Post Fri Mar 15, 2013 8:43 pm
This sounds like a problem with the options passed to ffmpeg by Serviio, not something that can be changed by the profile. Won't be at a computer until tomorrow so cannot test it myself. You could turn on detailed logging and make a note of the ffmpeg command used.
@zip could you confirm whether artwork is intentionally missed out when transcoding / is an option missing / is this an ffmpeg bug.
Also for the year, what could cause that to be missing? Looking at my music via ServiiGo I've just seen that all of the years for my albums are missing (displays year they were added to the library). Not sure how I missed that....
Xmantium
Post Fri Mar 15, 2013 9:21 pm
Tested a few videos (x264 mp4) on my HP Touchpad.
Video looks lower quality and video was sluggish and out of sync. Im thinking the internal player is not Hardware acceleration.
Same video runs smooth and synced with BSPlayer Pro.
Great start on having it built in.
bradycl_98258
Post Fri Mar 15, 2013 11:04 pm
Here we go:
To correct, my Serviio 1.2 install is on a Fedora 17 server.
rpm -qa|grep ffmpeg
ffmpeg-libs-0.10.6-1.fc17.i686
ffmpeg-0.10.6-1.fc17.i686
2013-03-15 15:33:42,688 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=xx.xxx.xxx.x, Profile=ServiiGo'
2013-03-15 15:33:42,691 DEBUG [CDSRetrieveMediaServerResource] GET http://xxx.xxx.xxx/cds/resource/15986/COVER_IMAGE,serviigo?authToken=c62a65b1a48146c099fe909ba9aafdf9 HTTP/1.1
2013-03-15 15:33:42,692 DEBUG [CDSRetrieveMediaServerResource] Creating client with id 'xx.xxx.xxx.x'
2013-03-15 15:33:42,692 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=xx.xxx.xxx.x, Profile=ServiiGo'
2013-03-15 15:33:42,693 DEBUG [ResourceDeliveryProcessor] Request for resource 15986 and type 'COVER_IMAGE' received
2013-03-15 15:33:42,693 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 15986)
2013-03-15 15:33:42,695 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 15986
2013-03-15 15:33:42,695 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 15986)
2013-03-15 15:33:42,701 DEBUG [ResourceDeliveryProcessor] Request for resource 5120 and type 'MEDIA_ITEM' received
2013-03-15 15:33:42,701 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 5120 (local)
2013-03-15 15:33:42,704 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 5120)
2013-03-15 15:33:42,707 DEBUG [MusicTrackDAOImpl] Reading a MusicTrack (id = 5120)
2013-03-15 15:33:42,708 DEBUG [AudioDeliveryEngine] Retrieving resource information for item 5120, format MP3 and profile ServiiGo
2013-03-15 15:33:42,710 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 15986
2013-03-15 15:33:42,710 DEBUG [GETMethodProcessor] Stream entity has length: 12578
2013-03-15 15:33:42,708 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file 03 Paradise.flac
2013-03-15 15:33:42,716 DEBUG [AudioDeliveryEngine] Found Format profile for transcoded file 03 Paradise.flac: MP3
2013-03-15 15:33:42,717 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 5120 (local)
2013-03-15 15:33:42,717 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 5120)
2013-03-15 15:33:42,718 DEBUG [MusicTrackDAOImpl] Reading a MusicTrack (id = 5120)
2013-03-15 15:33:42,724 DEBUG [AudioDeliveryEngine] Delivering item '5120' for client 'Identifier=xx.xxx.xxx.x, Profile=ServiiGo'
2013-03-15 15:33:42,725 DEBUG [AudioDeliveryEngine] Delivering file '03 Paradise.flac' using transcoding
2013-03-15 15:33:42,730 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-5132-serviigo-ORIGINAL.stf', will stop the job
2013-03-15 15:33:42,730 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-5132-serviigo-ORIGINAL.stf'
2013-03-15 15:33:42,734 DEBUG [TranscodingJobListener] Deleted temp file '/tmp/Serviio/transcoding-temp-5132-serviigo-ORIGINAL.stf': true
2013-03-15 15:33:42,735 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=xx.xxx.xxx.x, Profile=ServiiGo'
2013-03-15 15:33:42,736 DEBUG [MediaItemDAOImpl] Getting file of media item 5120
2013-03-15 15:33:42,739 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode audio file: /Music/Coldplay/Mylo Xyloto/03 Paradise.flac
2013-03-15 15:33:42,740 DEBUG [ProcessExecutor] Starting ffmpeg -i /Music/Coldplay/Mylo Xyloto/03 Paradise.flac -y -b:a 320k -ac 2 -vn -f mp3 /tmp/Serviio/transcoding-temp-5120-serviigo-ORIGINAL.stf
2013-03-15 15:33:43,241 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2013-03-15 15:33:43,242 DEBUG [AudioDeliveryEngine] Found Format profile for transcoded file 03 Paradise.flac: MP3
2013-03-15 15:33:43,242 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 5120) as read
2013-03-15 15:33:43,262 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-03-15 15:33:43,262 DEBUG [GETMethodProcessor] Entity will be consumed till the end
2013-03-15 15:33:43,262 DEBUG [GETMethodProcessor] Stream entity has length: -1
2013-03-15 15:34:03,297 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2013-03-15 15:34:03,297 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2013-03-15 15:34:08,432 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
I don't know if anything there might give a hint?
