How work subtitle options "Enable burned-in subtitle"?
thenamelessthing
Post Thu May 02, 2013 1:56 am
Hi, I want to know how exactly work this setting? What is the difference between Always and only if required? What is the condition for "only when required"?
Because when I specified fre as prefered sub language and I select "only when required" the sub are not show. But If I choose Always, that's working...
Thanks you.
My Setup : BDT220 Panasonic Bluray player, TC-L55ET5 and TC-L42ET5 Panasonic TV. My home media server run Serviio 1.4.2 Pro under GNU/Linux Ubuntu 14.04 LTS server x64 and the hardware is Amd 1045t Phenom II X6, 6Gb DDR3 1333 mhz on SSD and data on soft raid 5 (3x1tb).
Post Thu May 02, 2013 9:13 pm
Re: How work subtitle options "Enable burned-in subtitle"?
It depends on profile. Some devices don't need burned in subtitles, or only need them for some containers. I think it's the case of Viera devices.
thenamelessthing
Post Mon Jun 17, 2013 10:53 am
Any way to work this way with panasonic?
If it's set to: "only if required"
"If no "fre" audio is detected and an "fre" sub is detected, then use the sub"
Actually as I already said, it's only working when it's set to "Always"
P.S. Any hope to include in 1.3 audio track language selection when transcoding? :?:
Post Mon Jun 17, 2013 3:44 pm
The 'when necessary' currently used technical side of things (ie when the TV requires it). It's notlogical (ie when the customer needs it).
No.
thenamelessthing
Post Mon Jun 17, 2013 4:29 pm
When you say "when the TV requires it" how can I find if the tv ask for it or not? Any debugging tool to find this?
Post Mon Jun 17, 2013 7:15 pm
usually from experience of the users or from what other software does. Viera doesn't need burned-in subtitles with most file types, AFAIK
