unable to play subtitles on xbox 360
• Page 1 of 1
When i play and mkv file with embedded subtitles it plays as normal without any subtitles and even when i extract the subtitle and name both files the same and try this i get the unplayable content error message on xbox, is the xbox not supported in terms of subtitles, I have all subtitles optioned enabled on the console.
Re: unable to play subtitles on xbox 360
it should work, post detailed log of playing the file
Petr
Help translate Serviio
2013-03-09 00:55:27,401 DEBUG [WebServer] Incoming connection from /192.168.1.4:64807
2013-03-09 00:55:27,401 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-03-09 00:55:27,402 DEBUG [ResourceTransportRequestHandler] GET /resource/72104/MEDIA_ITEM/WMVHIGH_FULL-0/ORIGINAL HTTP/1.1, headers = [User-Agent: Xenon,Connection: Keep-alive,Host: 192.168.1.7:8895]]
2013-03-09 00:55:27,402 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-03-09 00:55:27,403 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:55:27,404 DEBUG [ResourceDeliveryProcessor] Request for resource 72104 and type 'MEDIA_ITEM' received
2013-03-09 00:55:27,404 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 72104 (local)
2013-03-09 00:55:27,405 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 72104, format WMVHIGH_FULL and profile Xbox 360
2013-03-09 00:55:27,407 DEBUG [SubtitlesService] Found external subtitle file: C:\Users\Jojo\Downloads\Bakuman_S3_-_12.ass
2013-03-09 00:55:27,409 DEBUG [SubtitlesService] Found external subtitle file: C:\Users\Jojo\Downloads\Bakuman_S3_-_12.ass
2013-03-09 00:55:27,409 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Bakuman_S3_-_12.mp4
2013-03-09 00:55:27,410 DEBUG [SubtitlesService] Found external subtitle file: C:\Users\Jojo\Downloads\Bakuman_S3_-_12.ass
2013-03-09 00:55:27,411 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Bakuman_S3_-_12.mp4: WMVHIGH_FULL
2013-03-09 00:55:27,411 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 72104 (local)
2013-03-09 00:55:27,412 DEBUG [VideoDeliveryEngine] Delivering item '72104' for client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:55:27,413 DEBUG [SubtitlesService] Found external subtitle file: C:\Users\Jojo\Downloads\Bakuman_S3_-_12.ass
2013-03-09 00:55:27,414 DEBUG [SubtitlesService] Found external subtitle file: C:\Users\Jojo\Downloads\Bakuman_S3_-_12.ass
2013-03-09 00:55:27,414 DEBUG [VideoDeliveryEngine] Delivering file 'Bakuman_S3_-_12.mp4' using transcoding
2013-03-09 00:55:27,416 DEBUG [SubtitlesService] Found external subtitle file: C:\Users\Jojo\Downloads\Bakuman_S3_-_12.ass
2013-03-09 00:55:27,416 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:55:27,417 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:131)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:100)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:120)
at org.serviio.delivery.GETMethodProcessor.retrieveResource(GETMethodProcessor.java:120)
at org.serviio.delivery.GETMethodProcessor.buildDeliveryContainer(GETMethodProcessor.java:48)
at org.serviio.delivery.AbstractMethodProcessor.handleRequest(AbstractMethodProcessor.java:132)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:80)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
this is for when i get the unplayable content message on xbox
and this when i try to play it with embedded subtitles, it plays normally but no subtitles
2013-03-09 00:58:43,685 DEBUG [WebServer] Incoming connection from /192.168.1.4:39378
2013-03-09 00:58:43,685 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-03-09 00:58:43,685 DEBUG [ResourceTransportRequestHandler] GET /resource/72081/MEDIA_ITEM/WMVHIGH_FULL-0/ORIGINAL HTTP/1.1, headers = [User-Agent: Xenon,Connection: Keep-alive,Host: 192.168.1.7:8895]]
2013-03-09 00:58:43,685 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:58:43,685 DEBUG [ResourceDeliveryProcessor] Request for resource 72081 and type 'MEDIA_ITEM' received
2013-03-09 00:58:43,685 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 72081 (local)
2013-03-09 00:58:43,685 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 72081, format WMVHIGH_FULL and profile Xbox 360
2013-03-09 00:58:43,685 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv
2013-03-09 00:58:43,685 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv: WMVHIGH_FULL
2013-03-09 00:58:43,685 DEBUG [VideoDeliveryEngine] Delivering item '72081' for client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:58:43,685 DEBUG [VideoDeliveryEngine] Delivering file '[SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv' using transcoding
2013-03-09 00:58:43,685 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-72104-3-ORIGINAL-be969d11cf8840d90dbebec118c7a386.stf', will stop the job
2013-03-09 00:58:43,685 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-72104-3-ORIGINAL-be969d11cf8840d90dbebec118c7a386.stf'
2013-03-09 00:58:43,701 DEBUG [TranscodingJobListener] Deleted temp file 'C:\Users\Jojo\Downloads\Serviio\transcoding-temp-72104-3-ORIGINAL-be969d11cf8840d90dbebec118c7a386.stf': true
2013-03-09 00:58:43,701 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:58:43,701 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: C:\Users\Jojo\Downloads\[SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv
