Updated Serviio to 1.2 - Cant start Serviio now.
fredricz
Post Sat Mar 09, 2013 2:53 pm
Updated to Serviio 1.2 the other day, can't really open Serviio at all now. Can't even start the service. Using Windows 7...
I've tried to uninstall, and then re-install Serviio 1.2. Didn't work.
I've tried to uninstall, and then re-install Serviio 1.1. Didn't work.
What to do now? When I open the Serviio console, it doesnt start. No error message and no logs are created. Got any tips?
Service error:
Post Sat Mar 09, 2013 6:47 pm
Re: Updated Serviio to 1.2 - Cant start Serviio now.
did you try searching the forum for 1067 ?
fredricz
Post Sat Mar 09, 2013 9:25 pm
zip wrote:did you try searching the forum for 1067 ?
Well, ye. Got 32-bits Windows 7, so has nothing to do with 64 bits installation.
I've tried both Java 6 and Java 7.
And, I made a log from "/create-i4g-log"
Started executable C:\Program Files\Serviio\bin\ServiioConsole.exe at Sat Mar 09 22:23:07 2013
number of sections: 5
size of optional headers: 224
resSectionTableStart: 648
rawDataSize: 10240, rawDataOffset: 528384
sun.locale.formatasdefault is true
language/country is sv_SE
change working directory to C:\Program Files\Serviio\bin
calling C:\Windows\explorer.exe /select,C:\Users\admin\AppData\Local\Temp\I4J_NL~1
semaphore name Local\c:_program_files_pc5dczc_bin_serviioconsole.exe0, code 0, value 000000A0
extracting files
Included files: 2
GetTempPath returned 34 (last error 183)
make dir returned -1
tempPath is C:\Users\admin\AppData\Local\Temp\
tempFile is C:\Users\admin\AppData\Local\Temp\e4j9003.tmp
Temp dir: C:\Users\admin\AppData\Local\Temp\e4j9003.tmp_dir1362864192
extracting C:\Users\admin\AppData\Local\Temp\e4j9003.tmp_dir1362864192\exe4jlib.jar (size: 29873)
extracting C:\Users\admin\AppData\Local\Temp\e4j9003.tmp_dir1362864192\i4jdel.exe (size: 28099)
extracting files done
native lib dir is
Setting PATH (native libs) C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Windows Live\Shared;C:\Program Files\Common Files\HP\Digital Imaging\bin;C:\Program Files\HP\Digital Imaging\bin\;C:\Program Files\HP\Digital Imaging\bin\Qt\Qt 4.3.3;C:\Program Files\MKVtoolnix;
LoadDLL (1, (null), 0)
Searching for a JVM
GetTempPath returned 34 (last error 3)
Testing location  (type Y)
checkJavaExe (C:\Program Files\Java\jre7\bin\java.exe, [out], 1.6, , 0)
file exists
got version from registry 1.7.0_17
checkJavaExe returning 1
found sun c:\program files\java\jre7\bin\javaw.exe 1.7.0_17
Trying to load JVM-DLL from c:\program files\java\jre7\bin\javaw.exe
Setting PATH C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Windows Live\Shared;C:\Program Files\Common Files\HP\Digital Imaging\bin;C:\Program Files\HP\Digital Imaging\bin\;C:\Program Files\HP\Digital Imaging\bin\Qt\Qt 4.3.3;C:\Program Files\MKVtoolnix;;c:\program files\java\jre7\bin
Trying c:\program files\java\jre7\bin\hotspot\jvm.dll (exists 0)
Trying c:\program files\java\jre7\bin\client\jvm.dll (exists 1)
Loading of JVM-DLL successful
launching program
GetTempPath returned 34 (last error 6)
expanding %EXE4J_EXEDIR% to C:\Program Files\Serviio\bin\ in -Xms5M -XX:+UseParNewGC -XX:MinHeapFreeRatio=5 -XX:MaxHeapFreeRatio=10 -Djava.net.preferIPv4Stack=true -Dserviio.home='C:\Program Files\Serviio\bin\\..'.