Post Sat Mar 16, 2013 9:34 am
Thanks, I'll look at this later today.
Post Sat Mar 16, 2013 9:35 am
Xmantium wrote:Tested a few videos (x264 mp4) on my HP Touchpad.
Can you try Medium quality and also test seeking.
Also, what resolution are the original files?
Homer_Concerned
Post Sat Mar 16, 2013 11:00 am
Quick question about ServiiGo guys;
Does ServiiGo push media from Serviio to a Television much like Airplayer does for iPhone?
I noticed in the App description you can "Playback videos in the external player of your choice (e.g. MX Player) ", is that where one would select their television set were it connected by wifi?
Post Sat Mar 16, 2013 11:11 am
Homer_Concerned wrote:Quick question about ServiiGo guys;
No it cannot. I'm looking into it for the future (no eta just yet) , but only when the TV is on the same network as the Server.
Post Sat Mar 16, 2013 11:55 am
bradycl_98258 wrote:Here we go:
Can you run
ffmpeg -i /Music/Coldplay/Mylo Xyloto/03 Paradise.flac -y -b:a 320k -ac 2 -vn -f mp3 /tmp/Serviio/tmp1.stf
vs
ffmpeg -i /Music/Coldplay/Mylo Xyloto/03 Paradise.flac -y -b:a 320k -ac 2 -f mp3 /tmp/Serviio/tmp2.stf
The -vn option specifically disables the video stream from being copied over, which is why there is no artwork.
Homer_Concerned
Post Sat Mar 16, 2013 12:03 pm
That's unfortunate, I look forward to the implementation of that feature in the future (although I do hope you will consider tackling pushing to TVs on other networks as well).
Are there currently any apps for Android devices that CAN push to TVs?
Post Sat Mar 16, 2013 12:08 pm
Homer_Concerned wrote:No it cannot. I'm looking into it for the future (no eta just yet) , but only when the TV is on the same network as the Server.
Are there currently any apps for Android devices that CAN push to TVs?[/quote]
The problem with across networks is it means the app has to consume the content and send it out. That will quickly drain the phones battery. On the same network, the app can simply setup a link between the tv and server and then leave them to transfer content directly.
Yes, lots of pure DLNA apps can do this, e.g. BubleUPnP, although make sure you assign the profile of your TV to your phone.
Homer_Concerned
Post Sat Mar 16, 2013 12:27 pm
will wrote:The problem with across networks is it means the app has to consume the content and send it out. That will quickly drain the phones battery.
Yes but if one were plugged in it wouldn't be an issue (you could issue a warning message for those who attempt it), plus then you'd have the awesome ability to push your content to any (wifi)tv anywhere.
will wrote:Yes, lots of pure DLNA apps can do this, e.g. BubleUPnP, although make sure you assign the profile of your TV to your phone.
What do you mean by pure DLNA? Sorry, I'm a bit new to DLNA. Does pure DLNA mean you can't use the Serviio server?
