Local MKV file with AAC = no sound
koan00
Post Fri Apr 19, 2013 10:03 pm
I am using the sony 2011-us profile. When attempting to play a MKV file with AAC audio, I get no audio. I did notice the transcoded file changes the audio format to AAC (ADTS). Not sure if this is the culprit...
ffmpeg -i
ffmpeg version 1.1.4 Copyright (c) 2000-2013 the FFmpeg developers
  built on Mar 23 2013 15:34:14 with gcc 4.7.2 (GCC)
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid --enable-libass
  libavutil      52. 13.100 / 52. 13.100
  libavcodec     54. 86.100 / 54. 86.100
  libavformat    54. 59.106 / 54. 59.106
  libavdevice    54.  3.102 / 54.  3.102
  libavfilter     3. 32.100 /  3. 32.100
  libswscale      2.  1.103 /  2.  1.103
  libpostproc    52.  2.100 / 52.  2.100
Input #0, matroska,webm, from 'Mickey's.Choo.Choo.Express.mkv':
    creation_time   : 2009-12-18 20:41:37
  Duration: 00:47:01.99, start: 0.000000, bitrate: 595 kb/s
    Chapter #0.0: start 0.105000, end 2821.986000
      title           : 00:00:00.105
    Stream #0:0: Video: h264 (High), yuv420p, 704x384, SAR 1:1 DAR 11:6, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: aac, 44100 Hz, stereo, fltp (default)
      title           : English
Media Info original file:
Unique ID                                : 232764635720230171267529713581341248243 (0xAF1CD693CD9E56D18642516D48B78AF3)
Complete name                            : C:\Mickey's.Choo.Choo.Express.mkv
File size                                : 200 MiB
Duration                                 : 47mn 1s
Overall bit rate                         : 596 Kbps
Encoded date                             : UTC 2009-12-18 20:41:37
Writing application                      : mkvmerge v2.9.7 ('Tenderness') built on Jul  1 2009 18:43:35
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Format profile                           : High@L3.0
Format settings, ReFrames                : 7 frames
Duration                                 : 47mn 1s
Nominal bit rate                         : 538 Kbps
Width                                    : 704 pixels
Height                                   : 384 pixels
Display aspect ratio                     : 1.85:1
Bits/(Pixel*Frame)                       : 0.083
Writing library                          : x264 core 72 r1222 d0ee6f8
Encoding settings                        : cabac=1 / ref=7 / deblock=1:1:1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.4:0.0 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=16 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=0 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / mbtree=0 / bitrate=538 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.60
Format profile                           : HE-AAC / LC
Codec ID                                 : A_AAC
Duration                                 : 47mn 1s
Sampling rate                            : 44.1 KHz / 22.05 KHz
Title                                    : English
Menu
00:00:00.105                             : en:00:00:00.105
Media Info for transcoded file:
Complete name                            : C:\transcoding-temp-446-sony2011us-ORIGINAL.stf
Format                                   : MPEG-TS
File size                                : 225 MiB
Duration                                 : 47mn 1s
Overall bit rate                         : 669 Kbps
Menu ID                                  : 1 (0x1)
Codec ID                                 : 27
Duration                                 : 47mn 1s
Width                                    : 704 pixels
Height                                   : 384 pixels
Menu ID                                  : 1 (0x1)
Format version                           : Version 4
Muxing mode                              : ADTS
Codec ID                                 : 15
Duration                                 : 47mn 1s
Menu
Menu ID                                  : 1 (0x1)
Duration                                 : 47mn 1s
List                                     : 256 (0x100) (AVC) / 257 (0x101) (AAC, English)
Language                                 :  / English
Service name                             : Service01
Service provider                         : FFmpeg
Service type                             : digital television
Post Sat Apr 20, 2013 8:21 am
Re: Local MKV file with AAC = no sound
@koan00 : HE-AAC audio is not supported, need to be transcoded.
With ffmpeg:
@Zip, I'm not sure but, does "fltp" expression on ffmpeg output means HE-AAC ?
Post Sun Apr 21, 2013 12:38 am
gk9
Post Thu May 23, 2013 5:57 pm
I am having the same problem with a similar setup (2011 Sony TV).
