SOPCAST VIDEO WEB RESOURCE
Chrisnewton
Post Sun Mar 17, 2013 5:46 pm
Re: SOPCAST VIDEO WEB RESOURCE
thanks ill re try, basically as far as the stream i was watching i was trying random ones through the sopcast programe.
ignation
Post Fri Mar 29, 2013 3:39 pm
Hi! I'm having some problems with my Sony Bravia KDL-NX700 (2010). I follow the first page instructions but the Sopcast #1 folder doesn't appear.
I have a channel of sopcast running right now, but this is the log:
2013-03-29 16:30:29,162 WARN [FeedUpdaterThread] Failed to retrieve online item information for http://localhost:8902. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:292)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:209)
at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:102)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:453)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:94)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:132)
at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveMetadata(FeedUpdaterThread.java:269)
... 2 more
Thanks!
Post Fri Mar 29, 2013 6:22 pm
Maybe its on a different port.
ignation
Post Sun Mar 31, 2013 7:45 pm
I don't think so because is the port that appears in vlc.
johnynimrod
Post Tue Apr 02, 2013 12:30 pm
Is this plugin compatible with serviio 1.2 or 1.2.1?
I add the attached groovy to the Serviio plugin directory, then add the URL http://www.sopcast.com?port=3902&items=7 to the console online sources as a video and then I can see the the Serviio Online Sopcast folder but there is no item inside.
With serviio 1.1 there is no problem, i see the folder and the items inside, and i can select them.
Vintila
Post Mon Apr 08, 2013 7:19 pm
Post Tue Apr 09, 2013 12:58 am
The problem is with the ffmpeg 1.1.1 used by 1.2 It hangs when using http:\\localhost:8902
Post Tue Apr 09, 2013 3:39 pm
Version 6 posted to use 127.0.0.1 in order to circumvent ffmpeg bug.
nicksson
Post Fri Apr 12, 2013 11:45 am
With Serviio 1.2.1 and Sopcast plugin v6 my tv (Samsung UE46D6500) keeped droping the stream at every 1-2 minutes - and that was very annoying. With transcoding or without it, the tv always jumped at the next entry on Sopcast list.
Until i decided to make the modification of profiles.xml indicated on page 1 and inserted the code below:
<Matches container="mpegts" vCodec="h264" /> <!-- jhb50 fixes serviio h264.ts to h264.ts transcode bug -->
Now, if the original stream is fluent and have no glitches, no more jumps on tv. Problem solved ! :D
THX for this great plugin!
siriusblack
Post Fri Apr 26, 2013 11:52 am
Hi
Just wondering when I watch sopcast I have 2 streams set up running at the same time
But when I click on each stream there are all of the same stream
So is there a way please to have the other stream on the other channel
Beta Tester
Post Fri Apr 26, 2013 2:14 pm
You don't need the plugin for that. Just set up each livestream in the console.
siriusblack
Post Mon Apr 29, 2013 8:12 pm
Hi
I tried changing the profile for my Samsung tv + blu-ray player
I put the second line and it works fine but soon as I put the third Line in like this
It don't work I get this message coming up serviio is not running exit serviio
Can you please tell me where I am going wrong
Thanks appreciate it
<Matches container="mpeg" vCodec="h264" /> <!-- optional --> h264 mpegps as well as h264 mpegts and wmv.asf streams will transcode to MPEG2VIDEO
Beta Tester
Post Mon Apr 29, 2013 8:44 pm
comments must be enclosed with <!-- -->
siriusblack
Post Mon Apr 29, 2013 8:51 pm
Can you please write it out so I can copy & paste it
Thanks a lot jhb50
Beta Tester
slyguy42o
Post Mon Apr 29, 2013 8:57 pm
it's pretty easy.. just add
at the end of the last line you posted.
siriusblack
Post Mon Apr 29, 2013 9:02 pm
Thanks so you don't need to do anything before h264
Just after mpeg2video
Thanks a lot appreciate it
Beta Tester
Post Mon Apr 29, 2013 9:18 pm
you should just try things and see if they work, If they don't then ask.
soringsm
Post Tue Jun 11, 2013 12:43 pm
Hello! There are new here :).
I need help. I recently installed 1.2.1 SERVIO. Before it was version 1.2 and going through serviio streaming sopcast (tv samsung d/c350). Now after the update number sopcast appears to online serviio (from TV). Does anyone know why? thanks
Post Tue Jun 11, 2013 2:49 pm
What does this mean?
xtrapeque
Post Thu Oct 03, 2013 7:10 pm
hello, I have the problem that in the 6 previous pages is common. I have a Samsung 40D6000 model, I added the lines that indicate and still keeps cutting.
If i use the plugin I had to replace all 7 channels to 45, because it gives me to see an event.
If anyone has this model and has solved the problem much I appreciate him for modified profiles file or explain me the right solution.
Thanks, sorry for the translation.
edit:
When i edit the profile serviio don't star with windows....
Return to Available plugins
