HOWTO: Serviio 1.1 on Zyxel NSA 325
tmcatalin
Post Mon Mar 25, 2013 7:07 pm
Re: HOWTO: Serviio 1.1 on Zyxel NSA 325
solved. thank you. it was in /ffp/opt/serviio/bin/serviio.sh
Happy_Highlander
Post Tue Apr 02, 2013 9:02 pm
Everything working well and problematic files play using Sony 2011 profile but only after remuxing audio with avidemux to ac3 which takes about 5 mins. The only problem I have is that the server is not recognised by any console installed into windows. I've tried on xp, 7 and 8 with both 1.1 & 1.2 consoles. Any help on this would be appreciated. It's more annoying than anything else as the serviidroid app recognises the server so I'm not stuck for adding folders or profiles but it would be handy for the missus to be able to add them if I'm not home.
vladster
Post Wed Apr 03, 2013 12:59 pm
I've been using serviio on server 2008 R2 for about 2 years now, but I got myself a NSA325 with hopes to switch platforms and reduce my carbon blueprint :D
Now, I followed the guide (by the way thanks for great work with guide and serviio) and was able to successfully install serviio on NAS. Couple problems I have now is I don't see anything in the Presentation Tab on ServiioConsole and my client (tested with iPad2 and Media Link Player) won't display large photos over 3MB or play any video that is not h.264 encoded. The iPad issue is not a big deal, but I would like to customize my Presentation Folder view. Any suggestions? Is it possible to make a complete package for Zyxel NAS?
Thanks again for all your hard work. Serviio is a great piece of software...
vladster
Post Wed Apr 10, 2013 1:36 pm
After unsuccessfully trying to get serviio 1.1 to work, I installed ffmpeg -1.1.1 with serviio 1.2 on my NSA325 and presentation tab is now working as well as streaming to a few of my clients. Pretty excited to see it run on the NAS.
MikePembo951
Post Fri Apr 12, 2013 1:44 pm
I've tried to edit the serviio.sh script on my (windows) PC. (Connecting to my NSA 310 through putty).
When running the script serviiod.sh I get:
: command not found.sh: line 1:
: command not found.sh: line 3:
: command not found.sh: line 5:
: command not found.sh: line 10:
: command not found.sh: line 11:
: numeric argument requirede 11: exit: 0
How did Reno fix this?
vladster
Post Wed Apr 24, 2013 5:24 pm
I used vim on NSA325 to edit serviio.sh file and it worked just fine.
bhatiagagan
Post Sun Apr 28, 2013 5:04 am
Guys
I'm a complete newb to this..so please forgive my basic questions.
I'm planning to install 1.2 on my NSA325, and from what I understand I need to install ffmpeg 1.1.1 for that. Could someone please guide me as to where all should the guide be modified?
Update:
I went ahead and installed Serviio 1.2 with ffmpeg 0.1.1. Serviio works( it is detected, haven't tested subtitles yet) but I've noticed that the video playback is really choppy. I have a Toshiba TV which requires transcoding, and I think this might be the reason behind the slow buffering.
Just wanted to check, is this because of the ffmpef incompatibility, or is this normal with zyxel nsa325? Should I go back to Serviio 1.1 or is there an easy way to update ffmpeg?
Would really be grateful for any help.
bhatiagagan
Post Fri May 10, 2013 8:13 pm
Still waiting for an answer. Could someone with the knowhow please help me.
robinthakur
Post Thu May 16, 2013 11:21 pm
I followed the instructions to the letter, changing the version of java as appropriate, but when I come time to start the service I get the following
root@NSA325:/ffp/start# sh /ffp/start/serviiod.sh start
Starting Serviio
/ffp/start/serviiod.sh: line 72: start-stop-daemon: not found
Failed
Java is definitely installed. Any ideas?
