No Audio on Oppo BDP 83 with MKV
Stace
Unique ID : 44482597239690732123757437391120474065 (0x2177095ECD24FF70A4EF439915E19FD1)
Complete name : H:\Video\THE_MUMMY\_t00.mkv
Format : Matroska
Format version : Version 2
File size : 15.8 GiB
Duration : 2h 4mn
Overall bit rate : 18.2 Mbps
Encoded date : UTC 2013-03-11 20:49:30
Writing application : MakeMKV v1.8.0 win(x86-release)
Writing library : libmakemkv v1.8.0 (1.2.0/1.1.0) win(x86-release)
Format : VC-1
Format profile : Advanced@L3
Codec ID : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint : Microsoft
Bit rate : 16.3 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Original frame rate : 29.970 fps
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Scan order : Top Field First
Compression mode : Lossy
Language : English
Default : No
Forced : No
Format : E-AC-3
Format/Info : Audio Coding 3
Codec ID : A_EAC3
Duration : 2h 4mn
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Delay relative to video : 2ms
Stream size : 1.34 GiB (8%)
Title : 3/2+1
Language : English
Default : Yes
Forced : No
Text
Format : VobSub
Codec ID : S_VOBSUB
Codec ID/Info : The same subtitle format used on DVDs
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:The Living Dead
00:07:10.166 : en:Sand and Blood
00:12:18.500 : en:The Key to Hamunaptra
00:23:18.500 : en:The Expedition
00:29:01.666 : en:The Magi Strike
00:36:44.166 : en:The City of the Dead
00:43:36.500 : en:Chambers of Death
00:49:04.000 : en:Leave or Die
00:53:30.833 : en:The Black Book
00:57:26.500 : en:The Bringer of Death
01:11:09.333 : en:A Curse in Cairo
01:18:43.833 : en:The Regeneration
01:27:24.666 : en:Evelyns Choice
01:29:58.500 : en:Back to Hamunaptra
01:36:27.333 : en:Against the Dead
01:43:52.000 : en:The Gold Book
01:49:38.333 : en:Death of a Mortal
01:56:44.833 : en:End Titles
Users browsing this forum: No registered users and 105 guests
