SOPCAST VIDEO WEB RESOURCE
thanks ill re try, basically as far as the stream i was watching i was trying random ones through the sopcast programe.
Re: SOPCAST VIDEO WEB RESOURCE
Hi! I'm having some problems with my Sony Bravia KDL-NX700 (2010). I follow the first page instructions but the Sopcast #1 folder doesn't appear.
I have a channel of sopcast running right now, but this is the log:
2013-03-29 16:30:29,162 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://localhost:8902. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:292)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:453)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:94)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:132)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:269)
... 2 more
Thanks!
... 2 more
Thanks!
Maybe its on a different port.
I don't think so because is the port that appears in vlc.
Is this plugin compatible with serviio 1.2 or 1.2.1?
I add the attached groovy to the Serviio plugin directory, then add the URL http://www.sopcast.com?port=3902&items=7 to the console online sources as a video and then I can see the the Serviio Online Sopcast folder but there is no item inside.
With serviio 1.1 there is no problem, i see the folder and the items inside, and i can select them.
The problem is with the ffmpeg 1.1.1 used by 1.2 It hangs when using http:\\localhost:8902
Version 6 posted to use 127.0.0.1 in order to circumvent ffmpeg bug.
With Serviio 1.2.1 and Sopcast plugin v6 my tv (Samsung UE46D6500) keeped droping the stream at every 1-2 minutes - and that was very annoying. With transcoding or without it, the tv always jumped at the next entry on Sopcast list.
Until i decided to make the modification of profiles.xml indicated on page 1 and inserted the code below:
Now, if the original stream is fluent and have no glitches, no more jumps on tv. Problem solved !
THX for this great plugin!
<Matches container="mpegts" vCodec="h264" /> <!-- jhb50 fixes serviio h264.ts to h264.ts transcode bug -->
Hi
Just wondering when I watch sopcast I have 2 streams set up running at the same time
But when I click on each stream there are all of the same stream
So is there a way please to have the other stream on the other channel
Beta Tester
Beta Tester
You don't need the plugin for that. Just set up each livestream in the console.
Hi
I tried changing the profile for my Samsung tv + blu-ray player
I put the second line and it works fine but soon as I put the third Line in like this
It don't work I get this message coming up serviio is not running exit serviio
Can you please tell me where I am going wrong
Thanks appreciate it
<Matches container="mpeg" vCodec="h264" /> <!-- optional --> h264 mpegps as well as h264 mpegts and wmv.asf streams will transcode to MPEG2VIDEO
Beta Tester
Beta Tester
comments must be enclosed with <!-- -->
Can you please write it out so I can copy & paste it
Thanks a lot jhb50
Thanks a lot jhb50
Beta Tester
Beta Tester
it's pretty easy.. just add
at the end of the last line you posted.
Thanks so you don't need to do anything before h264
Just after mpeg2video
Thanks a lot appreciate it
Beta Tester
Beta Tester
you should just try things and see if they work, If they don't then ask.
Hello! There are new here
I need help. I recently installed 1.2.1 SERVIO. Before it was version 1.2 and going through serviio streaming sopcast (tv samsung d/c350). Now after the update number sopcast appears to online serviio (from TV). Does anyone know why? thanks
What does this mean?
hello, I have the problem that in the 6 previous pages is common. I have a Samsung 40D6000 model, I added the lines that indicate and still keeps cutting.
If i use the plugin I had to replace all 7 channels to 45, because it gives me to see an event.
If anyone has this model and has solved the problem much I appreciate him for modified profiles file or explain me the right solution.
Thanks, sorry for the translation.
edit:
When i edit the profile serviio don't star with windows....
edit:
