No Audio on Oppo BDP 83 with MKV
sdlehman
Post Wed Mar 13, 2013 9:19 pm
I have been trying to play MKV with my Oppo BDP 83 over my network. I get the video but no audio. The same file will play over the network on my Panasonic BDP220 so although it is not fluid since the computer has to convert the video to something the Panasonic can understand. I have been trying to read and learn as much as I can as I am new to this but just can't seem to figure out how to make this work. Anyone have any suggestions?
Stace
probedb
Post Thu Mar 14, 2013 8:34 am
Re: No Audio on Oppo BDP 83 with MKV
What format are the audio tracks?
Might be worth posting the output from MediaInfo as documented here viewtopic.php?f=5&t=4510
sdlehman
Post Thu Mar 14, 2013 12:13 pm
Thank you for the reply. I believe the audio is 6 channel ac3. Below is the output from MediaInfo
Unique ID                                : 44482597239690732123757437391120474065 (0x2177095ECD24FF70A4EF439915E19FD1)
Complete name                            : H:\Video\THE_MUMMY\_t00.mkv
File size                                : 15.8 GiB
Duration                                 : 2h 4mn
Overall bit rate                         : 18.2 Mbps
Encoded date                             : UTC 2013-03-11 20:49:30
Writing application                      : MakeMKV v1.8.0 win(x86-release)
Writing library                          : libmakemkv v1.8.0 (1.2.0/1.1.0) win(x86-release)
Format                                   : VC-1
Format profile                           : Advanced@L3
Codec ID                                 : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint                            : Microsoft
Bit rate                                 : 16.3 Mbps
Height                                   : 1 080 pixels
Frame rate mode                          : Variable
Original frame rate                      : 29.970 fps
Scan order                               : Top Field First
Format                                   : E-AC-3
Codec ID                                 : A_EAC3
Duration                                 : 2h 4mn
Bit rate                                 : 1 536 Kbps
Delay relative to video                  : 2ms
Stream size                              : 1.34 GiB (8%)
Title                                    : 3/2+1
Text
Format                                   : VobSub
Codec ID                                 : S_VOBSUB
Codec ID/Info                            : The same subtitle format used on DVDs
Menu
00:00:00.000                             : en:The Living Dead
00:07:10.166                             : en:Sand and Blood
00:12:18.500                             : en:The Key to Hamunaptra
00:23:18.500                             : en:The Expedition
00:29:01.666                             : en:The Magi Strike
00:36:44.166                             : en:The City of the Dead
00:43:36.500                             : en:Chambers of Death
00:49:04.000                             : en:Leave or Die
00:53:30.833                             : en:The Black Book
00:57:26.500                             : en:The Bringer of Death
01:11:09.333                             : en:A Curse in Cairo
01:18:43.833                             : en:The Regeneration
01:27:24.666                             : en:Evelyns Choice
01:29:58.500                             : en:Back to Hamunaptra
01:36:27.333                             : en:Against the Dead
01:43:52.000                             : en:The Gold Book
01:49:38.333                             : en:Death of a Mortal
01:56:44.833                             : en:End Titles
Please let me know what you think.
Stace
probedb
Post Fri Mar 15, 2013 8:52 am
I notice it says E-AC3, I believe that's Dolby Digital+? I know my BDP-93 is only happy with standard Dolby Digital in an MKV container, it definitely doesn't work with TrueHD.
Try remuxing into an m2ts container. It's the player rather than Serviio that doesn't support the feature.
sdlehman
Post Fri Mar 15, 2013 12:50 pm
Thanks again for your input. Sorry to ask what may seem like a dumb question on this board. What tool should I use to re-mux this into an MT2S file container? I should probably also mention these are all HD DVD rips if that makes any difference.
Stace
probedb
Post Fri Mar 15, 2013 1:14 pm
No problems, everyone has to start somewhere :)
I found this thread which may help http://forum.videohelp.com/threads/3449 ... KV-to-M2TS I used tsMuxer but it doesn't like all audio codecs when you use the front end. http://www.videohelp.com/tools/tsMuxeR
I ended up reripping to m2ts using DVDFab.
I'm not saying this the problem but the Oppos seem to like m2ts a lot better for audio :)
Users browsing this forum: No registered users and 97 guests
