QPKG Serviio 1.2 for QNAP
• Page 1 of 1
Is there a QPKG Serviio 1.2 for NAS QNAP clients?!... Or any other way to install this new version?!
Re: QPKG Serviio 1.2 for QNAP
Not yet, and yes...
If you want to bodge it you can get the linux version and bang it over the top manually.
Getting ffmpeg compiled is a little more tricky, I got it compiled with libass, but subtitles aren't working even though there are no errors.
Use servidroid to configure it...
-EDIT-
School boy error, I didn't have any fonts installed on my QNAP, copied ARIAL.TTF to font directory and works a treat now. Better than the native support on my Viera...
-EDIT-
Hi Keifos,
I'm trying to do the same, which folder are you meant to save the ARIAL.TTF font file too?
Following.... Waiting for QPKG.
Christian released a new package with Serviio 1.2.1 and newly compiled FFMPEG. Webstreaming works in this release, no further errors found to date.
https://dl.dropboxusercontent.com/u/188 ... rm-x19.zip
Please post your findings and feedback here:
http://forum.qnap.com/viewtopic.php?f=2 ... 4&p=341669
Regards,
Blixx
Regards,
Blixx
Does anyone know if we'll get a Serviio 1.2.1 QPKG for the Intel processor ?
Regards
Regards
There is scripts you can run here - https://gist.github.com/tommeier/5324815
This will update your current Serviio and will also install a fresh compiled ffmpeg which is custom to your QNAP
Not as easy as installing a QPKG but works very well and don't need to wait for others to release a package.
There individual scripts for updating serviio, updating ffmpeg, updating webui and plugins.
Thanks Xmantium.
Hi.
Can someone provide me a help to update the serviio that is installed in my qnap using the scripts? I don't know how to use the scripts to update to version 1.2.1.
I haven't done mine yet but I will advise any success or failure here to help others.
Regards from Jamaica
Ive packaged together a QPKG for ARM and Intel devices using the previous source material
http://forum.qnap.com/viewtopic.php?f=2 ... 02#p375699
Hope you guys enjoy Serviio as much as i do!
• Page 1 of 1
