[SOLVED] Missing files?
cruisinfanatic
Post Fri Mar 08, 2013 12:00 am
Got Serviio 1.2 installed and it recognizes my Sony DVD player fine. I go to shared folders, add local and drop in the file with the movies and tv shows that I want to see on my tv via DVD player. All checked marked. My DVD player sees Serviio in the video options ok. I go to folders and media (the name of the folder) on the DVD and see some of the shows (blank folders) but says there is no playable file. Same with opening series. Says no playable files. What am I missing?
Thanks, Mike
slyguy42o
Post Fri Mar 08, 2013 3:05 pm
Re: Missing files?
what profile are you using for your device?
cruisinfanatic
Post Fri Mar 08, 2013 3:09 pm
Re: Missing files?
slyguy42o wrote:what profile are you using for your device?
not sure what you mean. Thought I was reasonably computer savy, but not with this.
I've tried streaming with both Windows Media and VLC
Post Fri Mar 08, 2013 3:14 pm
Re: Missing files?
What is your Sony DVD player model name ?
cruisinfanatic
Post Fri Mar 08, 2013 3:45 pm
Re: Missing files?
Illico wrote:What is your Sony DVD player model name ?
BDP-BX37
Post Fri Mar 08, 2013 4:48 pm
Re: Missing files?
cruisinfanatic wrote:BDP-BX37
This model was DLNA certified on 2010.
Could you open Serviio console, on status tab, look at renderer profile, you should see your Sony device with a 2012 profile selected ("Sony BDP-Sx90 (2012)").
Change the profile to "Sony BDP-Sx70 (2010)" and save.
cruisinfanatic
Post Fri Mar 08, 2013 5:16 pm
Re: Missing files?
done,
And it's working now. Thought it would be something simple.
Thanks so much!!!!
cruisinfanatic
Post Mon Mar 18, 2013 7:02 pm
Re: Missing files?
I did what you said and most of the movies showed up as playable, but not some of the TV series I have. Found someone else here that had similar issue and they switched to Sony Bravia TV (2012) - US.
This worked perfectly as every movie and TV series was there to play.
Now this morning I go to watch one of the TV series and almost all of them are gone although the folders are still there (says no playable file)
Stumped again
Post Mon Mar 18, 2013 7:14 pm
Re: [SOLVED] Missing files?
Give your TV a static IP address on your router to keep the selected profile assigned to the device over time.
cruisinfanatic
Post Mon Mar 18, 2013 8:05 pm
zip wrote:Give your TV a static IP address on your router to keep the selected profile assigned to the device over time.
the tv is not on the internet, only the sony bdp-bx37. Not sue how to find the IP
I set router to static IP, no change
Don't understand why half my files that would play yesterday all of a sudden won't
Post Mon Mar 18, 2013 9:53 pm
because the TV probably changed IP address and defaulted to a different profile than what you chose yesterday.
cruisinfanatic
Post Mon Mar 18, 2013 10:29 pm
zip wrote:because the TV probably changed IP address and defaulted to a different profile than what you chose yesterday.
The TV is not hooked up to the internet. The Bluray is. The IP for it didn't change.
Why would some content show and not others. I'd think it would either work or not for everything.
Would uninstalling and reinstall be of any benefit in your opinion. Don't know what else to try.
Thanks for your help, Mike
Post Tue Mar 19, 2013 8:17 pm
Post detailed log of browsing to a folder with missing items
cruisinfanatic
Post Wed Mar 20, 2013 11:36 am
zip wrote:Post detailed log of browsing to a folder with missing items
I ended up uninstalling and reinstalling. Working as of now, thanks
