avi and mkv videos in Sony KDL-46HX820 (BRAVIA)
anousheh
Post Sat May 25, 2013 12:37 am
I am new to Serviio. Please help me to get things right! Appreciate your time and help.
Version: 1.2.1
I have installed Serviio in 2 desk-top. Both Windows 7. For one PC, Serviio icon can be seen on the TV. The TV cannot see avi files. mkv files are OK but there are no sound for these.
On the other PC, copmuter name appears on the TV but without Serviio icon. Therefore, no files can be streamed from this PC.
Could you please give me step-by-step procedure to fix these issues?
Thank you again and all the best,
Anousheh
NX3
Post Sat May 25, 2013 9:16 am
Re: avi and mkv videos in Sony KDL-46HX820 (BRAVIA)
What country did you buy your tv in ?
What is selected for the profile in serviio for you device ?
anousheh
Post Sat May 25, 2013 4:04 pm
1- USA
2- Sony Bravia TV (2011) - US
Thank you again,
Anousheh
NX3
Post Sat May 25, 2013 6:02 pm
Have you got transcoding enabled?
The audio issue is a known issue. I've posted a fix before but not on desktop so can't dig it out...you'll find it on here, look for no aac audio.
Sent from my Nexus 7 using Tapatalk 2
anousheh
Post Sat May 25, 2013 11:54 pm
Thanks again.
Yes. Transcoding is enabled.
Anousheh
anousheh
Post Mon May 27, 2013 5:40 pm
I am still waiting to see if I can get some help to solve the issue.
Thank you,
Anousheh
Luscombag
Post Tue May 28, 2013 4:00 pm
My Sony BDP-BX57 will also not display AVI Files. I haven't tried the MKV yet. It used to play AVI, but since I updated Serviio to 1.2.1 I have had this problem. I noticed that the profile names have changed on my device in the console. I guess I'll try using a generic when I get home tomorrow and see if that fixes it. I'll let you know how it goes.
[b]Serviio 1.5.2 | Sony PS3 Slim | Sony PS4 | Sony BDP-BX57 BD Player | Windows 7 I AMD Octa-Core
NX3
Post Tue May 28, 2013 5:03 pm
anousheh wrote:Hello,
Thank you,
Anousheh
This was the profile fix for 2011 which worked for me. Try this, change to 2011 (not US) then see if you get audio on your mkv's. If yes then the same change can be applied to USA 2011 profile to get audio.
viewtopic.php?p=66363#p66363
anousheh
Post Wed May 29, 2013 6:59 am
Hello all,
Thank you. Please let me know where all these CODES are and how to change/replace them?
Thanks again,
Anousheh
Post Wed May 29, 2013 7:36 am
anousheh wrote:Hello all,
Thanks again,
Anousheh
First, on serviio console do you try to change manually the profile :
1- Sony Bravia TV (2011) - US => Not work
2- Sony Bravia TV (2011) => ?
3- Sony Bravia TV (2012) => ?
4 - etc
anousheh
Post Wed May 29, 2013 7:22 pm
4 - etc
I have tried (2011) and (2011)-US, but not (2012)
Anousheh
Luscombag
Post Wed May 29, 2013 8:38 pm
Something has changed in the profiles. On my PC running Serviio 1.1 it will play avi files. On my Main PC with Serviio 1.2.1, My Sony BluRay player will not display AVI files. I Changed the profiles and found that the Sony Bravia TV (2009) allows my BluRay Player to play all files, but none of the ones that are intended for my BluRay work anymore. But at least I found a temp/patch fix.
NX3
Post Wed May 29, 2013 8:41 pm
anousheh, on Windows 7 "profiles.xml" file is located in "C:\Program Files\Serviio\config"
Take a backup copy of your existing file. Copy the one from my posting above and replace the file in the folder "C:\Program Files\Serviio\config". Restart the PC, for your TV select "Sony 2011", play a mkv and see if you get sound now ?
NX3
Post Wed May 29, 2013 8:42 pm
Luscombag wrote:Something has changed in the profiles. On my PC running Serviio 1.1 it will play avi files. On my Main PC with Serviio 1.2.1, My Sony BluRay player will not display AVI files. I Changed the profiles and found that the Sony Bravia TV (2009) allows my BluRay Player to play all files, but none of the ones that are intended for my BluRay work anymore. But at least I found a temp/patch fix.
Thats forcing all your files to be transcoded to mpeg2, creating a lot of work for the PC but at least they work.
anousheh
Post Wed May 29, 2013 11:08 pm
NX3 wrote:anousheh, on Windows 7 "profiles.xml" file is located in "C:\Program Files\Serviio\config"
Hello NX3,
Thank you. I did what you suggested. Now I have sound. Thank you so much.
Could you please tell me:
1- how to get avi files? No avi files there!
2- My other computer with Serviio installed cannot be seen by the TV. (It was OK before)!
Thank you for your time and help.
Anousheh
NX3
Post Thu May 30, 2013 5:13 pm
Set your profile to Sony2009 and see if the AVI are listed and play ? If not then as per my foot get mediainfo and get the details of what codec your AVI's are using.
Is your 2nd PC streaming to the same tv ? It stopped working without you making any changes ? Have you rebooted the PC ? Is this all wired or over wifi ? Have you check the network connections ?
anousheh
Post Fri May 31, 2013 12:17 am
NX3 wrote:Set your profile to Sony2009 and see if the AVI are listed and play ? If not then as per my foot get mediainfo and get the details of what codec your AVI's are using.
Hello NX3,
Thanks. I am going to set the profile to Sony 2009 to see if it works. I shall let you know.
Answers to your questions regarding my 2nd PC:
- Yes, it is streaming to the same TV.
- Yes, it stopped working after I installed 1.2.1.
- Yes, I have rebooted the PC few times.
- Everything is wired.
- yes, network is good and the connections are OK.
Thank you so much for your time and help.
Anousheh
NX3
Post Sun Jun 02, 2013 8:44 am
Weird 2nd pc not working properly with Serviio. I'd uninstall it, reboot then install again....
Do you have fixed ip addresses on the PCs?
Sent from my HTC Desire S using Tapatalk 2
anousheh
Post Tue Jun 04, 2013 7:07 am
I shall do this.
How do I find out?
Anousheh
Post Tue Jun 04, 2013 9:15 am
Luscombag wrote:My Sony BDP-BX57 will also not display AVI Files. I haven't tried the MKV yet. It used to play AVI, but since I updated Serviio to 1.2.1 I have had this problem. I noticed that the profile names have changed on my device in the console...
Do you try with "Sony BDP-Sx70/SMP-N100 (2010) - US" or "Sony BDP-Sx80/SMP-N200 (2011)" profiles ?