adding options
vmoptions: exe file: C:\Program Files\Serviio\bin\ServiioConsole.exe, long: C:\Program Files\Serviio\bin\ServiioConsole.exe, opts1: C:\Program Files\Serviio\bin\ServiioConsole.vmoptions, file: 00000000
vmoptions: opts2: C:\Program Files\Serviio\bin\ServiioConsole.exe.vmoptions, file: 004299A0
default vmoptions file: 004299A0
classpath entry S0..\.\lib;D0..\.\config;
GetTempPath returned 34 (last error 2)
vmoption count 15
vmoption 0: -Dexe4j.semaphoreName=Local\c:_program_files_pc5dczc_bin_serviioconsole.exe0
vmoption 1: -Dexe4j.moduleName=C:\Program Files\Serviio\bin\ServiioConsole.exe
vmoption 2: -Dsun.java.command=C:\Program Files\Serviio\bin\ServiioConsole.exe
vmoption 3: -Dexe4j.tempDir=C:\Users\admin\AppData\Local\Temp\e4j9003.tmp_dir1362864192
vmoption 4: -Dexe4j.unextractedPosition=599099
vmoption 5: -Djava.library.path=C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Windows Live\Shared;C:\Program Files\Common Files\HP\Digital Imaging\bin;C:\Program Files\HP\Digital Imaging\bin\;C:\Program Files\HP\Digital Imaging\bin\Qt\Qt 4.3.3;C:\Program Files\MKVtoolnix;;c:\program files\java\jre7\bin
vmoption 6: -Dexe4j.consoleCodepage=cp0
vmoption 7: -Xms5M
vmoption 8: -XX:+UseParNewGC
vmoption 9: -XX:MinHeapFreeRatio=5
vmoption 10: -XX:MaxHeapFreeRatio=10
vmoption 11: -Djava.net.preferIPv4Stack=true
vmoption 12: -Dserviio.home=C:\Program Files\Serviio\bin\\..
vmoption 13: -Dsun.locale.formatasdefault=true
vmoption 14: -Djava.class.path=C:\Users\admin\AppData\Local\Temp\e4j9003.tmp_dir1362864192\exe4jlib.jar;C:\Program Files\Serviio\bin\..\.\lib\commons-codec.jar;C:\Program Files\Serviio\bin\..\.\lib\commons-io.jar;C:\Program Files\Serviio\bin\..\.\lib\commons-lang.jar;C:\Program Files\Serviio\bin\..\.\lib\concurrent.jar;C:\Program Files\Serviio\bin\..\.\lib\derby.jar;C:\Program Files\Serviio\bin\..\.\lib\freemarker.jar;C:\Program Files\Serviio\bin\..\.\lib\groovy-all.jar;C:\Program Files\Serviio\bin\..\.\lib\gson.jar;C:\Program Files\Serviio\bin\..\.\lib\httpcore.jar;C:\Program Files\Serviio\bin\..\.\lib\jaudiotagger.jar;C:\Program Files\Serviio\bin\..\.\lib\jcl-over-slf4j.jar;C:\Program Files\Serviio\bin\..\.\lib\jcs.jar;C:\Program Files\Serviio\bin\..\.\lib\jdom.jar;C:\Program Files\Serviio\bin\..\.\lib\jul-to-slf4j.jar;C:\Program Files\Serviio\bin\..\.\lib\log4j.jar;C:\Program Files\Serviio\bin\..\.\lib\org.restlet.ext.gson.jar;C:\Program Files\Serviio\bin\..\.\lib\org.restlet.ext.net.jar;C:\Program Files\Serviio\bin\..\.\lib\org.restlet.ext.xstream.jar;C:\Program Files\Serviio\bin\..\.\lib\org.restlet.jar;C:\Program Files\Serviio\bin\..\.\lib\padlock.jar;C:\Program Files\Serviio\bin\..\.\lib\rome-modules.jar;C:\Program Files\Serviio\bin\..\.\lib\rome.jar;C:\Program Files\Serviio\bin\..\.\lib\sanselan.jar;C:\Program Files\Serviio\bin\..\.\lib\serviio-client.jar;C:\Program Files\Serviio\bin\..\.\lib\serviio-media-browser.jar;C:\Program Files\Serviio\bin\..\.\lib\serviio.jar;C:\Program Files\Serviio\bin\..\.\lib\slf4j-api.jar;C:\Program Files\Serviio\bin\..\.\lib\slf4j-log4j12.jar;C:\Program Files\Serviio\bin\..\.\lib\winp.jar;C:\Program Files\Serviio\bin\..\.\lib\xstream.jar;C:\Program Files\Serviio\bin\..\.\config;
Creating JVM
Post Sun Mar 10, 2013 12:09 pm
uninstall all Java versions and install java again
fredricz
Post Sun Mar 10, 2013 2:20 pm
Which version? Java6 (as recommended on your website) or Java7?