Post Sat Mar 16, 2013 12:35 pm
Homer_Concerned wrote:Yes but if one were plugged in it wouldn't be an issue (you could issue a warning message for those who attempt it), plus then you'd have the awesome ability to push your content to any (wifi)tv anywhere.
It is certainly something I would like to add, but to actually get it to work reliably will be a lot of work, so it the first step would be same network only.
will wrote:What do you mean by pure DLNA? Sorry, I'm a bit new to DLNA. Does pure DLNA mean you can't use the Serviio server?
Sorry, I ment DLNA is a standard for same network media sharing, its what Serviio does best, and it is what is built into most TV's Blu-ray players in some form or another. Where as ServiiGo is different in that it doesn't use DLNA and uses a different means of talking to Serviio that works outside of your netowrk as well as in it. All I ment was to try a DLNA app that is designed specifically for home network streaming and you should be able to push content from Serviio to your TV.
Homer_Concerned
Post Sat Mar 16, 2013 1:23 pm
will wrote:It is certainly something I would like to add, but to actually get it to work reliably will be a lot of work, so it the first step would be same network only.
Understandable for sure!
will wrote:Sorry, I ment DLNA is a standard for same network media sharing, its what Serviio does best, and it is what is built into most TV's Blu-ray players in some form or another. Where as ServiiGo is different in that it doesn't use DLNA and uses a different means of talking to Serviio that works outside of your netowrk as well as in it. All I ment was to try a DLNA app that is designed specifically for home network streaming and you should be able to push content from Serviio to your TV.
Ah ok, I wasn't aware that ServiiGo didn't use DLNA. I shall check out BubleUPnP and any other suggestions you might have for DLNA apps, though somehow I doubt any of them will look as good as ServiiGo, it's a fine app you're developing here. I could see myself using ServiiGo for tablet viewing and another app for pushing for the time being.
Post Sat Mar 16, 2013 2:42 pm
rpm -qa|grep ffmpeg
Missing artwork is going to require a change to Serviio and will need a bit of testing so will not be in for 1.2.1 but instead 1.3 (https://bitbucket.org/xnejp03/serviio/i ... ding-audio). For now, it would help if you could run the commands I listed above (with and without -vn), and then post ffmpeg -i <path_to_file> for the two generated files to confirm that artwork is then copied over correctly during the transcoding process.
bradycl_98258
Post Sun Mar 17, 2013 8:34 am
Will,
After doing some testing and googling yesterday I came to the same conclusion--ffmpeg just does not seem to be transferring the album art from flac(removing the vn made no difference). Decided to try taking a different approach--I'm using mp3fs in linux to present my flac repository to Serviio as mp3's. This lets me use lame instead of ffmpeg for the transcoding, and I get 320k quality 2 mp3's with perfectly transferred tags for Serviio to then stream to me.
But the album art in ServiiGo isn't working. As you can see below, Serviio is indeed sending me the native file:
2013-03-17 01:02:49,587 DEBUG [CDSRetrieveMediaServerResource] GET http://xxxxxxxxxxxx.xxxxxx.xxx/cds/resource/5131/COVER_IMAGE,serviigo?authToken=3faedaafa0bd4703a20eef01badfd6f4 HTTP/1.1
2013-03-17 01:02:49,588 DEBUG [CDSRetrieveMediaServerResource] Creating client with id 'xxx.xxx.xxx.xxx'
2013-03-17 01:02:49,588 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=xxx.xxx.xxx.xxx, Profile=ServiiGo'
2013-03-17 01:02:49,589 DEBUG [ResourceDeliveryProcessor] Request for resource 5131 and type 'COVER_IMAGE' received
2013-03-17 01:02:49,592 DEBUG [CDSRetrieveMediaServerResource] GET http://xxxxxxxxxxxx.xxxxxx.xxx/cds/resource/5132/MEDIA_ITEM/MP3-0/ORIGINAL,serviigo?authToken=3faedaafa0bd4703a20eef01badfd6f4 HTTP/1.1
2013-03-17 01:02:49,598 DEBUG [CDSRetrieveMediaServerResource] Creating client with id 'xxx.xxx.xxx.xxx'
2013-03-17 01:02:49,599 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=xxx.xxx.xxx.xxx, Profile=ServiiGo'