The only difference is that it complained when I wrote tar xfvz serviio-1.1-linux.tar.gz near the end and I had to type tar xvzf serviio-1.1-linux.tar.gz
If I typed what was in the example I got
root@NSA325:/ffp/start# tar xfvz serviio-1.1-linux.tar.gz
tar: can't open 'vz': No such file or directory
However, When I launch the PS3, there is a serviio icon there, but no videos at all.
nforced
Post Sun Jun 23, 2013 10:18 am
this tutorial works for me on Zyxel NSA 310 just as described, I'm running serviio-1.2.1-linux.tar.gz with ejre-7u21-fcs-b11-linux-arm-sflt-headless-04_apr_2013.tar.gz and this works just perfect with my Sony kdl-32ex650
root@nsa:~# java -version
java version "1.7.0_21"
Java(TM) SE Embedded Runtime Environment (build 1.7.0_21-b11, headless)
Java HotSpot(TM) Embedded Client VM (build 23.21-b01, mixed mode)
Thanks Man, you have a big beer from me! I was about to write my steps but this is useless, you have wrote it all :D
markus74
Post Fri Jul 05, 2013 8:38 pm
I am a newbie on this topic, but I would like to install serviio 1.2.1 on a Zyxel NSA325.
Could you possibly update the howto or describe the steps that are different to install this version?
@nforced: Have you installed ffmpeg 1.1.1 when you were installing Serviio 1.2.1? How have you done that? From what I am reading that seems to be the biggest question for everyone...
Thanks in advance to anyone helping me on that.
Markus
ryyyiu
Post Sun Jul 28, 2013 7:07 pm
what is wrong many times i see java or ffmpeg uses 99% of CPU!!!?? I have isntalled servio 1.2.1 and ffmpeg 1.1.1
ryyyiu
Post Mon Jul 29, 2013 8:22 pm
ah i have successfully deleted serviio from nsa325, it was so bad experience, nas server was so slow, sometimes it get response in longer time, back to twonky is much faster and better, because it is integrated with whole nsa325 firmware.
JamesUK
Post Wed Jul 31, 2013 11:26 pm
You may find this thread of interest.
v2kisad
Post Thu Aug 01, 2013 1:10 pm
Hi ,
I followed this article to install serviio on my newly purchased NSA325 but i am stuck when i try to start the service. Here's the error that i get.
/ffp/start/serviiod.sh: line 14: syntax error: unexpected end of file
I installed serviio-1.2.1-linux.tar.gz, not sure if its th reason for the error. I would be grateful if someone can please help me fix this.
JamesUK
Post Thu Aug 01, 2013 1:16 pm
When you created serviiod.sh, are you sure that you copy and pasted the whole file from this thread? (I know I never noticed the scrollbars at first.)
v2kisad
Post Thu Aug 01, 2013 1:42 pm
I think i did. Here's my script
root@NSA325:/ffp/start# cat serviiod.sh
#!/ffp/bin/sh
# FFP Startup script for Serviio
EXEC=/ffp/opt/serviio/bin/serviio.sh
PIDFILE=/var/run/serviiod.pid
JAVA_HOME=/ffp/opt/java/jre
OPTS=
test -x $EXEC || exit 0
case "$1" in
start)
JamesUK
Post Thu Aug 01, 2013 1:48 pm
You didn't! :)
v2kisad
Post Thu Aug 01, 2013 3:08 pm
Thank You @JamesUK ...stupid of me not to realise it after you indicated the scroll bar thing. I have copied the entire script now and serviio does start okay but it doesnt stay running for long.
Starting Serviio
OK
root@NSA25:/ffp/start# ps -ef | grep serviio
root 32685 1 0 08:04 ? 00:00:00 /bin/sh /ffp/opt/serviio/bin/serviio.sh
root 32690 32685 93 08:04 ? 00:00:02 /ffp/opt/java/jre/bin/java -Xms5M -XX:+UseParNewGC -XX:MinHeapFreeRatio=5 -XX:MaxHeapFreeRatio=10 -Dserviio.home=/ffp/opt/serviio -Djava.net.preferIPv4Stack=true -classpath /ffp/opt/serviio/lib/*:/ffp/opt/serviio/config org.serviio.console.ServiioConsole
root@NSA325:/ffp/start# ps -ef | grep serviio
JamesUK
Post Thu Aug 01, 2013 4:11 pm
That java command looks odd - The parameters don't match what's in my /ffp/opt/serviio/bin/serviio.sh - You can see the expected java command in the first post in this topic.
Note: There are some log files under /ffp/opt/serviio/log/ that may be of interest to you.
