Sony Bluray image resolution issue
IJ25
Post Mon Apr 01, 2013 11:13 pm
Hi
I've been using Serviio for PC for some time with a couple of Sony Bluray players (BDP-S370 and BDV-E370) plus a Sony Bravia TV (KDL-40EX503). All images, audio and video work well across all Sony devices, as well as to my iOS devices using the Airplayer app.
Today I've upgraded my digital camera to a Sony Cybershot HX20V - 16MP, image resolution 4896 x 3672. The Bravia TV handles these images fine, but not the bluray players (just display blank screen). Following advice in another thread I edited the file profiles.xml so that the bluray profiles contain the value <LimitImageResolution>false</LimitImageResolution>. This solves the issue for the large files, and most other files play well. However I have a lot of scanned images at 1800x1200 which now don't work, although older digital images at 1600x1200 are fine. I'm confused!
I'm not very familiar with xml so highly likely I've done something wrong. Any advice much appreciated!
IJ25
Post Thu Apr 04, 2013 6:51 pm
Re: Sony Bluray image resolution issue
Any suggestions or advice, anyone?
This is frustrating as my Sony TV can handle all of the image types (and other media) that Serviio throws at it - only the Sony Bluray players are struggling with the larger image size.
Cheers
slyguy42o
Post Thu Apr 04, 2013 7:24 pm
I am not sure what the issue could be, can you try viewing a few of the images that don't work then post your detailed server logs?
IJ25
Post Fri Apr 05, 2013 9:38 pm
Thanks for the reply.
This is what I see in the file serviio.log after trying a few images (this is with the modified profiles.xml on my Sony BDP-S370 as described in my original post). Larger images display fine (e.. 4896x3672, 3264x2448), but smaller images (e.g. 1800x1200) just show a black screen with the timer - eventually I have to hit 'return' and no error shows in the log ...
If I revert to the original profiles.xml, all images display correctly except the largest (4896x3672). This only affects the Sony Bluray players - my Sony TV, iOS devices display everything fine.
2013-04-05 22:07:05,186 INFO [MediaServer] ------------------------------------------------------------------------
2013-04-05 22:07:05,217 INFO [ServiioConsole] Starting Serviio Console
2013-04-05 22:07:05,264 INFO [MediaServer] Serviio DLNA media streaming server v 1.2.1 (rev. a2aa56064460+)
2013-04-05 22:07:05,264 INFO [MediaServer] Petr Nejedly 2009-2013
2013-04-05 22:07:05,264 INFO [MediaServer] http://www.serviio.org
2013-04-05 22:07:05,264 INFO [MediaServer] Java 1.6.0_13-Sun Microsystems Inc.
2013-04-05 22:07:05,264 INFO [MediaServer] OS Windows Vista x86 6.1
2013-04-05 22:07:05,264 INFO [MediaServer] File encoding: windows-1252
2013-04-05 22:07:05,326 INFO [MediaServer] Headless mode enabled: true
2013-04-05 22:07:05,326 INFO [MediaServer] User: JENKINS-PC$
2013-04-05 22:07:05,326 INFO [MediaServer] User home dir: C:\
2013-04-05 22:07:05,326 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2013-04-05 22:07:05,326 INFO [MediaServer] ------------------------------------------------------------------------
2013-04-05 22:07:15,326 INFO [WebServer] Socket buffer set to 65535 bytes
2013-04-05 22:07:15,404 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-04-05 22:07:18,040 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-04-05 22:07:18,040 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-04-05 22:07:19,288 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-04-05 22:07:27,026 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-04-05 22:07:56,682 INFO [MediaServer] ------------------------------------------------------------------------
2013-04-05 22:07:56,682 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2013-04-05 22:07:56,806 INFO [Device] Created UPnP Device with UUID: ed7af508-ea08-31fc-8d66-78bc66833cd9, bound address: 192.168.0.7
2013-04-05 22:08:00,706 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-04-05 22:08:01,689 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-04-05 22:08:01,954 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-04-05 22:08:01,970 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-04-05 22:08:01,970 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-04-05 22:08:01,970 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-04-05 22:08:01,970 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-04-05 22:08:01,986 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-04-05 22:08:01,986 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-04-05 22:08:01,986 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-04-05 22:08:01,986 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2013-04-05 22:08:01,986 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2013-04-05 22:08:01,986 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2013-04-05 22:08:01,986 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2013-04-05 22:08:01,986 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-04-05 22:08:01,986 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-04-05 22:08:01,986 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-04-05 22:08:01,986 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-04-05 22:08:01,986 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-04-05 22:08:01,986 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-04-05 22:08:01,986 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-04-05 22:08:01,986 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-04-05 22:08:02,001 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2013-04-05 22:08:02,001 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2013-04-05 22:08:02,001 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-04-05 22:08:02,001 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-04-05 22:08:02,001 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-04-05 22:08:02,001 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-04-05 22:08:02,001 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-04-05 22:08:02,001 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-04-05 22:08:02,001 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-04-05 22:08:02,001 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-04-05 22:08:02,001 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-04-05 22:08:02,001 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2013-04-05 22:08:02,001 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2013-04-05 22:08:02,110 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-04-05 22:08:02,110 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-04-05 22:08:02,110 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-04-05 22:08:02,110 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-04-05 22:08:03,202 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-04-05 22:08:03,218 INFO [UpdateChecker] Checking if a new version is available
2013-04-05 22:08:03,265 INFO [PluginCompilerThread] Started looking for plugins
2013-04-05 22:08:06,806 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-04-05 22:08:08,538 INFO [WebServer] WebServer starting on port 8895
2013-04-05 22:08:08,974 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-04-05 22:08:08,974 INFO [EventDispatcher] Starting EventDispatcher
2013-04-05 22:08:08,974 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-04-05 22:08:09,086 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2013-04-05 22:08:09,117 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth6 (Realtek PCI GBE Family Controller #2) and address 192.168.0.7, timeout = 0
2013-04-05 22:08:09,179 INFO [RendererSearchSender] Searching for Renderer devices
2013-04-05 22:08:16,068 INFO [Messages] Loaded console message bundle for locale: en
2013-04-05 22:08:36,141 INFO [FeedUpdaterThread] Started looking for information about online resources
2013-04-05 22:08:36,305 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-04-05 22:08:36,866 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-04-05 22:08:36,867 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-04-05 22:08:56,321 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-04-05 22:08:57,465 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2013-04-05 22:17:32,037 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:17:38,165 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:17:39,141 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:17:40,668 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:17:42,264 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:17:42,675 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:17:43,201 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:17:44,950 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:17:45,641 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:17:46,752 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:17:47,750 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:18:05,239 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:18:07,612 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:18:09,280 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:18:11,176 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:18:11,819 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:18:13,109 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:18:14,658 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:18:15,665 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:18:16,930 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:18:17,859 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
2013-04-05 22:18:19,136 WARN [LibraryManager] Skipping processing metadata for an unsupported file. Message: Unknown video codec.
IJ25
Post Sun Apr 14, 2013 6:08 pm
I'm assuming by the limited responses to this post that there isn't a solution - which is a real shame as I've been a big fan of Serviio :cry:
Post Sun Apr 14, 2013 6:11 pm
Could you post some samples files?
IJ25
Post Sun Apr 14, 2013 6:18 pm
Hi, thanks for the reply. I have a couple of sample images but they total 5MB, against the forum upload limit of 500KB. Any suggestions for the most suitable alternative means of posting such large files?
Users browsing this forum: Bing [Bot] and 4 guests
