Many Issues with MKV Playback - Samnsung C Series
darkcloud784
Post Wed May 15, 2013 5:28 pm
I recently moved from windows to ubuntu and had to re-install serviio. On windows this movie was able to play with full dynamics, now for some reason its not. It plays the fist 5 minutes of the video in surround sound and full dynamics, now it does not. FFmpeg information is listed below. I've also noticed some movies dont play back at all anymore, they just give me a "not supported format" error. Lastly, some of the sound on our movies have been off sync, they weren't before when we were streaming from our windows media box fitted with serviio. The device I am trying to stream to is a C series Samsung TV. Specific model is: Model Number: LN46C630K1FXZA
Sound dynamics lost on this file:
ffmpeg version 0.8.6-4:0.8.6-0ubuntu0.12.04.1, Copyright (c) 2000-2013 the Libav developers
  built on Apr  2 2013 17:02:36 with gcc 4.6.3
[matroska,webm @ 0x95c9c0] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from 'Rio (2011).mkv':
  Duration: 01:35:57.81, start: 0.000000, bitrate: 1536 kb/s
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x800 [PAR 1:1 DAR 12:5], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) (forced)
    Stream #0.1(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 1536 kb/s (default) (forced)
This file doesn't play at all:
Input #0, avi, from 'Aladdin and the King of Thieves (1996).avi':
    encoder         : Lavf52.77.0
  Duration: 01:18:09.26, start: 0.000000, bitrate: 2209 kb/s
    Stream #0.0: Video: h264 (Main), yuv420p, 720x480 [PAR 1:1 DAR 3:2], 29.97 fps, 29.97 tbr, 29.97 tbn, 59.94 tbc
    Stream #0.1: Audio: mp3, 48000 Hz, stereo, s16, 256 kb/s
Sound not sync'd file:
[matroska,webm @ 0x169c9c0] max_analyze_duration reached
[matroska,webm @ 0x169c9c0] Estimating duration from bitrate, this may be inaccurate
Input #0, matroska,webm, from 'Finding Nemo (2003).mkv':
title : Finding Nemo (2003)
Duration: 01:36:28.08, start: 0.000000, bitrate: 1216 kb/s
Chapter #0.0: start 0.000000, end 229.418667
title : Chapter 01
Chapter #0.1: start 229.418667, end 303.458667
title : Chapter 02
Chapter #0.2: start 303.458667, end 631.552000
title : Chapter 03
Chapter #0.3: start 631.552000, end 687.632000
title : Chapter 04
Chapter #0.4: start 687.632000, end 795.952000
title : Chapter 05
Chapter #0.5: start 795.952000, end 930.272000
title : Chapter 06
Chapter #0.6: start 930.272000, end 1065.552000
title : Chapter 07
Chapter #0.7: start 1065.552000, end 1450.970667
title : Chapter 08
Chapter #0.8: start 1450.970667, end 1761.330667
title : Chapter 09
Chapter #0.9: start 1761.330667, end 1881.770667
title : Chapter 10
Chapter #0.10: start 1881.770667, end 2065.010667
title : Chapter 11
Chapter #0.11: start 2065.010667, end 2301.810667
title : Chapter 12
Chapter #0.12: start 2301.810667, end 2569.490667
title : Chapter 13
Chapter #0.13: start 2569.490667, end 2755.786667
title : Chapter 14
Chapter #0.14: start 2755.786667, end 2941.666667
title : Chapter 15
Chapter #0.15: start 2941.666667, end 3211.026667
title : Chapter 16
Chapter #0.16: start 3211.026667, end 3488.322667
title : Chapter 17
Chapter #0.17: start 3488.322667, end 3742.242667
title : Chapter 18
Chapter #0.18: start 3742.242667, end 3839.482667
title : Chapter 19
Chapter #0.19: start 3839.482667, end 3924.176000
title : Chapter 20
Chapter #0.20: start 3924.176000, end 4201.976000
title : Chapter 21
Chapter #0.21: start 4201.976000, end 4256.256000
title : Chapter 22
Chapter #0.22: start 4256.256000, end 4355.696000
title : Chapter 23
Chapter #0.23: start 4355.696000, end 4510.296000
title : Chapter 24
Chapter #0.24: start 4510.296000, end 4698.576000
title : Chapter 25
Chapter #0.25: start 4698.576000, end 4844.216000
title : Chapter 26
Chapter #0.26: start 4844.216000, end 4983.136000
title : Chapter 27
Chapter #0.27: start 4983.136000, end 5129.176000
title : Chapter 28
Chapter #0.28: start 5129.176000, end 5210.496000
title : Chapter 29
Chapter #0.29: start 5210.496000, end 5317.576000
title : Chapter 30
Chapter #0.30: start 5317.576000, end 5357.312000
title : Chapter 31
Chapter #0.31: start 5357.312000, end 5788.080000
title : Chapter 32
Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 25 fps, 25 tbr, 1k tbn, 50 tbc (default)
title : Video
Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
title : English DD5.1
Stream #0.2(eng): Audio: dca (DTS), 48000 Hz, 5.1, s16, 768 kb/s
title : English DTS
Stream #0.3(ita): Subtitle: dvdsub (default) (forced)
title : Italiano Forced
Stream #0.4(ita): Subtitle: dvdsub
title : Italiano
Stream #0.5(eng): Subtitle: dvdsub
title : English
Stream #0.6(eng): Subtitle: dvdsub
title : English for the hearing impaired
Post Thu May 16, 2013 11:11 pm
Re: Many Issues with MKV Playback - Samnsung C Series
Your FFmpeg is old, build a new one as per instructions on the wiki.
darkcloud784
Post Fri May 17, 2013 1:43 am
zip wrote:Your FFmpeg is old, build a new one as per instructions on the wiki.
I followed the instructions as laid out here... http://wiki.serviio.org/doku.php?id=how ... all:ubuntu
-Edit- I have re-installed ffmpeg by building it manually. Most of the issues seem to be resolved
Though Rio still has issues with sound "blips" where it will randomly go to stereo then back to surround.
ffmpeg version git-2013-05-17-17989dc Copyright (c) 2000-2013 the FFmpeg developers
  built on May 16 2013 21:38:38 with gcc 4.6 (Ubuntu/Linaro 4.6.3-1ubuntu5)
  configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-libvpx --enable-librtmp --enable-libxvid --enable-libass
  libavutil      52. 32.100 / 52. 32.100
  libavcodec     55.  9.100 / 55.  9.100
  libavformat    55.  7.100 / 55.  7.100
  libavdevice    55.  0.100 / 55.  0.100
  libavfilter     3. 68.101 /  3. 68.101
    creation_time   : 2011-07-14 02:34:05
  Duration: 01:35:57.81, start: 0.000000, bitrate: 9767 kb/s
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x800 [SAR 1:1 DAR 12:5], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) (forced)
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default) (forced)
Post Fri May 17, 2013 12:31 pm
This file should not be transcoded, so it's up to the TV or the file to play as intended.
