Sat Apr 20, 2013 1:45 pm by _SDK_
Hi Zip,
Thanks for the reply.
Been busy w/ work.
UPDATE: As of 13/04/20
I have Serviio working (including plugins) after the recent JAVA update.
However, I still have to hard quit Serviio to shut down any of my Macs, and, the Serviio Icon still shows in the dock intermittently.
When it disappears, I have to go into Activity Monitor to force quit. All my computers run 24 hours a day so that is not too much of a problem for me.
My clients however, shut down and start up daily. They are not all computer savvy. This bug will continue to be a problem for them.
I am also facing another problem now to having plugins working... It may need to be restarted as another thread but I will post here (for now) for recommendations.
When running Serviio 1.2 / MacOS 10.8.3 using the WDTV media player I now get speedy, showing of plugin links on the WDTV menu but, when I try to access them, I get the message:
"Unable to play the selected file. Please see the user manual for a list of supported file formats"
It is happening with 3 versions of WDTV and different WDTV firmware versions. Before Serviio 1.2 and / or Mac OS 10.8.3 they all played plugins perfectly. It is occurring on different home networks that are unchanged in connection scheme since all was working perfectly.
I am unsure what has changed to cause the problem and do not know what I should check next.
Thanks to everyone who has tried to help :-)
Regards,
Steve
- Attachments
- Serviio icon in dock disappears
- dock.jpg (57.13 KiB) Viewed 13142 times
- Mac failed to shutdown
- failed.jpg (68.59 KiB) Viewed 13142 times