2013-03-09 00:58:43,701 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -threads 2 -i C:\Users\Jojo\Downloads\[SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv -y -c:v wmv2 -b:v 15360k -maxrate:v 15360k -bufsize:v 15360k -r 24000/1001 -g 15 -c:a wmav2 -b:a 192k -ac 2 -map 0:0 -map 0:1 -sn -f asf C:\Users\Jojo\Downloads\Serviio\transcoding-temp-72081-3-ORIGINAL.stf
2013-03-09 00:58:44,777 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-03-09 00:58:44,793 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv: WMVHIGH_FULL
2013-03-09 00:58:44,808 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-03-09 00:58:44,808 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-03-09 00:58:44,808 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-03-09 00:58:44,808 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-ms-wmv,Date: Sat, 09 Mar 2013 00:58:44 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-03-09 00:58:46,883 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-03-09 00:58:47,008 DEBUG [WebServer] Incoming connection from /192.168.1.4:61724
2013-03-09 00:58:47,024 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-03-09 00:58:47,024 DEBUG [ResourceTransportRequestHandler] GET /resource/72081/MEDIA_ITEM/WMVHIGH_FULL-0/ORIGINAL HTTP/1.1, headers = [User-Agent: Xenon,Connection: Keep-alive,Host: 192.168.1.7:8895]]
2013-03-09 00:58:47,024 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:58:47,024 DEBUG [ResourceDeliveryProcessor] Request for resource 72081 and type 'MEDIA_ITEM' received
2013-03-09 00:58:47,024 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 72081 (local)
2013-03-09 00:58:47,024 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 72081, format WMVHIGH_FULL and profile Xbox 360
2013-03-09 00:58:47,024 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv
2013-03-09 00:58:47,024 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv: WMVHIGH_FULL
2013-03-09 00:58:47,039 DEBUG [VideoDeliveryEngine] Delivering item '72081' for client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:58:47,039 DEBUG [VideoDeliveryEngine] Delivering file '[SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv' using transcoding
2013-03-09 00:58:47,039 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:58:47,039 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-03-09 00:58:47,039 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv: WMVHIGH_FULL
2013-03-09 00:58:47,039 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-03-09 00:58:47,039 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-03-09 00:58:47,039 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-03-09 00:58:47,039 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-ms-wmv,Date: Sat, 09 Mar 2013 00:58:47 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-03-09 00:59:07,974 DEBUG [WebServer] Incoming connection from /192.168.1.4:58529
kiyoheha wrote:and this when i try to play it with embedded subtitles, it plays normally but no subtitles
Do you check "enable extract embedded subtitles" on serviio console ?
Do you set a preferred langage for subtitles extraction ?
With embedded it only means Serviio will try to extract them from the file, not send the file with embedded subtitles.
For XBox, you have to enable hardsubs (burn-in)
Petr
Illico wrote:kiyoheha wrote:and this when i try to play it with embedded subtitles, it plays normally but no subtitlesC:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -threads 2 -i C:\Users\Jojo\Downloads\[SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv -y -c:v wmv2 -b:v 15360k -maxrate:v 15360k -bufsize:v 15360k -r 24000/1001 -g 15 -c:a wmav2 -b:a 192k -ac 2 -map 0:0 -map 0:1 -sn -f asf C:\Users\Jojo\Downloads\Serviio\transcoding-temp-72081-3-ORIGINAL.stf
Yes on both questions, do i have to have the burn in option checked only?
i am still having the same issues, no matter which subtitle options i use, whether i have all of them selected or either one selected and i have tried this other files
can you post the whole log (zip it up and attach)
Petr
Were you able to resolve this issue. I am wondering because I am having the same problem as the original poster. I extract the files give the .ass file the same name as my mkv file and it won't play the video anymore.
There were problem with File name that used special char like [], could you remove them, refresh library and retry ?
I just tried that. Got the same results. Just to be sure. On the serviio console I should Have all three options in Subtitles checked off correct?
Also could I be having problems because of the codecs I'm using. (CCCP and FFdshow)...could it be a Windows8 problem too?
zip wrote:For XBox, you have to enable hardsubs (burn-in)
Ok that is what I had. I'll have to try it out again when I get home from work.
that's strange, I have everything but hard subs enabled on my server and the 360 displays subs for me. I just watched a movie last night that was an mp4 with an SRT file and it worked great.
Yeah I thinking about re-installing windows8 when i get home from work in a few hours and retrying then. Wish me luck, I post with updates if that works.
• Page 1 of 1
