B-series - no sound with Serviio 1.2 from DTS-audio .mkv
Sky1111
Post Sat Mar 16, 2013 3:51 pm
Hello everyone, I have been using Serviio since 0.6.1 and recently hit an unexpected issue:
PROBLEM: with Serviio 1.2 and Samsung B-series TV, there is no audio from ANY .mkv file with DTS audio track.
- Profile is correctly set in Serviio to B-series (just like it was done before)
- Video playback is fine, no issues.
- AC3 .mkv are fine too.
- To re-iterate: the problem is not limited to any particular file
- D-series TV connected to the same Serviio server, play all everything with sound, no issues
REGRESSION TESTING DONE:
- uninstall Serviio, Java, clean with CCleaner
- installed the latest Java
- reinstalled Serviio 1.2 - same issue persists
Installed Serviio 1.2 on another PC - same issue with DTS files
Rolled back to 1.0.1 - NO PROBLEMS with DTS sound
Any ideas how to fix it?
Sky1111
Post Sat Mar 16, 2013 3:57 pm
Re: B-series - no sound with Serviio 1.2 from DTS-audio .mk
ATTEMPTED FIX:
- copied B-series portion from old profiles.xml into the new (1.2) profile (edited part which says DO NOT EDIT :))
- After reboot - error message: Cannot connect to Serviio server, exiting
So hacking did not work. I am restoring to the original profiles.xml
What can I do to keep Serviio 1.2 and be able to use both TVs? thanks...
Post Sun Mar 17, 2013 11:44 am
It should work, can you post detailed log of playing the file?
Sky1111
Post Sun Mar 17, 2013 1:09 pm
Please see attachment - I enabled the debug mode, but I do not see anything obvious (the log is huge, so I trimmed down to what I think is applicable to the specific file).
Serviio_Log.txt
Log file for the no sound mkv
(27.06 KiB) Downloaded 577 times
Post Sun Mar 17, 2013 7:13 pm
It sends it transcoded. Is it just this file or do you have any other MKV/h264/DTS to test?
I tried a similar file on my C series with the B profile and it played it. Can you try to play the file on your D series with B profile?
Sky1111
Post Mon Mar 18, 2013 4:39 am
the no DTS audio issue is not specific to a particular MKV - I tried randomly few, the same result.
I tried "B" profile on "D" TV with somewhat mixed results: audio is there (the TV natively can play DTS anyway), but the FF does not work.
I tried to copy B-portion of old profile at the very end of the new profile (without changing anything else in the original profile) - the same error message about Serviio not running....
Restored back to the original profiles.
Any other suggestions?
Post Mon Mar 18, 2013 11:39 am
Could you post detailed log of playing the file with 1.1 and then 1.2 - use the B profile distributed with each version.
Also, first try to copy FFmpeg from 1.1 to your 1.2 installation and try to play it then.
Sky1111
Post Thu Mar 21, 2013 2:57 am
Miracle! I swapped the ffmpeg and my old TV played DTS movie with sound!!!
I am not able to tell the exact version comparison (right click -> properties); the working binary comes from Serviio 1.0.1 install
Next step will be to follow your guide to update ffmpeg - if there is anything newer.
Sky1111
Post Thu Mar 21, 2013 11:55 am
UPDATE: FFmpeg Build Version: git-17c1881 (2013-03-19), 64bit version - works for "D" series, completely breaks for "B" - "not supported file format".
I am rolling back to the FFmpeg version included in 1.0.1 (and transplanted into 1.2)
FeroLopata
Post Sun Mar 24, 2013 3:31 pm
Hi guys,
the same problem here (Samsung UE55B7000) - Serviio 1.2 and 1.2.1 DTS sound not working (i.e. video OK with no sound) - I reverted back to 1.1 which works fine.
It is a very serious issues - the DTS transcoding is the main reason I use Serviio w/o it well...
I hope it gets fixed soon otherwise no upgrade for Samsung B series users possible.
FeroLopata.
Post Sun Mar 24, 2013 7:28 pm
It looks like FFmpeg issue, so either revert to FFmpeg from 1.1, or keep trying the newest FFmpeg builds
neuronik
Post Mon Apr 01, 2013 9:51 pm
I'm writing to confirm that i just solved the ffmpeg issue by replacing the file ffmpeg.exe in ..\Program Files\Serviio\lib with the same file you can find by installing a old serviio release like the 1.0.1 for my UE40B7000
Using Google i downloaded it from http://www.downloadcrew.com/article/27941-serviio and I installed it.
in the dir ..\Program Files\Serviio\lib I copied the old ffmpeg.exe and pasted it away.
I installed serviio 1.2.1 over the same dir then i renamed the ffmpeg.exe in the ..\Serviio\lib directory to ffmpeg.exe.new
I moved the old ffmpeg.exe from the away location to its original dir.
Reboot and then it works.
Unfortunately, i have no chance to solve the same problem if i want the console to run from my Synology NAS DS212j.
Maybe Patters can have a look at it and include an exception for Samsung B series in his package.
In the meantime i'll keep my pc up for the transcoding.
Thanks for your wonderful work.
NeuroNik
Post Mon Apr 01, 2013 10:49 pm
Did you try the latest Zeranoe build?
neuronik
Post Tue Apr 02, 2013 9:30 pm
I tried to read around this forum and in http://ffmpeg.zeranoe.com but seems im not able to find a tip about how to deal with it and with my synology.
I've also read this thread viewtopic.php?f=5&t=9594 and im confident that mbarnig's ticket will get it work in next ffmpeg release.
in the meantime, nvm :)
Users browsing this forum: No registered users and 53 guests