2013-03-17 01:02:49,601 DEBUG [ResourceDeliveryProcessor] Request for resource 5132 and type 'MEDIA_ITEM' received
2013-03-17 01:02:49,602 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 5132 (local)
2013-03-17 01:02:49,603 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 5131)
2013-03-17 01:02:49,612 DEBUG [CoverImageRetrievalStrategy] Retrieving info of Cover image with id 5131
2013-03-17 01:02:49,613 DEBUG [CoverImageDAOImpl] Reading a CoverImage (id = 5131)
2013-03-17 01:02:49,618 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 5132)
2013-03-17 01:02:49,621 DEBUG [CoverImageRetrievalStrategy] Retrieving Cover image with id 5131
2013-03-17 01:02:49,622 DEBUG [GETMethodProcessor] Stream entity has length: 10667
2013-03-17 01:02:50,035 DEBUG [MusicTrackDAOImpl] Reading a MusicTrack (id = 5132)
2013-03-17 01:02:50,042 DEBUG [AudioDeliveryEngine] Retrieving resource information for item 5132, format MP3 and profile ServiiGo
2013-03-17 01:02:50,045 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 5132 (local)
2013-03-17 01:02:50,045 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 5132)
2013-03-17 01:02:50,051 DEBUG [MusicTrackDAOImpl] Reading a MusicTrack (id = 5132)
2013-03-17 01:02:50,059 DEBUG [AudioDeliveryEngine] Delivering item '5132' for client 'Identifier=xxx.xxx.xxx.xxx, Profile=ServiiGo'
2013-03-17 01:02:50,060 DEBUG [AudioDeliveryEngine] Delivering file '07 Viva La Vida.mp3' in native format
2013-03-17 01:02:50,060 DEBUG [MediaItemDAOImpl] Getting file of media item 5132
2013-03-17 01:02:50,171 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 5132) as read
2013-03-17 01:02:50,428 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2013-03-17 01:02:50,428 DEBUG [GETMethodProcessor] Stream entity has length: 10074151
I ran the copy sent to my phone through mp3tag, and my album art, all beautiful 404k of it, is indeed in the track I receieved. In fact, the original mp3 in my mp3fs directory and the item I received on my phone are bitwise exactly the same, all 10074151 bytes.
However, although I saw the thumbnail in the player flash when the blue line completed the download, still no high-res, it just put the thumbnail back up! No high-res even after two or three plays and a reboot.
Any ideas or things for me to check in this case?
Post Sun Mar 17, 2013 8:40 am
bradycl_98258 wrote:Will,
Can you PM me a link to the mp3 on dropbox or email the mp3 to me at the address on Google Play.
Post Sun Mar 17, 2013 9:46 am
After some testing I've found that Android does not support reading ID3 v2.4 tags (niether does Windows), so use ID3 v2.3 tags.
Post Sun Mar 17, 2013 11:22 am
How about his? http://herself.movielady.net/2011/06/21 ... -id3-tags/
jsebright
Post Fri Mar 22, 2013 9:07 pm
Access Group Restrictions
Apologies if I shouldn't be posting in this thread or if this has been already answered somewhere else. I have dome some searching and not found the answer.
I've bought serviio pro and a paid licence for serviigo*. I think the two together are a great way of showing content on android devices. But...
I want to restrict access on my daughters tablet to one of the shares. I've put that tablet in the Limited access group, and configured the shared folders so that only the one I want her to see is ticked with Limited access. According to the documentation that should do it...
I've restarted the services, but that device can still see all the content including the files I don't want her to see. Even removing the "Device allowed" tick does not restrict playback in any way.
Is this due to the way Serviigo interacts with Serviio, or am I missing a step?
* - just realised am not using a paid version of Serviigo on this tablet / account yet - would that make a difference?
Thanks for help,
Jon.
Post Fri Mar 22, 2013 9:23 pm
Hi, at the moment this only works when using traditional DLNA clients such as TVs, Serviio does not have the ability to identify remote clients (ServiiGo or MediaBrowser) and until it is added to Serviio there isn't anything I can do for ServiiGo.
@zip, cannot check bitbucket atm, is this scheduled for anytime soon?
