QPKG Serviio 1.2 for QNAP
JohnMike
Post Sat Mar 02, 2013 3:47 pm
Is there a QPKG Serviio 1.2 for NAS QNAP clients?!... Or any other way to install this new version?!
KeifOS
Post Sat Mar 02, 2013 8:56 pm
Re: QPKG Serviio 1.2 for QNAP
Not yet, and yes...
If you want to bodge it you can get the linux version and bang it over the top manually.
Getting ffmpeg compiled is a little more tricky, I got it compiled with libass, but subtitles aren't working even though there are no errors.
Use servidroid to configure it...
-EDIT-
School boy error, I didn't have any fonts installed on my QNAP, copied ARIAL.TTF to font directory and works a treat now. Better than the native support on my Viera...
pommytom
Post Sat Apr 13, 2013 6:57 am
Hi Keifos,
I'm trying to do the same, which folder are you meant to save the ARIAL.TTF font file too?
_SDK_
Post Sat Apr 20, 2013 3:53 pm
Following.... Waiting for QPKG.
Blixx
Post Sat May 18, 2013 7:14 am
Christian released a new package with Serviio 1.2.1 and newly compiled FFMPEG. Webstreaming works in this release, no further errors found to date.
https://dl.dropboxusercontent.com/u/188 ... rm-x19.zip
Please post your findings and feedback here:
http://forum.qnap.com/viewtopic.php?f=2 ... 4&p=341669
Regards,
Blixx
_SDK_
Post Mon May 20, 2013 12:21 pm
Does anyone know if we'll get a Serviio 1.2.1 QPKG for the Intel processor ?
Regards
Xmantium
Post Mon May 20, 2013 6:41 pm
There is scripts you can run here - https://gist.github.com/tommeier/5324815
This will update your current Serviio and will also install a fresh compiled ffmpeg which is custom to your QNAP
Not as easy as installing a QPKG but works very well and don't need to wait for others to release a package.
There individual scripts for updating serviio, updating ffmpeg, updating webui and plugins.
_SDK_
Post Tue May 21, 2013 2:20 am
Thanks Xmantium.
jotavip
Post Tue Aug 06, 2013 5:40 am
Hi.
Can someone provide me a help to update the serviio that is installed in my qnap using the scripts? I don't know how to use the scripts to update to version 1.2.1.
_SDK_
Post Tue Aug 06, 2013 12:53 pm
I haven't done mine yet but I will advise any success or failure here to help others.
Regards from Jamaica
Xmantium
Post Sun Oct 20, 2013 5:20 pm
Ive packaged together a QPKG for ARM and Intel devices using the previous source material
http://forum.qnap.com/viewtopic.php?f=2 ... 02#p375699
Hope you guys enjoy Serviio as much as i do!
Users browsing this forum: Google [Bot] and 8 guests