In particular, I had serviio 0.6.2 with ffmpeg-0.7.13 installed, and it was working fine.
I just upgraded serviio to 1.2.1 (and also installed ffmpeg 1.2.1), and I started having problems. Non-AAC mkv's are transcoded fine.
This does not work:
Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1: Audio: aac, 48000 Hz, stereo, fltp (default)
Stream #0:2: Subtitle: subrip (default)
This works:
Stream #0:0: Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s (default)
koan00
Post Mon Jun 03, 2013 12:54 pm
After version 0.6.2 I believe the Sony profile was changed to allow the TV to natively decode AAC instead of transcoding it (before it was all transcoded).
However the TV is a bit picky on what it accepts. As of right now, the profile logic is not setup to properly feed the TV only the AAC audio it can actually decode. The fix for me is to simply go back to the previous working method and transcode the AAC again.
In your profiles.xml file, at about line 660 you should see text like this:
<Matches container="matroska" vCodec="h264" aCodec="aac" />
Delete it, or comment it out like this:
<!-- Matches container="matroska" vCodec="h264" aCodec="aac" / -->
Or you can use the profile file that I am using now. It has 2 changes: 1) Trancodes the AAC audio. and 2) Removes all of the DAR attributes (this fixes a lot of my content being weirdly stretched by serviio).
profiles.xml
(90.09 KiB) Downloaded 814 times
gk9
Post Mon Jun 03, 2013 1:05 pm
Yes, I ended up doing this, too, (based on another post), and now it works.
Hmm.. It seems to me, though, that the profile for the Sony TVs, then, should be a bit conservative, until the profile logic is correct for all models. I vote for reverting the profile, in the shipping profile, so that people don't get into the same issue me (and other people) have hit.
koan00
Post Mon Jun 03, 2013 1:18 pm
I have mentioned the same sentiment in others threads as well. I just submitted a bug ticket on the issue. Please add your thoughts: https://bitbucket.org/xnejp03/serviio/i ... io-changes
Post Mon Jun 03, 2013 1:21 pm
Illico, can you comment on the issue? I think we should transcode AAC if the detection is not 100%
Post Mon Jun 03, 2013 1:48 pm
koan00 wrote:..Or you can use the profile file that I am using now. It has 2 changes: 1) Trancodes the AAC audio.
We limited transcoding process for NAS system with low CPU,.
That is why profile has been changed to allow the TV to natively decode AAC.
But with serviio/ffmpeg, we can not distinguish HE-AAC (not supported) vs AAC (supported).
Zip, which option should be preferred ?
koan00 wrote:and 2) Removes all of the DAR attributes (this fixes a lot of my content being weirdly stretched by serviio).
Can we conclude that the DAR option should be removed for all U.S. models (2009 -> 2012)? if it 's the case, we have to make a custom 2012-us profile (and 2010-2011(us) inheritance...)
koan00
Post Mon Jun 03, 2013 2:01 pm
I think Zip was only referring to the Audio issue.
For DAR, I'm not sure the fix I use is widely applicable.
Post Mon Jun 03, 2013 2:09 pm
koan00 wrote:I think Zip was only referring to the Audio issue.
Yes, it is up to Zip to make the choice.
koan00 wrote:For DAR, I'm not sure the fix I use is widely applicable.
@koan00, what is your model number and region ?
Is there some other 2012 users with Display Aspect Ratio problem ?
koan00
Post Mon Jun 03, 2013 3:15 pm
Illico wrote:@koan00, what is your model number and region ?
I have a 2011 kdl-55nx720 (US). I can't comment on the 2012 users..
Post Mon Jun 03, 2013 3:50 pm
Ok, let's revert to the original state and add a comment in the profile to comment the line to avoid transcoding.
Illico, can you comment on the ticket with changes I need to make?
Post Mon Jun 03, 2013 7:48 pm
zip wrote:Illico, can you comment on the ticket with changes I need to make?
I post here the Sony Bravia profiles (attach on bitbucket does not work)...
profiles - SonyBravia - beta1.3.xml
AAC - h264 high_10 will be transcoded
(29.08 KiB) Downloaded 837 times
