unable to play subtitles on xbox 360
kiyoheha
Post Fri Mar 08, 2013 8:40 pm
When i play and mkv file with embedded subtitles it plays as normal without any subtitles and even when i extract the subtitle and name both files the same and try this i get the unplayable content error message on xbox, is the xbox not supported in terms of subtitles, I have all subtitles optioned enabled on the console.
Post Fri Mar 08, 2013 9:45 pm
Re: unable to play subtitles on xbox 360
it should work, post detailed log of playing the file
kiyoheha
Post Sat Mar 09, 2013 12:57 am
2013-03-09 00:55:27,401 DEBUG [WebServer] Incoming connection from /192.168.1.4:64807
2013-03-09 00:55:27,401 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-03-09 00:55:27,402 DEBUG [ResourceTransportRequestHandler] GET /resource/72104/MEDIA_ITEM/WMVHIGH_FULL-0/ORIGINAL HTTP/1.1, headers = [User-Agent: Xenon,Connection: Keep-alive,Host: 192.168.1.7:8895]]
2013-03-09 00:55:27,402 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-03-09 00:55:27,403 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:55:27,404 DEBUG [ResourceDeliveryProcessor] Request for resource 72104 and type 'MEDIA_ITEM' received
2013-03-09 00:55:27,404 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 72104 (local)
2013-03-09 00:55:27,405 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 72104, format WMVHIGH_FULL and profile Xbox 360
2013-03-09 00:55:27,407 DEBUG [SubtitlesService] Found external subtitle file: C:\Users\Jojo\Downloads\Bakuman_S3_-_12.ass
2013-03-09 00:55:27,409 DEBUG [SubtitlesService] Found external subtitle file: C:\Users\Jojo\Downloads\Bakuman_S3_-_12.ass
2013-03-09 00:55:27,409 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Bakuman_S3_-_12.mp4
2013-03-09 00:55:27,410 DEBUG [SubtitlesService] Found external subtitle file: C:\Users\Jojo\Downloads\Bakuman_S3_-_12.ass
2013-03-09 00:55:27,411 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Bakuman_S3_-_12.mp4: WMVHIGH_FULL
2013-03-09 00:55:27,411 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 72104 (local)
2013-03-09 00:55:27,412 DEBUG [VideoDeliveryEngine] Delivering item '72104' for client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:55:27,413 DEBUG [SubtitlesService] Found external subtitle file: C:\Users\Jojo\Downloads\Bakuman_S3_-_12.ass
2013-03-09 00:55:27,414 DEBUG [SubtitlesService] Found external subtitle file: C:\Users\Jojo\Downloads\Bakuman_S3_-_12.ass
2013-03-09 00:55:27,414 DEBUG [VideoDeliveryEngine] Delivering file 'Bakuman_S3_-_12.mp4' using transcoding
2013-03-09 00:55:27,416 DEBUG [SubtitlesService] Found external subtitle file: C:\Users\Jojo\Downloads\Bakuman_S3_-_12.ass
2013-03-09 00:55:27,416 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:55:27,417 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:131)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:100)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:120)
at org.serviio.delivery.GETMethodProcessor.retrieveResource(GETMethodProcessor.java:120)
at org.serviio.delivery.GETMethodProcessor.buildDeliveryContainer(GETMethodProcessor.java:48)
at org.serviio.delivery.AbstractMethodProcessor.handleRequest(AbstractMethodProcessor.java:132)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:80)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
this is for when i get the unplayable content message on xbox
kiyoheha
Post Sat Mar 09, 2013 1:02 am
and this when i try to play it with embedded subtitles, it plays normally but no subtitles
2013-03-09 00:58:43,685 DEBUG [WebServer] Incoming connection from /192.168.1.4:39378
2013-03-09 00:58:43,685 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-03-09 00:58:43,685 DEBUG [ResourceTransportRequestHandler] GET /resource/72081/MEDIA_ITEM/WMVHIGH_FULL-0/ORIGINAL HTTP/1.1, headers = [User-Agent: Xenon,Connection: Keep-alive,Host: 192.168.1.7:8895]]
2013-03-09 00:58:43,685 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:58:43,685 DEBUG [ResourceDeliveryProcessor] Request for resource 72081 and type 'MEDIA_ITEM' received
2013-03-09 00:58:43,685 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 72081 (local)
2013-03-09 00:58:43,685 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 72081, format WMVHIGH_FULL and profile Xbox 360
2013-03-09 00:58:43,685 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv
2013-03-09 00:58:43,685 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv: WMVHIGH_FULL
2013-03-09 00:58:43,685 DEBUG [VideoDeliveryEngine] Delivering item '72081' for client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:58:43,685 DEBUG [VideoDeliveryEngine] Delivering file '[SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv' using transcoding
2013-03-09 00:58:43,685 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-72104-3-ORIGINAL-be969d11cf8840d90dbebec118c7a386.stf', will stop the job
2013-03-09 00:58:43,685 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-72104-3-ORIGINAL-be969d11cf8840d90dbebec118c7a386.stf'
2013-03-09 00:58:43,701 DEBUG [TranscodingJobListener] Deleted temp file 'C:\Users\Jojo\Downloads\Serviio\transcoding-temp-72104-3-ORIGINAL-be969d11cf8840d90dbebec118c7a386.stf': true
2013-03-09 00:58:43,701 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:58:43,701 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: C:\Users\Jojo\Downloads\[SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv
2013-03-09 00:58:43,701 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -threads 2 -i C:\Users\Jojo\Downloads\[SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv -y -c:v wmv2 -b:v 15360k -maxrate:v 15360k -bufsize:v 15360k -r 24000/1001 -g 15 -c:a wmav2 -b:a 192k -ac 2 -map 0:0 -map 0:1 -sn -f asf C:\Users\Jojo\Downloads\Serviio\transcoding-temp-72081-3-ORIGINAL.stf
2013-03-09 00:58:44,777 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-03-09 00:58:44,793 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv: WMVHIGH_FULL
2013-03-09 00:58:44,808 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-03-09 00:58:44,808 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-03-09 00:58:44,808 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-03-09 00:58:44,808 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-ms-wmv,Date: Sat, 09 Mar 2013 00:58:44 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-03-09 00:58:46,883 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2013-03-09 00:58:47,008 DEBUG [WebServer] Incoming connection from /192.168.1.4:61724
2013-03-09 00:58:47,024 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.4
2013-03-09 00:58:47,024 DEBUG [ResourceTransportRequestHandler] GET /resource/72081/MEDIA_ITEM/WMVHIGH_FULL-0/ORIGINAL HTTP/1.1, headers = [User-Agent: Xenon,Connection: Keep-alive,Host: 192.168.1.7:8895]]
2013-03-09 00:58:47,024 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:58:47,024 DEBUG [ResourceDeliveryProcessor] Request for resource 72081 and type 'MEDIA_ITEM' received
2013-03-09 00:58:47,024 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 72081 (local)
2013-03-09 00:58:47,024 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 72081, format WMVHIGH_FULL and profile Xbox 360
2013-03-09 00:58:47,024 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file [SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv
2013-03-09 00:58:47,024 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv: WMVHIGH_FULL
2013-03-09 00:58:47,039 DEBUG [VideoDeliveryEngine] Delivering item '72081' for client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:58:47,039 DEBUG [VideoDeliveryEngine] Delivering file '[SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv' using transcoding
2013-03-09 00:58:47,039 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.4, Profile=Xbox 360'
2013-03-09 00:58:47,039 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-03-09 00:58:47,039 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file [SFW-sage]_Bakuman_S3_-_12_[720p][D07C91FC].mkv: WMVHIGH_FULL
2013-03-09 00:58:47,039 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-03-09 00:58:47,039 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2013-03-09 00:58:47,039 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2013-03-09 00:58:47,039 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-ms-wmv,Date: Sat, 09 Mar 2013 00:58:47 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.2,Cache-control: no-cache,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2013-03-09 00:59:07,974 DEBUG [WebServer] Incoming connection from /192.168.1.4:58529
Post Sat Mar 09, 2013 9:32 am
kiyoheha wrote:and this when i try to play it with embedded subtitles, it plays normally but no subtitles
Do you check "enable extract embedded subtitles" on serviio console ?
Do you set a preferred langage for subtitles extraction ?
Post Sat Mar 09, 2013 12:05 pm
With embedded it only means Serviio will try to extract them from the file, not send the file with embedded subtitles.
For XBox, you have to enable hardsubs (burn-in)
kiyoheha
Post Sat Mar 09, 2013 8:23 pm
Yes on both questions, do i have to have the burn in option checked only?
kiyoheha
Post Sun Mar 10, 2013 3:00 am
i am still having the same issues, no matter which subtitle options i use, whether i have all of them selected or either one selected and i have tried this other files
Post Sun Mar 10, 2013 12:07 pm
can you post the whole log (zip it up and attach)
Muchan
Post Fri Mar 29, 2013 6:36 am
Were you able to resolve this issue. I am wondering because I am having the same problem as the original poster. I extract the files give the .ass file the same name as my mkv file and it won't play the video anymore.
Muchan
Post Fri Mar 29, 2013 7:21 am
Here is my log if this can help in any way.
serviiolog.rar
(4.33 KiB) Downloaded 357 times
Post Fri Mar 29, 2013 8:02 am
There were problem with File name that used special char like [], could you remove them, refresh library and retry ?
Muchan
Post Fri Mar 29, 2013 8:58 am
I just tried that. Got the same results. Just to be sure. On the serviio console I should Have all three options in Subtitles checked off correct?
Also could I be having problems because of the codecs I'm using. (CCCP and FFdshow)...could it be a Windows8 problem too?
Post Fri Mar 29, 2013 9:20 am
zip wrote:For XBox, you have to enable hardsubs (burn-in)
Muchan
Post Fri Mar 29, 2013 9:53 am
Ok that is what I had. I'll have to try it out again when I get home from work.
slyguy42o
Post Fri Mar 29, 2013 2:28 pm
that's strange, I have everything but hard subs enabled on my server and the 360 displays subs for me. I just watched a movie last night that was an mp4 with an SRT file and it worked great.
Muchan
Post Fri Mar 29, 2013 10:06 pm
Yeah I thinking about re-installing windows8 when i get home from work in a few hours and retrying then. Wish me luck, I post with updates if that works.