Post Sun Mar 10, 2013 2:35 pm
either
fredricz
Post Sun Mar 10, 2013 2:50 pm
zip wrote:either
Huh, worked like a charm. Thanks. :)
But, how can java get fucked up when I updated to Serviio 1.2?
ajg007
Post Sun Mar 17, 2013 10:13 pm
I was having issues until i uninstalled all java version and went to the site
http://www.java.com/en/download/manual.jsp
and downloaded the one i needed.
I think for some reason the web installer of java does not install it properly.
Hope this helps someone.
fredricz
Post Wed Apr 10, 2013 6:42 pm
Well, I installed the "default" recommended Java from the serviio installations (java 6). After a while I updated java.. And woopz, back to the same problem.
I uninstalled Java and installed Java 7 from their website and it started to work again. Amazing. :)
Christopher_Povey
Post Sat Apr 13, 2013 9:56 am
I have had issues in the past when updating Serviio or Java (mainly Java).
If I just run the Java 64-bit installer on my PC, on rebooting I get errors and Serviio fails to start up. I then have to reinstall Java 64-bit again and it works after another reboot. It seems the best policy when updating Java is to close the Serviio console and stop the service. Then install the Java update, and reboot. It seems Serviio "locks" some of the Java files, but the Java updater does not realise.
With the last Serviio update I also had problems. I installed it and the Serviio console did not start up. The Serviio service was running as ServiDroid could see it. When I looked into it, the Serviio entry in Start Up menu was there, but the short cut was actually missing! I then checked the bin folder for Serviio and there were files in it with corrupted and invalid names (foreign characters and symbols). I removed Serviio completely (which actually crashed the uninstaller) and did a manual clean up and reinstalled it. It has been fine ever since.
Chris
Running Serviio on Intel Q6700 Windows 7 Ultimate x64 PC feeding a Sony BDP-S570, Pansonic TX-L37G20B, and a XBox 360.
Managed with Serviidroid via HTC One X
sachiel
Post Sat Apr 13, 2013 3:42 pm
Upgrade to 1.1 from 1.0: Java screws up; Serviio Server refuses to start. Take an hour of Java/Serviio reinstalls and reboots to fix on a 2008 R2 server.
Upgrade to 1.2 from 1.1: Java screws up; Serviio Server refuses to start. Take an hour of Java/Serviio reinstalls and reboots to fix.
Can you guys get this sorted before 1.3? It's getting pretty annoying and making me gun-shy about updating. I'm a paying Pro customer by the way.
slyguy42o
Post Sat Apr 13, 2013 5:25 pm
it's strange how some people have this issue and some don't. I have three serviio instances on my network and they all upgrade without issue. (well maybe some profile tweaking is required.. but no issues with java itself)
question - do you have java automatic updating enabled?
sachiel
Post Sat Apr 13, 2013 6:26 pm
I have Java set to autoupdate. I was on 7 17 before and after the update. It's update serviio -> serviio doesn't work. Reboot and Serviio still doesn't work. I removed java, reinstalled java (without rebooting) and that didn't work. I then removed Java and Serviio, rebooted, installed Java 7, rebooted, installed serviio, rebooted and then the service came back on. I had to rebuild my library and reset all my settings. In hindsight, I should have maybe rebooted after pulling Java off the first time. I couldn't remember what steps I took during the last update.
I was also using a Domain Admin level account to do the Serviio update.
fredricz
Post Sat Apr 20, 2013 9:37 am
I didn't have any problems before Serviio 1.0.1, but I've disabled Java AutoUpdate to avoid these problems. Everytime I update serviio, I have to uninstall Java, install serviio and then install the newest Java version.
dkammermann
Post Thu May 09, 2013 7:55 am
I use a mac and have unistalled java and servio, reinstalled both several times and still cannot get it to work. It was working no problems before the last update. Can anyone offer some ideas?
Users browsing this forum: No registered users and 276 guests
