-03-03 18:41:05,932 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.138
2013-03-03 18:41:06,047 DEBUG [DeviceDescriptionRequestHandler] Sending DeviceDescription XML back using profile 'LG TV / player'
2013-03-03 18:41:06,060 DEBUG [WebServer] Incoming connection from /192.168.1.138:41499
2013-03-03 18:41:06,063 DEBUG [WebServer] Incoming connection from /192.168.1.138:41500
2013-03-03 18:41:06,068 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.138
2013-03-03 18:41:06,069 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ConnectionManager
2013-03-03 18:41:06,069 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=3cd7396b-cf95-48b4-b67a-8df1c3bb535b) for service urn:upnp-org:serviceId:ConnectionManager reporting to http://192.168.1.138:13000/
2013-03-03 18:41:06,075 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.138
2013-03-03 18:41:06,075 DEBUG [WebServer] Incoming connection from /192.168.1.138:41501
2013-03-03 18:41:06,075 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service ContentDirectory
2013-03-03 18:41:06,075 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=d6d2ad5d-4c7b-44f1-9451-8fe2b87b4a3e) for service urn:upnp-org:serviceId:ContentDirectory reporting to http://192.168.1.138:13000/
2013-03-03 18:41:06,077 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.138
2013-03-03 18:41:06,077 DEBUG [ServiceEventSubscriptionRequestHandler] ServiceEvent subscription request received for service X_MS_MediaReceiverRegistrar
2013-03-03 18:41:06,077 DEBUG [ServiceEventSubscriptionRequestHandler] Event subscription registered (uuid=3f325a29-e776-4055-a7dc-200ebbc69f41) for service urn:microsoft.com:serviceId:X_MS_MediaReceiverRegistrar reporting to http://192.168.1.138:13000/
2013-03-03 18:41:06,186 DEBUG [EventDispatcher] Sending event notification #0 for subscription d6d2ad5d-4c7b-44f1-9451-8fe2b87b4a3e to endpoint http://192.168.1.138:13000/
2013-03-03 18:41:06,193 DEBUG [RequestExecutor] Sending HTTP request to 192.168.1.138:13000
2013-03-03 18:41:06,200 DEBUG [EventDispatcher] Event notification sent and received successfully
2013-03-03 18:41:06,200 DEBUG [EventDispatcher] Sending event notification #0 for subscription 3cd7396b-cf95-48b4-b67a-8df1c3bb535b to endpoint http://192.168.1.138:13000/
2013-03-03 18:41:06,200 DEBUG [RequestExecutor] Sending HTTP request to 192.168.1.138:13000
2013-03-03 18:41:06,213 DEBUG [EventDispatcher] Event notification sent and received successfully
2013-03-03 18:41:06,396 DEBUG [WebServer] Incoming connection from /192.168.1.138:41502
2013-03-03 18:41:06,396 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.138
2013-03-03 18:41:06,397 DEBUG [UPnPIconRequestHandler] UPnP icon request received for icon smallPNG
2013-03-03 18:41:07,105 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2013-03-03 18:41:10,186 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 18:41:10,187 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 18:41:10,188 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 18:41:10,188 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 18:41:10,193 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 18:41:10,194 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 18:41:11,214 DEBUG [RendererSearchSender] Finished searching for Renderer devices
When trying to connect, the log loops the following:
2013-03-03 19:04:40,261 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 19:04:40,261 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 19:04:40,263 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 19:04:40,263 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 19:04:40,265 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 19:04:40,265 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 19:05:10,262 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 19:05:10,263 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 19:05:10,264 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 19:05:10,265 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 19:05:10,267 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.1.138:59000s
2013-03-03 19:05:10,267 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.1.138:59000
2013-03-03 19:05:26,516 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
Any ideas? I'd be happy to post the entire log if you like. I switched from xbmc to serviio two months ago - I'd hate to have to switch back.
Post Mon Mar 04, 2013 5:44 pm
Re: LG BP620 won't connect
There is no incoming request from the player when you browse. It connects to get Serviio's description (so firewall is ok), but after that nothing. Not sure if it's the player failing to make a connection of something on your network preventing it.
Zync
Post Wed Mar 13, 2013 10:36 pm
I have the same DVD player and same issue. It started about the same time. Did you found out a solution? I was not able to make XMBC to work properly with the DVD player. Serviio was working perfectly.
At the moment, I can start the movies using iMediashare on my iPad. This is not the most practical solution though, just a workaround.
Zync
Post Wed Mar 13, 2013 11:47 pm
I saw on another thread that 1.1 should work. I then uninstall 1.2 and reinstall 1.1. This is now working fine. I'll wait on 1.2.1 before moving up again.
Post Wed Mar 13, 2013 11:54 pm
Zync wrote:I saw on another thread that 1.1 should work. I then uninstall 1.2 and reinstall 1.1. This is now working fine. I'll wait on 1.2.1 before moving up again.
I don't think there are any/much LG betatesters, so i doubt it'll be fixed in 1.2.1. PM me if you'd like to try the latest beta.
Return to LG
