[SOLVED] Missing files?
Thanks, Mike
slyguy42o wrote:what profile are you using for your device?
Illico wrote:What is your Sony DVD player model name ?
cruisinfanatic wrote:BDP-BX37
Illico wrote:cruisinfanatic wrote:BDP-BX37
This model was DLNA certified on 2010.
Could you open Serviio console, on status tab, look at renderer profile, you should see your Sony device with a 2012 profile selected ("Sony BDP-Sx90 (2012)").
Change the profile to "Sony BDP-Sx70 (2010)" and save.
zip wrote:Give your TV a static IP address on your router to keep the selected profile assigned to the device over time.
zip wrote:because the TV probably changed IP address and defaulted to a different profile than what you chose yesterday.
zip wrote:Post detailed log of browsing to a folder with missing items
